Mathsoft StudyWorks! Mathematics Deluxe 5.0 (11513) for PC Logo
Posted on Jun 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2x+4y=8 find x intercept and y intercept
0=1/2x+y find x intercept and y intercept
  • Anonymous Mar 14, 2014
    how do I get the y intercept from -2x+y=8
  • Anonymous Mar 26, 2014
    y-intercept form
Anonymous
Level 3:
President:
  • Master 948 Answers
  • Posted on Jun 19, 2009
Anonymous
Master
Level 3:
President:
Answers
948
Questions
Helped
418167
Points
3155
Have you graphed the equation? Are you asking someone to solve and give you the answer or tell you how to use your software?
Anonymous
Level 1:
  • Contributor 25 Answers
  • Posted on Jun 26, 2009
Anonymous
Contributor
Level 1:
Answers
25
Questions
Helped
63977
Points
83
Rewrite the equation in the form y=mx + b, where m is the slop and b is the y intercept. To find the x intercept just solve for x with y being 0. when you rewrite the equation you get 0=1/2(x) + Y, bring the y to the other side and now you have -y=1/2(x) now divide off the neg sign and you will end up with y= -1/2(x), notice there is no b in this equation so the y intercept is at 0, if you set x to zero (which is where the y intercept would be you get y=0) now set y =0 and you get 0=-1/2x divide off the -1/2 and you get x=0. So this line goes through the origin and the x and y intercepts are both zero. The slope of the line is -1/2 so it decrease going from left to right.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2484
Points
1) A car has a value of $25,000 when purchased. It depreciates at a rate of $1,500 per year for the first five years.
a) Write a function ff to approximate the value of the car for the years .
b) Use that function to find the value of the car at the end of three years.
a)the function is f(t)
Find the equations of circles passing through (1,-1),touching the lines 4x+3y+5=0 and 3x-4y-10=0
First, I graphed the lines and the point using Desmos.com.
I noticed that the two lines are perpendicular to each other and the point (1,-1) appears to be on the right side of the circle, on a line parallel to 3x -4y-10=0. The equation of this line is y= 3/4x - 1.75. The y-intercept is -1.75. Now we have two points on the opposite sides of the circle, (1, -1) and (0,-1.75). The midpoint formula will give you the centre of the circle and the distance formula will provide the radius.
Let me know if you have any questions.
Good luck.
Paul
Desmos Beautiful Free Math
Find the x- and y-intercepts and graph the equation plotting the intercepts. Please show all of your work. Submit your graph to the Dropbox.5x-4y=-10
Use the definitions of the intercepts.
x-intercepts (or zeros or roots) are the values of the independent variables that make the function equal to zero. To obtain an intercept set y=0 in equation : 5x=-10, mean x=-10/5=-2
y-intercept: value of y when x=0.
Just set x=0 in equaltion and solve for y
-4y=-10, gives y=5/2
And Sorry, I cannot enter the answer in the drop box.
1helpful
What is the y and x intercept of x+4y=4
x-intercept: set y=0, and find x=4
The intercept point on the x-axis is (4,0)
y-intercept: set x=0, and find y=4/4=1
The intercept point on the y-axis is (0,1)
How do I use this calculator to find the x and y intercepts when the problem has both the x and y letters. it will not allow me to enter the full equation. example problem is 2x-5y=20 and I need to find...
x-intercept (or zero of the function)
Set y=0 in the equation and solve fo x: 2x-5(0)=20 and x=20/2=10
y-intercept (initial value)
Set x= 0 in the equation and solve for y: 2(0)-5y=20 and y=20/(-5)=-4
If the equation is in the slope-intercept form y=ax+b
1. y-intercept is b
2. To get the x-intercept ( zero of the function) Set y=0=ax+b, and x=-b/a
1helpful
2answers
2x - 4y = 20 4x + 2y = -20
This should start wit X=something and Y=something, sorry I'm not an human algebra calculator....
Can i ask how to answer this?2x-4y-9=o
That is an equation describing a straight line. The "slope-intercept" form of a line is
y = mx + b
where m is the slope (change in y-value / change in x-value)
and b is the y-intercept (the point where the line crosses the y-axis when x=0)
Positive slope means the line is rising and negative slope means it's falling.
You can rewrite the original equation 2x - 4y -9 = 0 in slope-intercept form:
y = (1/2)x - (9/4)
So you know the slope is positive 1/2 (line rises 1 y-unit for each 2 x-unit change) and crosses the y-axis at -9/4. With this information you can graph the line.
2answers
2X+4Y=-8
2x + 4y = -8 ; divide each side by 2
x + 2y = -4 ; subtract x from both sides
2y = -4 - x ; rearrange
2y = -1x -4 ; divide each side by 2
y = -1/2x - 2 ; relate to slope/intercept form of line (y=mx+b)
implies there are multiple solutions that fall along a line with slope -1/2 and y intercept of -2
Sample points on this line are (-4,0), (-2,-1), (0,-2), (2,-3)
8helpful
2answers
Why is the y-intercept of the graph of 4x+2y=12?
use the slope-intercept form to graph y=2/3x+4
2answers
How do I solve x and y in the following equations? 5x+3y=6 2x-4y=5 Thank you
You can solve it with following method.
5x+3y=6 2x-4y=5
So 5x=6-3y so 2[(6-3y)/5]-4y=5
So x=(6-3y)/5 so 12-6y-20y=25
so -26y=25-12
so -26y=13
so y= -(1/2)
2x-4y=5
so 2x=5+4y
so 2x=5+4(-1/2)
so 2x=(10-4)/2
so 2x=6/4
so x =3/2
The value of x=3/2 and value of y= -1/2
Let me know if you need further assistance.
Thanks for using FixYa.
2x-4y=8 simplify
2x-4y=8
=> 2[x-2y]=8
=> x-2y=8/2
=> x-2y=4
Top Mathsoft Computers & Internet Experts
k24674
Kolbrun...
 Mikey
Mikey
Are you a Mathsoft Computer and Internet Expert? Answer questions, earn points and help others
