Question about Curtis Klu 7-inch Touch Screen Mobile Internet Device
How to charge my klu from the usb port - Curtis Klu 7-inch Touch Screen Mobile Internet Device
If the charging port for my zeiko 10 inch is broken,what other way can I charge
Some tablets have a charging port and a usb port. If your tablet is so equipped it should charge while connected to another computer by usb or to a usb charger.
If your tablet is only equipped with a usb port and that is broken, it will need a repair before the battery can be charged.
Jul 11, 2016 | Tablets & eReaders
My Klu tablet is running very slow, hangs for long periods, stops responding, on all sites, how can I sapped the function up?
Get rid of any 'junk' that you don't need.
If you get rid of 10% of your stored messages, pictures, apps, downloads, old files, etc and it speeds your tablet up 10% it will encourage you to go on
Feb 03, 2015 | Klu Tablets & eReaders
My CURTIS KLU LT7035J tablet only works when I have it plugged in. It won't charge and I have been trying to charge it for days ? Nothing in the manual on what to do...should I return it or is
Please ensure you are using the correct power adapter that came with the tablet. If it is the wrong voltage/amps then the charging function will protect itself. If it uses a micro USB end then try charging via a computer USB port using a USB to Micro USB cable. This should work and will possibly eliminate the Tablet from the diagnosis. DON'T try to make your own power solution from a combination of cables/adapters because it's potentially dangerous to both you and your tablet.
Dec 01, 2014 | Curtis Tablets & eReaders
My klu has a white screen with lines. can';t do anything with it
Just a question, does your Klu once fall down on the ground ?
If yes, you have to change the screen or repair it.
If no, try to make a hard reset of the Klu.
Thanks, Ciberax
Jul 10, 2014 | Curtis Klu 7-inch Touch Screen Mobile...
Games for klu
How do I get pandora radio or iheart radio on my klu tablet by curtis
Feb 18, 2013 | Curtis Klu 7-inch Touch Screen Mobile...
Open Questions:
See all Curtis Klu 7-inch Touch Screen Mobile Internet Questions
Curtis Klu 7-inch Touch Screen Mobile Internet Device Logo
23 people viewed this question
Top Curtis Tablets & eReaders Experts
Michael Harrier
barez
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Curtis Tablet and eReader Expert? Answer questions, earn points and help others
