Question about ViewSonic PJ558D DLP Projector
I can't focus my viewsonic pj558d
The lamp light is on amber, could that be causing it? I just bought this projector and i can't even read the menu options. thanks.
  • mchughbb3 Jun 19, 2009
    the clarity gets better when i move the projector closer to the screen.
    President:
  • 1,383 Answers
Yo uhave to reset all settings first.
Press power button for 10 seconds.
Alos remove batterry from it then refix it.
Reattch all connection to it.
If you need manual downlaod from here.
http://dl.owneriq.net/9/9ec73155-b5e4-469b-afbe-b38d475ab9ed.pdf
Posted on Jun 19, 2009
  • kishor
    kishor Jun 19, 2009
    set resolution to 1024*768 then it works fine.
Lamp light flashes amber without the lamp ever turning on, then projector shuts down in a minute or two
Based on what you're describing, it sounds like a failure in the lamp ballast itself. The projector will probably need to be sent for service.
If you have a spare lamp, that would be the first thing to try. However, if it isn't that, it is likely the ballast.
Mar 15, 2016 | ViewSonic PJ402D DLP Projector
Viewsonic PJ558D shuts off after a few seconds
Sounds like the ballast board for the lamp stopped working.
Nov 19, 2014 | ViewSonic PJ558D DLP Projector
Our ViewSonic PJ558 is emitting yellow light. The whole display is in yellow already. Please help.
If the yellow is perfectly uniform across the whole screen, then a processor problem may be present.
If the lamp is very old then this could be a problem.
Otherwise an optical part has deteriated due to overheating
Jul 26, 2011 | ViewSonic PJ558D DLP Projector
Are LED conversions coming for the older Projectors? I have a Viewsonic pj5558D. I need a new bulb, but would love to see if an LED version exists...
Not for a while yet. You'll need to use the "standard" lamp. Do not forget to reset the lamp timer when you change the lamp.
Aug 15, 2010 | ViewSonic PJ558D DLP Projector
AMber light blinks as soon as I turn it on then shuts off
As soon as you turn it on hold down the menu button until the lamp turns on.
Oct 13, 2009 | ViewSonic PJ402D DLP Projector
The projector start to turn on but the lamp led turns into amber blinking and then it shuts off
the lamp has reached the end of it's life. replace it and reset the lamp timer (through the menu).
Sep 02, 2009 | ViewSonic PJ506D DLP Projector
The lamp continues to flash red lights for power and lamp
I have the same problem as posted too, ordered 3 new lamps and they all still do the same thing. I`m starting to think its the projector that has a problem. Anyone got a solution other then keep buying new lamps and try getting it to work... I mean, after 3, how bad lucky can you be that they are all bad lamps...
Dec 04, 2008 | ViewSonic PJ500 Multimedia Projector
Lamp won't come on
Hi
Check the cables, try taking out lamp and put it back in. If all fails replace the lamp.
Hope this helps
Nov 15, 2008 | ViewSonic PJ556D DLP Projector
Both Temp and Lamp lights blink red
All you should need to do is go to the menu on the projector, and find the Filter Timer. Hit the right arrow to select the filter time, and then hold the rest button on the projector until you are prompted to confirm the reset. Hit menu to confirm and it should now reset the filter timer. Now cut the projector off and back on and the lights should stop blinking. I hope this helps.
May 23, 2008 | ViewSonic PJ551 Multimedia Projector
ViewSonic PJ558D DLP Projector Logo
132 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
