Question about Nikon Office Equipment & Supplies
Batterie ran out how do you charge it
Do I need to buy a battery charger seperate
SOURCE: My blackjack wont charge
I did a hard reset because i was having the same problem with a new battery and a new charger. I took my sim card out first to prevent any possible data loss. then followed the following steps:
  1. Once the handset has rebooted to the Today Screen, enter the following code: *2767*3855#. The handset should display a message “Formatting- Please wait a moment”.
  2. The phone will reboot after the Full Reset as this is normal operation.
after i did that i plugged in the charger and it worked perfectly. this is the last step that you would do after updating the software on the BJ
Posted on Jul 11, 2008
SOURCE: Very little juice in freshly charged batteries
have you tried the batterys in any other tool?
you would also need to check the voltage of the batterys they should be at least 18 volts (19 prefered)
then if the batterys do not show charged you would need to make sure the battery charger is putting out voltage.
After that contact your closest Ryobi service center we would check that for free to let you know what you need, I am sure you local place would do the same.
Posted on Mar 20, 2009
  • 7 Answers
SOURCE: I have the Duracell small battery charger
it dont matter where but i prefer the first 2 slot
Posted on Jun 08, 2009
  • 32 Answers
SOURCE: batteries are charged disconnected and used seperate charger thet had 3/4 charge to start with push start button nothing wheels locked but when charger is plugged in controller lights light up showing
it sounds like dead cel in one of the batteries, try having batteries loaded tested.
Posted on Jul 13, 2009
eradiostore
  • 1654 Answers
SOURCE: Motorola CP040 charging time
The rapid rate charger WPLN41__ will typically charge a battery in 90-120 minutes. Your battery should be depleted or nearly depleted when you place it in the charging stand. Be certain your radio is always turned off, when charging an attached battery. The NiMH battery will generally go 12-16 hours on a charge when new. If you work an eight hour shift, you might see if the radio will go 2 days on a charge. Later as the battery ages, you will need to charge it nightly. (Think of putting it in the charger as putting it to bed at night.)
Rapid charging is necessary on NiMH and Li-Ion batteries. They require a "hotter" charger, a fast rate, to completely charge the battery. It will not harm this chemistry of battery. It is safe to leave the battery on the charger overnight, or for a weekend. We would not recommend leaving the battery on the charger longer periods of time, as that will age the battery and reduce its life.
(Sidenote: Frequent rapid charging will however reduce the life of a NiCD battery.)
Posted on Aug 12, 2009
General electric hq moviemaker cg 9908 how do i no if batterie is charging
On some chargers the light goes off when charged, read the manual it should tell you. On other chargers you guess or buy a smart charger.
May 25, 2014 | GE Cg 9808se Hq Vhs Movie Video System...
Looking how to charge the batterie on a Mountfield 1840h grass tractor please-no instructions manual, please help xxx
take the battery out of the mower
hook the charger up to the battery
when the charger shuts itself off you are done.
you may also just remove the wire from the positive battery post and charge the battery
while it stays in the mower.
you may well find you have a bad battery and you are wasting your time trying to charge it.
May 06, 2011 | Garden
Need direction on how to charge batteries not working by just plugging into wall help help please
it s possible that you have a chargement faul. look if your camera have works normaly befor the dischargement of the batterie.. you can buy with a chip price a charger on ebay. insert the exact model of your camera, and go on the international seller. in china you must wayth 3 weeks to have the item...but you can find a new charger, with 6-7 gbp it s possible to find battery and charger with 7- 8 gbp... so if the problem is that the camera dont charge. buy a external charger.. so you can charge the battery external out from the camera. regards paolo
Oct 10, 2010 | Cameras
I have an Alba MP2200BUK. I do not know how to recharge the battery.Do I need a seperate charger?
Yes you do, you can charge it via the USB plug on your pc or you'll need to buy a seperate charger to charge it independantly.
Sep 05, 2010 | Audio Players & Recorders
I have charged my camera but it will not stay on when turned on
you dont have explain exactly the problem.. if the problem turn on and off istantly this is shure a lens problem and you mst change the lens. if the camera turn on one two 3 minute and than turn off its probably that the camera dont charge the batterie. if the camera dont charge you can bypass the problem. you can buy on ebay a external charger for your batterie. if you search on ebay international seller you can find charger and batterie to a very good price. its possible to find two batterie and one charger to 10 sterl. so you have new batteries and a external charger. external charger is better as charge the battery in the camera. why i is nott so difficult that the batterie explode and ruine the camera. with a external charger this is not possible why you can ruine the charger that have a low cost but not the camera. i hope that i have help you. its possible that the camera dont charge its possible that the batterie dont mantain the charge.. its possible if the camera go on and go out directly that this is a lens error.. sorry foer my english
Aug 10, 2010 | Kodak EASYSHARE M1063 Digital Camera
When I turn on my camera, a notice of low battery comes on and it turns itself off, even thou the batteries are charged up.
are you shure that the batterie is charged. are you shure that the charger have not a problem and the batterie is not charged. the better is to find a new batterie to prove if the problem is in to the camera or in to the batterie. you can find on ebay international seller to a very god price new external charger and new batterie. i have see that any seller sell two batteries and one charger to 10 euro in usa or in china. look if one friend have the same batterie to prove the camera with another batterie.. if the camera makes the same problem this is a motherboard fault.
Aug 10, 2010 | Samsung Digimax S730 Digital Camera
Faulty devolt batterie
Try placing the battery in a freezer for six hours before trying to charge the battery and if this doesn't work find a friend with a working charger and make sure using that method that you don't just have a bad charger.
Jul 24, 2010 | Dewalt 12V XRP Battery Pack
My camera will not charge. I have just bought a new battery as I thought that was the problem, however it still won't hold any charge when it is plugged into the charging dock. What can I do?
this is probably a faulty of the camera charging system. if this was my camera i search on ebay international seller one external charger for your batterie type. you find in ebay 100 models of external charger, so you charge you batterie and the camera goes like new. you can find a new charger with one or twoo new batterie all togheter to 10 euro . this is the better system to not spend a high fixing sum.
ok?? it s not so important if the camera dont charge the important is that the camera goes perfectly. ciao paolo italy
Jun 01, 2010 | Casio Exilim EX-Z1200 Digital Camera
Aug 12, 2009 | Motorola Radio Communications
The batterie charger for my Casio Exilim EX-Z77 has a blinking red light instead of a continous red light when i try charging the batterie. also, it doesnt appear to be charging it at all. Left in in for...
The blinking light indicates a charging error. Try connecting a 9 volt battery to your camera battery. Sometimes if the battery has lost all charge, the charger doesn't recognize it properly.
Dec 05, 2008 | Cameras
21 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Doberman
Jerry Greenberg
Jerry Greenberg
Ric Donato
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
