Question about GE Profile Arctica Stainless Steel Top Freezer Refrigerator
Ice makes dispenses but water does not
Ps123SGNA BS
MNTECH
  • 1543 Answers
SOURCE: not cooling or freezing
When the compressor is running, both the fan inside the freezer and the fan down by the compressor should be running. If OK, look for frost on the back wall of the freezer, indicating a probable defrost heater failure. If yes, remove back metal cover in freezer, defrost with hair blower, replace defrost heater (the thing at the bottom of the freezer coils with two wires going to it)
If no to these, send me an "ask me" follow up question.
Posted on Aug 28, 2008
  • 111 Answers
SOURCE: GE GSS25LGM Ice maker not dispensing ice
You have one of three things wrong. The auger motor is frozen up, the ice bucket is broken or you need to dump out any ice, run warm water through the entire ice bucket, dry it out and try again with fresh cubes. My guess is the auger motor is frozen. You can buy a vinyl boot that covers the auger motor to prevent moisture buildup and freezing from GE Parts at 1-800-626-2002
Posted on Dec 16, 2008
SOURCE: GSS25LGMF WW Will not dispense ICE or Water, lights are on
If the water does not dispense, it may be that the water line is frozen in the refrig. section. The solution is to lower the temperature setting of the refrig sect a number or two.
If the ice bin is full and does not dispense, it is probably a bad or frozen auger motor. To test it open freezer door and remove the ice bin by sliding it out. Then hold the door switch while you press the dispenser lever on the outside of the door. You should see the motor turn in the back of the fridge. If nothing happens, it should be replaced. If it just hums, it may be frozen. In that case, wait till the freezer finishes defrosting and test again.
Posted on Mar 02, 2009
aasc
  • 1606 Answers
SOURCE: I have a GE model GSL22JFPH BS refridgerater and
Then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . There is a heater for the water dispensor tube , pt # WR49X10173 , which should keep this from happening again .
Posted on Nov 19, 2009
  • 106 Answers
SOURCE: GE GSL25IGRE BS slow water dispenser
Sounds like your water valve may need changing, and has filled up with sediment, slowing the water flow.
Posted on Mar 29, 2010
Ge profile arctica model #ps123sgna bs, leaking water from fresh food side?
Plugged or frozen drain pan located under the evaporator (cooling coil), located in the freezer.
Aug 31, 2014 | GE Profile PSW26P Stainless Steel Side by...
GE Profile Arctica PS123SGNA every fall the water dispenser stops working although the ice maker continues to work. Any ideas??
Strange, obviously the colder days dont effect the ice harvest so water is still coming in, has to be the water dispenser itself or the water filter may be freezing up stopping the flow.
Nov 24, 2013 | Refrigerators
We have a GE profile ps123sgna bs side by side that is around 10 years old. Niether side is staying cold enough and frost is accumulating in the freezer. Does this model have a defrost timer? If so,...
The defrost timer is part of the control board. If the unit is not defrosting, you will need to replace the board. Here is the part to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 10, 2012 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Mar 29, 2010 | GE Profile Arctica Stainless Steel Top...
Nov 18, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Frig GSL22JFTA BS
If you get water at the bottom of the door then something is blocking it between there and the dispenser. Usually ice. Leave the door open and cover the freezer opening with a blanket to keep freezer cold.It should thaw in 156 or 20 minutes.
Oct 08, 2009 | Refrigerators
Water Filter Freezes
The filter is building up ans excess of water. When this waters freezes it expands and breaks the filter. Do you have a way to extend tubin, and install filter on the outside of unit?
Jul 20, 2009 | GE Profile Arctica 25.4 Cubic Feet...
GE Profile Arctica Stainless Steel Top Freezer Refrigerator Logo
13 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
