Question about LG Electronic Window Air Conditioner
LG Turbo cool compressor not turning on - LG Electronic Window Air Conditioner
I have an LG freezer/refridgerator model # LMX28988ST-00 it does not freeze and the fridge compartment doe not get very cool. the compressor seems to be working. as I can feel it blowing cool air
Wellp.... that air you are feeling should be somewhat warm from the compressor 'compression action'...
Please don't discount a possible bad compressor from your list!
You should find the LINK below VERY helpful!
Anthony
LG Help Library Not Cooling Refrigerator LG
Dec 02, 2017 | LG Refrigerators
LG Express Cool Turbo GR T542G Stopped cooling
it should run when the comp is on and the unit is calling for cooling, you most likely need a new fan for your unit.
Aug 10, 2013 | Refrigerators
I have a Turbo Air TGF-49F freezer and it is not cooling. The compressor unit seems to work but when I turn the unit on all I hear is the compressor running continuously but nothing gets cold.
Difficult for you to check this I'm afraid, if the fan on the cooling unit is working unless you have an experienced 'ear' you will not hear the compressor running or worse still occasionally clicking.
Possible faults are
1. Compressor not running (the fan will run even if the compressor does not) electrical fault
2. Compressor seized (consult your service guy) also true for the rest of these
3. Compressor not pumping
4. Refrigerant leak
Not much hope for a cheap repair
Apr 14, 2011 | Turboair 49 cu. ft. Upright Freezer...
Our LG Art cool Airconditioner displays the error code CH 21. The unit turns on BUT after about 5 minutes the unit turns its self off. Please Help
Inverter compressor run current high. Check compressor windings all equal 1 to 4 OhmsCheck to earth 50 MOhm minimum, check run current. If high, winding is weak. Solution: Replace compressor.
Jan 11, 2011 | LG LSC183VMA Split System Air Conditioner
Have an lg reverse cycle was sitting for 12 months. the fan works fine but cooling or heating is not working.when i first turned it on it took about 5 minutes then compressor kicked in once in got to...
I think, your compressor gets over heated due to condenser block-clean it. Less rpm fan speed. -Replace capacitor. 3.Check compressor running capacitor. If weak replace it. Helpful?
Dec 29, 2010 | LG Heat cool Window Air Conditioner
I have a 91 Holden rodeo with the isuzu 2.8 TD lump in it. which is drawing oil up through the compressor and subsequently through the turbo giving me plenty of interestingly coloured clouds following me...
The turbo is in need of an overhaul/replacement. The problem is that people do not let turbo charged engines idle for at least 5 minutes before turning them off. The engine oil is coolant for a turbo much like antifreeze is to an engine. Exhaust temperatures reach up to 1700 degrees F and if the turbo is not cooled down, it will cook the seal that keeps oil from entering the engine. Have a shop that is experienced with replacing turbos do the job and it will cost quite a bit. Always cool down your trubo and it will last lots longer.
Jul 20, 2009 | 1993 Isuzu Pickup
If you set the temp to 74 it will not cool down to that temp the compressor will kick off on eather the energy or regular mode lg model number lwhd1009r
compressor shuts down air is cool but unit does not stay long enough to cool lower the thermostat down little lower if the compressor starts up then bad thermostat
May 19, 2009 | LG Heat cool Window Air Conditioner
Compressor constantly on too hot to touch
hi have you cleaned the matrix best done by blowing with air but a soft brush can work,make sure that all the cooling vanes are clear
hope this helps ian
Jul 21, 2008 | LG LRTN22324 Top Freezer Refrigerator
LG GR-602TVF Top Freezer
turned out to be the compressor all fixed and working fine now
Feb 12, 2007 | LG LRTP1231W Top Freezer Refrigerator
LG Electronic Window Air Conditioner Logo
21 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
