Question about Kocaso SX9701 Android 4.0 9.7" Tablet PC - IPS Capacitive Touch,
When command do I need to reset? - Kocaso SX9701 Android 4.0 9.7" Tablet PC - IPS Capacitive Touch,
  • Kocaso Master
  • 2,219 Answers
You can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it.
Support Troubleshooting Guide
Posted on Feb 22, 2015
How to factory rest ipad mini with out using the apple I'd or password
Connect it to a computer with iTunes. Set up your own Apple ID and Password. Then Reset the iPad.
You can also do it from the iPad itself Settings - General and at the very bottom command RESET.
After the reset you will be able to set it up from new.
Please note that the RESET command clears EVERYTHING off the device.
May 08, 2016 | Apple iPad Mini
I can't get my trio AXS tablet to get off of No Command and Now send package.
Remove the battery from your phone/tab in order to get it to power off or shut down first.
Next, perform a hard reset on
Press at the same time any of these combinations
Power on + volume up button
Or
Power on + volume down button
Follow the menu prompt to reset your phone/tab
Where no command and the android logo on its back and with its tummy opened is still displayed, attempt to press any of these buttons/keys
Home button alone
Or Volume down button alone
or Volume up button alone
Attempt is to call out the hard reset command prompt
Give these tips/steps several tries.
If all else fails to work, you may have to flash stock ROM firmware of your phone/tab
Oct 14, 2017 | Tablets & eReaders
I can not reset my tablet to factory reset no matter how many times it will not work
Hello, today I will show you how to fix stuck on android or remove password, for model SC-91JB - SC-74JB
First, connect your tablet to PC.
you need drivers to be able to reset;
download the adb drivers from website;
www.adbdriver.com/downloads/
or click on link below for direct download.
ADB Driver Installer (9.22 MB)
next, install the ADB driver then you will see a USB root on notification area on your PC.
not-reset-tablet-factory-reset-no-matter-ov0hda1oylwbkzivvosqeagh-5-0.jpg next, download the fastboot click on link below;
https://www.dropbox.com/s/adu0ysny2191kgd/Fastboot.zip?dl=0
install fastboot and you will open a dialog box.
Follow the steps on image below; step one, two and three...
not-reset-tablet-factory-reset-no-matter-ov0hda1oylwbkzivvosqeagh-5-2.jpg next, command prompt will open and you need to type these commands;
not-reset-tablet-factory-reset-no-matter-ov0hda1oylwbkzivvosqeagh-5-5.jpg This will reboot and erase password.
If stuck on Android; type commands below (it's the same way like on top image just shorter commands).
> adb devices
> adb shell
> wipe data
> adb reboot
> exit
that is all; your tablet will be completely restored...
thanks and good luck.
Jan 26, 2016 | Supersonic SC-91JB 9-inch Android 4.1...
My Nextbook model NX785QC8G freezes when you turn it on. How do I reset it to the factory settings? I have looked, but have not found a reset button.
Check http://support.nextbookusa.com/support/index.php?/Knowledgebase/Article/View/84/0/reset-instructions-for-nx785qc8g.
1. Hold down the Volume (+) and the Power button at the same time, until you see No Command on your screen. (The tablet will act like it's going to turn on and go black, continue to hold your buttons until No Command shows up on your screen)
2. Release your buttons when you see the No Command appear on your screen.
3. Tap the Volume (+) once, and a blue menu will appear on your screen.
4. You will use the Volume (-) to navigate and the Power to select. Tap theVolume (-) until you highlight "Wipe Data Factory Reset"
4. Press your Power button to select it.
5. You will see a list of "No's" and one "Yes." Use the Volume (-) to go to the onlyYES on your screen.
6. Press your Power button to select the Yes.
7. This will prompt your tablet to go through the motions of resetting itself. When you see the words ''Wipe Data Complete", tap your Power button once to selectReboot System Now.
8. Your tablet will power off and power back up on its own; this will take a little longer than normal, so give it a couple minutes before it boots.
Dec 29, 2015 | Nextbook Tablets & eReaders
When i turn kocaso tablet on it say no command.
You probably need a factory reset.......go here and download the reset program just follow the instructions
http://register.kocaso.com/firmware.html
Jun 05, 2015 | Kocaso M M9100 9-Inch 8 GB Tablet
My tablet is stuck on a no command screen, whaat to do?
You need to hard reset your device
reset.
follow this procedure.
1. switch the tab off. after,
2. long press power button +
volume down key simultaneously.
3. after it shows the logo then
release the power button but
continue pressing the volume key
until the wipe or reset menu
appears.
after that you can reset/wipe it.
May 23, 2015 | Tablets & eReaders
How to hard reset my supersonic tablet
www.adbdriver.com/downloads/or click on link below for direct download.
ADB Driver Installer (9.22 MB)next, install the ADB driver then you will see a USB root on notification area on your PC.
No comment next, download the fastboot click on link below;
> adb devices
> adb shell
> wipe data
> adb reboot
> exit
Jul 03, 2014 | Supersonic 7" Touch Screen MID Tablet
RCA 7 inch table says no command
You may have to reset it. let if charge for about 24hrs, 10hrs may work fine too and With the device turned off, press and hold the volume down button, and then briefly press the power button. - Wait for the screen with the three Android images to appear, and then release the volume down button. - Press volume down to select clear storage, and then press power. - Press volume up to start the factory reset.
Mar 03, 2014 | RCA 7 DUAL TABLET DVD SYSTEM
I tried reseting it cos it was telling me my firmware was corruped. after reset, i powered on and i came on! but the only screen that apper is the welcon screen and nothing more. so i treid hardreseting by...
So sorry to hear/read about this challenge you are having.
You've provided a few details to help you out; so also is it that you've probably left a few otter details out too.
First, the android logo which appears... is it lying on its back with its tummy open and a 'no command' writing also displayed?
Or is it simply the android logo ONLY.
In any case, once you do the hard reset and the android logo re-appears, try and pushing either the volume up or volume down button.
Next, check and see if it now displays the various command options on the screen.
Otherwise, when the android logo reappears, you can try press one of the following 'home button' or 'back button' or 'opened tabs button' and see if the reset menu/command options become displayed.
Oct 03, 2017 | PANDIGITAL Novel white
I have the MiTraveler 7D-1A Bought for the grandkids and they locked the screen . Now they cant ge back in. Need help unlocking the tablet. Please help
on the back of the unit there is a small hole that says "reset"....gently push a straight pin or anything that will fit in the hole. that resets the tablet.
Dec 24, 2012 | Tablets & eReaders
Kocaso SX9701 Android 4.0 9.7" Tablet PC - IPS Capacitive Touch, Logo
41 people viewed this question
Top Kocaso Tablets & eReaders Experts
CrisO
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Kocaso Tablet and eReader Expert? Answer questions, earn points and help others
