Question about Garden
Husky 500 series power washer is overheating and no pressure
3 Suggested Answers
  • 553 Answers
SOURCE: Owner's manual for Husky #HU80432 pressure washer
If you can't find it under Tech Support, Manuals & Guides on this site you could go to: http://huskypowerwasher.com/manuals_specs.php
You can also call Husky at: 1-888-550-1606 from 8:00 AM to 4:30 PM Central time.
I hope this helps.
Posted on Mar 28, 2010
Testimonial: "thanks for the info. the # that I was referred to for manuals is - 866-340-3912."
SOURCE: My Husky pressure washer 2600 psi powered by a gcv
It sounds like the (RMW 2.2 G24) pump has gone out. Mine had this problem after about 6 hours of use. I was able to order a new pump for around $160.00, and then installed it myself. Go figure it was just out of warranty. I think my next pressure washer will be one with a professional pump as I was told the one on my husky is only rated for about 40 hours of use.
Posted on Aug 09, 2010
No pressure on my husky power washer 1650
Basic Issues As an electric-powered washer, a circuit overload may cause your Husky 1600 to shut down or prevent it from starting. In this case, check your home's electrical service panel for a tripped breaker or a blown fuse -- the 1600 requires a dedicated circuit rated at a minimum of 15 amps. To prevent a blown fuse, avoid using other large devices on the same circuit as your washer. If you use an extension cord, it must be rated at 15 amps as well. Before moving on to more complex troubleshooting measures, check the gun safety trigger and release the lock if your 1600's trigger will not move. Water Woes Releasing air from the pump serves as a simple fix for low-pressure water output; remove the wand and allow the washer to run as you depress the gun's trigger until the water output normalizes. If your water output seems to lack detergent, ensure that the clear tube is securely connected to the detergent nozzle. Likewise, check the connected water supply and make sure the faucet is fully open and that there are no kinks in the hose to ensure optimal pressure. Using a shorter garden hose makes for stronger pressure, as well -- Husky recommends a hose with a maximum length of 50 feet for a city water supply. Clearing Clogs If your Husky 1600's pressure seems lacking or its water flow is obstructed, clean the nozzle by removing the wand from the gun, clearing the nozzle hole of obstructions with a stiff wire and flushing the nozzle with clean water. Similarly, clean the washer's inner water screen, located behind the garden hose connector, by removing the screen and flushing it with water. This also corrects low or irregular pressure and may remedy a unit that does not stop releasing water when the trigger is released. Model HD1600 features a chemical solution reservoir with a similar screen; clean this screen in the same fashion if you experience chemical intake issues. More to Consider If your power washer issues go beyond troubleshooting basics, contact Husky's customer service department at 800-381-0999. Husky recommends contacting customer service when your 1600 has problems with its pump, bypass valve, discharge valve or manifold assembly, for instance. Because this series of powerwashers was originally offered around 2001 through 2008, Husky's one-year limited warranty no longer covers the cost of replacement parts or repairs.
Sponsored Links
Sep 29, 2016 | Garden
OWNERS MANUAL FOR HUSKY 2200PSI Q-45 SERIES PRESSURE WASHER
Ask Husky direct as it is not listed on their manuals page
Manuals for download Pages
Oct 02, 2015 | Garden
What kind of oil to ues on pump ona husky 2600 preassore washer
I use the SAE30 Non-detergent Mineral Pump oil as it is formulated for the high pressure pump.
Feb 28, 2015 | Homelite 308653009 Blackmax Husky Pressure...
Husky power washer won't stay on after I start it
low oil pressure switch faulty or oil level low, disconnect pressure switch then try.
May 14, 2014 | Homelite For Husky - Pressure Washer Pump...
Husky deckmate
Looks like it might be a faulty/sticking pressure sensor/switch on the pressure side of the unit.
Mar 10, 2014 | Garden
Anybody know how to remove the wheels on a Husky 1750 power washer?
where does the link-mechanical gov. rod connect to the carburetor on the craftsman pressure washer number 919.762350.
Sep 28, 2013 | Dayton Wire Wheels Dayton Twin-Piston...
What is the maximum water temp my machine can take?
The manufacturers do not recommend more than 120deg inlet temp. Overheating is a comon and serious problem for these high RPM direct drive pumps. Heat builds whenever the trigger gun is not pulled. Some pumps have special "hot pack" kits available, but even that maxs out at 160deg. Most real washers made for hot water, heat the water after the pump, not before. Special separate Hot Boxes are available for 2k or so.
Oct 18, 2012 | Honda Pressure Washer PSI 3000
My Husky pressure washer 2600 psi powered by a gcv 160 Honda. Engine starts no pressure other then from water source and soap is not being dispensed
Jul 10, 2010 | Garden
I hope this helps.
Mar 28, 2010 | Garden
Husky 1650 PSI power washer hose got brittle and broke.
If the $$ that you Husky Dealer is asking is to tall, try a garage that make brake hoses. Take the hose with you and many times they can remove your nozzle and install it on a new piece of hose. MAKE SURE that they understand that this hose is for a pressure washer...DO NOT use just any hose...it MUST be a high pressure rated hose.
Oct 07, 2009 | Garden
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
