Question about Microwave Ovens
LG Washing machine Model WM1832CW - LE error - Microwave Ovens
  • Microwave Ovens Master
  • 13,433 Answers
another user has fixed the problem in the following way as shown on this page:
http://www.fixya.com/support/t1235898-lg_washing_machine_model_wm1832cw
"I called Sear's to fix it. The tech just removed and reconnect all cables on the Printed circuit board.
It is now working fine. So, probably some corrosion on connector pins on the board.,, LE error is gone!!!
Next time it does it again, I will use a "light" sandpaper to clean allexternal pins on the Printed circuit board. I suspect corrosion on asensor pin...
I was surprised to see how well the machine is made!!! Even If I hadthat problem, I woul propably buy that type again.... At least fornow...."
Theres another suggestion from another person as follows:
"error LE Overload in motor.unplug for 1 hour plug back in. motors going bad or over loaded with stuff"
Here is the service manual for your washer
http://136.166.4.200/contents/Laundry/WM1832/WM1832xx_Service_Manual.pdf
You will need a pdf reader to open the file, if you don't have one or you can't open the document get one from here: http://get.adobe.com/reader/
The service manual says the following about the LE error:
I think you will be able to solve the problem with these tips and the quidance of the service manual.
Thanks,
Ekse
Posted on Jun 19, 2009
What is error code E-10 on a LG microwave oven, model MC- 7646UQ
This usually means a defective control circuit board.
Contact manufacturer for help.
Jun 27, 2017 | LG Microwave Ovens
Symbol ol a key will not allow a wash cycle
This indicates that the DOOR SWITCH is faulty and is not contacting without which the machine will not start off as it encounters an error for safety.
You can remove the door switch clean and reset it or else replacement is the best option.
Check this link:
http://www.espares.co.uk/advice/washing-machines/a/7/1294/how-to-open-a-washing-machine-door-thats-stuc.html
Sep 23, 2011 | Microwave Ovens
Microwave ne se rechauffe pas
Premierement, assurez vous que le niveau de pouvoir est sur le maximum (10).
Si ca n'est pas le probleme, vous probablement aurez besoin d'un micro-onde nouveau.
Il y a un parti a l'interieur appeler le Magnetron qui ne fonctionne plus. Avec le cout de travaille, remplacement de cette parti peu couter jusqu'autant q'un nouveau machine complet.
Si votre machine est presque nouveau, contactez le magasin ou vous l'avez acheter, et demandez un retour ou echange.
Outrement vous devez acheter un nouveau. Essayez de faire un peu de recherche sur l'internet avant d'acheter un autre. Le modele que vous avez a recu beaucoup de plaintes de mauvais qualite.
http://www.reviewcentre.com/reviews126097.html
Desole de vous donner les mauvais nouvelles.
Merci et bonne chance.
May 12, 2011 | Neff H5430 Convection Microwave Oven
What does PF mean on my LG washing machine?
According to lg PF code signifies that your washing machine has experienced a power failure,
Mar 17, 2011 | LG Microwave Ovens
I have a LG Dishwasher that keep displaying and "e" error signal can you tell me what is wrong
Have you checked the water inlet? If the water doesn't enter the machine quickly enough and error 1E will show.
Hope that helps.
Mar 06, 2011 | Microwave Ovens
Le moteur de mon aspirateur duo vac model 3200 refuse de démarrer, cette aspirateur à plus de 10 ans et a toujours fonctioné, La semaine dernière le moteur a...
Bonjour M. Grenier, le probleme ce situe dans la carte électronique de votre aspirateur central Duo Vac. C'est probablement le relais qui est défectueux. Il peut rester en position ''on'' ou autant en position ''off'' lorsqu il devient capricieux. Contactez nous au www.aspirateursenligne.com pour des renseignements et les pièces
Bonne chance
Nov 16, 2010 | Microwave Ovens
Le Gourmet Chef Pasta Machine user manual
Go to this web page and they can tell you where to find it on there online web page but we need the model number to get the correct one. You can e-mail or call or do a live chat. http://www.appliancepartspros.com/
Thanks for using fix-ya.com
Aug 22, 2010 | Microwave Ovens
I have an error code on my new LG LDF 6920st dishwasher. It runs for about 10 minutes and then dings and flasher LE
I would suggest calling the seller or distributor and having this unit replaced.
This error is not part of the consumer repair area and should only be done in A workshop here are two preevious ownrs experiences
1)
LE ERROR CODE
YOUR MOTOR RING CAME APRAT
THE UNIT EMPTIES AND REFILLS AND STOPS AT WHEN IT TRYS TO WASH I had to take the unit apart from the inside to comferm the motor is stuck. remove the racks the spinner in the bottom, the screen assy (1 foot in dia.) the wheel of pump with left hand threads, make sure it is unplugged, try to spin the garbage disspser blade. if it has trouble spinning then, pull out dish washer unit and flip over and remove the cover on botom and the motor and ground wire. good luck. i have had to replace mine twice now!
2)
I had the same problem and was told it was the motor. Well, it wasn't the motor. Take the front panel off & look at the wiring harness. There was a wire broken, not to mention the insulation was in the wrong place. It should be between the inside wall (dishwasher tub) and the wiring harness this way the wires wont get hot and break. Simple fix but, I would have never thought to take the door apart.
This unit is under warranty and should be attended to by the technicla support. LG are not good quality at any time, now made in Korea as cheaply as possible.
Please rate my help++++Thanks for using FIXYA
Nov 16, 2009 | Microwave Ovens
Bought an Intellowave Microwave a couple of years ago and the 'white' paint under the glass plate has come off. I always buy LG products as I have a 106cm TV,had a 68 cm TV but wanted to upgrade for the...
Normally this is due to spills, excess moisture or insufficient ventilation.
The chipped area should be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Aug 18, 2008 | LG Microwave Ovens
Microwave Ovens Logo
61 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
