Question about Lexmark X3550 All-In-One Printer
Not reading new ink cartridge
I have installed a color 24 print cartridge in my x3550 printer, and it is indicating that the cartridge is incorrect, however, this is the same cartridge that is required
  • natalewilson Jun 19, 2009
    Yeah its in the right spot. I guess ill take it back.
    Thanks
  • 400 Answers
Are you installing where the colour cartridge goes?
It could be faulty ,return it or let them test it.
Posted on Jun 19, 2009
Replaced ink with #32 & #33 but keeps saying right & left ink cartridges incorrect. please help
The Lexmark X3550 cartridges are:
Black: #23, #23A, and #34 Color: #24 , #24A and #35
I hope this explains why you are getting the error. Thanks.
Feb 16, 2011 | Lexmark X3550 All-In-One Printer
How do I install the printer cartrige? I do not have the booklet...
  1. Turn on your printer.
  2. Open the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press the tabs on the cartridge lids, then lift the lids.
  1. Remove the old ink cartridges.
  1. Store the cartridges in an air-tight container or dispose of them properly.
  2. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
NOTE: You can use your printer with one cartridge (color or black) at a time. To extend the life of your color cartridge and improve printing speed, install both a color cartridge and a black cartridge at the same time.
  1. Insert the new ink cartridges. Make sure the color ink cartridge is secure in the left ink cartridge carrier and the black ink cartridge is secure in the right ink cartridge carrier.
  1. Snap each lid closed.
  1. Close the front cover. The front cover must be closed to start a print job.
  1. Open the Dell Printer Solution Center by clicking Start® Programs or All Programs® Dell Printers® Dell Photo Printer 720® Dell Printer Solution Center.
  2. Click the Maintenance tab.
  3. Click Install a new print cartridge.
  4. Click Next.
  5. Select the type of cartridge you installed.
NOTE: Specify whether the cartridge is a new cartridge or an old cartridge (one that has been used before). If an old cartridge is incorrectly identified as New Cartridge in the Dell Printer Solution Center, ink levels may be incorrect.
  1. Click Next.
Dec 17, 2010 | Dell Inkjet 720 Printer
Keeps saying insert colour cartridge when we have just bought a new cartridge of correct spec. Says incorrect colour cartridge installed.Impossible to get past!!!
Hi,The most common reason for missing or incorrect colors is a print cartridge with one of the following problems:
  • One or more of the ink colors is empty. The black ink and all three colors of ink in the tri-color cartridge must be available or colors will be incorrect or missing. Under normal usage, the print cartridge will run low on one color of ink shortly before all ink colors are emptied.
  • The protective tape is not removed from a new cartridge.
  • Contacts on the cartridge are not making proper contact with the print carriage.
  • The cartridge is remanufactured or refilled.
  • The cartridge is defective.
Feb 14, 2010 | HP PSC 950 All-In-One InkJet Printer
I have lexmark x3580 printer i refilling the ink cartridge i have this massage in printer left cartridge Incorrect ( the black )
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Oct 02, 2009 | Lexmark X3550 All-In-One Printer
I have installed a black 23 print cartridge in my x3550 printer, and it is indicating that the cartridge is incorrect, however, this is the same cartridge that is required.
Left/Right Cartidge Incorrect - huh? The printer is saying Left Cartridge Incorrect or Right Cartridge Incorrect,
and you are sure that you inserted the correct cartridge, a #23 or #24.
A small number of #23/#24 cartridges will report as Incorrect Cartridge because
of a manufacturing issue. There is a firmware upgrade available to fix this problem, and allow
the printer to accept the cartridge.
3500-4500 Series (X3550, X4550)
3400 Series (X3430)
1400 Series (Z1420)
To apply the upgrade:
  1. Make sure the printer is turned ON and connected with a USB cable.
  2. Download and run the appropriate update program using the links above.
  3. Be careful not to disconnect or turn off your printer while it is being updated.
When the update is complete the printer should automatically restart and accept the #23/#24 cartridges.
Jun 18, 2009 | Lexmark X3550 All-In-One Printer
Printer reads "Incorrect Print Cardtridge Installed"
According to the HP website, the correct cartridge for the HP PSC950 is HP15 or HP78. Comes in black only or tri-color.
Dec 22, 2008 | HP PSC 950 All-In-One InkJet Printer
Display shows: printer cartridge incorrect
It seems like you are using incorrect printer cartridges.....
Make sure that part number on ink cartridges should be :
MK990 Cartridge, Ink, Standard, Series-9, Black CTRG,INK,STD,SERIES-9,BLK 0 1 0 Yes 1 N MK991 Cartridge, Ink, Standard, Series-9, Color CTRG,INK,STD,SERIES-9,CLR 0 1 0 Yes 1 N MK992 Cartridge, Ink, High-Yield, Series-9, Black CTRG,INK,HIYLD,SERIES-9,BLK 0 1 0 Yes 1 N MK993 Cartridge, Ink, High-Yield, Series-9, Color CTRG,INK,HIYLD,SERIES-9,CLR 0 1 0 Yes 1 N MK995 Cartridge, Ink, Series-9, Photo
Nov 10, 2008 | Dell 962 Photo All-In-One InkJet Printer
Lexmark 3500 wireless
I have put in genuine Lexmark ink catridges but an error states incorrect cartridge can anyone help.
Aug 03, 2008 | Lexmark X3550 All-In-One Printer
Lexmark x3550
Changing print cartridges Changing print cartridges Removing a used print cartridge
  1. Make sure the printer is on.
  2. Lift the scanner unit.
    The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  3. Press down on the cartridge carrier lever to raise the cartridge carrier lid.
  4. Remove the used print cartridge.
Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge. Installing print cartridges
  1. If you are installing new print cartridges, remove the sticker and tape from the back and bottom of the cartridges.
    cartridge_tape_remove_one_2.jpg Warning: Do not touch the gold contact area on the back or the metal nozzles on the bottom of the cartridges.
  2. Press down on the cartridge carrier levers to raise the cartridge carrier lids.
  3. Insert the black cartridge or the photo cartridge in the left carrier. Insert the color cartridge in the right carrier.
  4. Close the lids.
  5. Close the scanner unit, making sure to keep your hands out from underneath the scanner unit.
    scanner_unit_close_2.jpg The control panel display will prompt you to load paper and press button_select_0.jpg to print an alignment page.
    Note: The scanner unit must be closed to start a new scan, print, copy, or fax job.
Jul 22, 2008 | Lexmark X3550 All-In-One Printer
Lexmark X3550 All-In-One Printer Logo
188 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
