Question about Behringer NU6000 - iNuke NU6000
Not powering on
Standby mode only ,notpowering on
Define "standby" mode.
The standby mode is a power saving feature. In this mode, a it does not shut down completely, just goes to low power state and so it consumes less power. When it resumes from the standby mode, full power is restored.. During the standby mode, if the power supply is disconnected or interrupted, data might be lost.
Hope this helps,
Lucas
Jul 08, 2011 | Uniden CEZAI998 Phone
I just cleaned the keyboard of my IBM T30 after that it did notpower on anymore ;-(
Try removing the battery and plug in the power adapter and switch on the power. Now try switching on the Laptop and see whether its powering on. if it is , then clean the battery contacts and put it back again.
Apr 18, 2011 | IBM ThinkPad T30 2366 Notebook
Compaq nx5000 PC Notebook: my compaq nx5000 is notpowering up when i power it...
First check to ensure the battery is properly seated. If it's in good, then this is probably a power supply issue or a problem with the motherboard.
May 06, 2010 | HP Compaq nx5000 Notebook
Standby mode
There are three modes — standby mode, radio mode or CD mode. To enter CD mode, press the power button and then the CD button. To enter radio mode, press the power button and then the radio button. To enter standby mode, press the power button.
If you're in standby mode and press the time set button, the clock digits will blink. If they don't blink, you aren't in standby mode.
Dec 28, 2008 | TruTech Clock Radio
How do I get to standby mode?
Laptop will notpower on.
remoe the battery for a half hour then try it again
hope this helps
Dec 27, 2008 | Computers & Internet
Kenwood KDC-138 Standby Question
Standby mode does not completely power down the unit it jsut does not draw as much power as when the unit is on. Also, depending on the unit, it might start back up faster in standby then from power off. You can select to have certain things displayed while in standby mode. Here is what can be selected for this unit:
Standby: displays CD loaded indicator, "STBY" indicator, and clock (when selected)
Hope this was helpful.
Oct 29, 2008 | Kenwood KDC-138 FM / AM Receiver
Black Screen / Computer Stays in Standby Mode
Completely remove the battery and unplug the power cord for a few minutes. Reinsert battery and power up. You can also hit F8 when starting and see if you can boot into safe mode.
Sep 06, 2007 | HP Compaq Presario V2000 Notebook
DVD player stuck in standby mode
Bad caps in the power supply is causing this. C17 (10v,470uf), C17,c14 (10v,1000uf) and C18 (10v,470uf). Replace with same capacitance values but 25 volt rating 85 C. Just fixed mine half hour ago works great.
May 27, 2007 | Onkyo DV-CP500 Multi-disc DVD Player
Behringer NU6000 - iNuke NU6000 Logo
15 people viewed this question
Top Behringer Computers & Internet Experts
Seanzilla
Brett Duxbury
Brett Duxbury
Steve
Steve
Are you a Behringer Computer and Internet Expert? Answer questions, earn points and help others
