Question about Tascam DR-1 MP3 Player
Stuck on play can't power off - Tascam DR-1 MP3 Player
Have a Sony HVR M25U deck and put in a mini-dv tape and the tape played fine but not able to play, ffwd, rwd or stop. So I unplugged power cord on deck. Plugged power cord back in and now the tape is...
DO NOT , UNPLUG THE POWER CHORD, DO ONE THING SWITCH ON THE VTR AND THEN HAVE AN ALL PIN .. THEN RESET THE MACHINE ... WITH THAT PIN .. AND THEN PRESS EJECT ... YOUR TAPE WILL COME OUT ..
Jul 14, 2011 | Sony HVR-M25U HDV VCR
Display stuck on Play Mode
Try Power Resetting the Camera.
To Power Reset the Camera, First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
Jun 15, 2009 | Sony Cyber-Shot DSC-S50 Digital Camera
Disc stuck in deh-p7000r plays but wont eject
should be a small pin hole next to the disk tray, 2 or 3mm wide. Insert a pin and that should then cause the disk to be ejected.
Aug 25, 2017 | Pioneer DEH-P7000r
Sony HCDX1 STUCK IN DEMO MODE
I don't have a Sony HCDX1, so if this doesn't work, please do not rate me down.
Push the PLAY and STOP buttons (at the same time) and hold them for about ten seconds. This should get you out of DEMO mode.
Power the unit off, then back on. If the display now says LOCKED, then press the PLAY and STOP buttons (at the same time) again to unlock.
If this does work, please rate it Solved, so others can use this solution. Thanks!
Dec 23, 2008 | Sony DAV-X1 System
I have a new ds game stuck in the slot - please help
the pin is stuck down try powering the unit down and pulling it out by hand, dont use any tools.
then see if another game will click into place.
Dec 13, 2008 | Nintendo DS Console
Stuck minidisc
Turn the power off and back on at the mains. With the machine now in standby, press and hold the "Play Mode" and "Minidisc Play/Pause" buttons together. The machine will enter test mode and the disc should eject. Switch the power on and off again at the mains and the machine should be back to normal.
Oct 16, 2007 | Sony DHC-MD333 Shelf System
Tascam DR-1 MP3 Player Logo
13 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
