Question about Canon imageRUNNER 1310 Copier
Check toner/drum crg of my canon ir1210 - Canon imageRUNNER 1310 Copier
5 Suggested Answers
muleskinner2
  • 270 Answers
SOURCE: I have a canon imagerunner 1630 had a paper jam
Before reinstalling the drum make sure the Developer unit is correctly attached to the drum unit. The two clips ( Blue slides on top ) keep the two items together. Canon had two screws that were to added make sure the two stay together when removing the drum. Anyway make sure the drum is squarely installed with you insuring the rear is pushed all the way down. The sensor is located below drum near the entrance to the fuser. Good Luck
Posted on Apr 07, 2009
  • 114 Answers
SOURCE: 'check toner/drum crg' error, Cannon imagerunner 1370f
check the contacts inside of copier cavity where they line up with drum unit and make sure they are in correct position.
Posted on Mar 21, 2010
  • 254 Answers
SOURCE: my copier was working just
hello
remove the paper jam and close the front cover and unplug the power from the outlet and same at the back of the printer, wait for 5 minutes and plug it again. this will helps to clear the error code of the printer.
thank you
Posted on Mar 08, 2011
  • 3 Answers
SOURCE: Check Toner/Drum CRG I Replaced Both
Sounds like you need to reset your counters.
Check these areas on your printer to see if you can locate them.
To select events that will raise alarms:
1. In the navigation pane, expand the Canon Devices node and the Configuration
node, and click Alarm Management.
2. Select the check box for each type of information you want alarms generated for.
3. Click Apply.
Specifying Rates and Timeouts
To set rate and timeout values:
node, and click Rates and Timeouts.
2. In the Discovery Refresh Rate list, click how often the client should refresh the
navigation pane's list of discovered devices.
3. In the Alarm Poll Rate list, click how often the client should poll for alarms.
Posted on Apr 01, 2011
Printing black
is the copy/print full black or have streaks or have dots, or ...
First, remove the toner crg., and check the drum surface if it has toner leftovers or spots or streaks, or... if so replace the toner crg.
btw. It also can be the fixing unit, but if these is the problem then the toner will not be "baked" on paper and it can be wide solid black stripe on corner.
Hope that helps!
Jan 10, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
Dark copies
First remove toner crg and check the drum, if its covered with stripes or toner, replace toner crg.
It also could be fixing film fault.
Nov 16, 2010 | Canon imageCLASS D320 Digital Copier
Canon Super G3 Laser Classs310 all in one. Has lines in copies and when receiving faxes and sending faxes. How do I resolve this problem?
Check toner crg. if there are streakes on drum change toner crg.
If not there is problem with fixing system.
Jun 07, 2010 | Canon Office Equipment & Supplies
Why do I have a black line on my copies? I have the Canon imageClass D480 Multifunction copier
Pull out the toner crg., and if there are streaks on the drum, replace crg. If there is no streaks on the drum, clean the copy glasses.
May 22, 2010 | Canon imageCLASS D480 Black and White...
Mar 01, 2010 | Canon ImageRUNNER 1670F Copier
I have a canon imagerunner 1630 had a paper jam and had to pull drum to get it out, now can not get it back in correctly, display reads check toner/drum crg
Apr 06, 2009 | Canon imageRUNNER 1630 Copier
Light alarm on said check toner/drum crg
check the drum by opening the center of machine by a lever located in the middle of machine.
over flow toner container maybe full,
count how many light and how many colors
than type in prints name,make,model#, # of lights and what color of lights together in same sentance lie the followin here: example
canon inkjet goy000 6 green flashing lights
enter
rod
Feb 06, 2009 | Office Equipment & Supplies
Canon imageRUNNER 1310 Copier Logo
old marine
old marine
