Question about Kohler K-6350-7 Avatar single-control pullout kitchen sink faucet with leve
Problem with removing the handle on k-6350_7
How do I get the handle off the k-6350_7 avatar kitchen faucet
  • 2976 Answers
SOURCE: one handle kitchen faucet leaks
There are "o" rings in the area where it is leaking. You can get them at almost every hardware chain. Clean everything well with scotchbrite ant put silicon grease on before you put it back together.
Posted on Feb 21, 2009
  • 2692 Answers
SOURCE: Delta single handle kitchen sink faucet
Tuen the stops off unsder the sink . Remove the alaen screw from the handle. Using a spanner wrinch or a needle nosed pliers spred apart unscrew the large nut that has two slots. Lift the whole assembly out. Take assembly to the plunmbign supply and match ius the kit that youy need with has two new rubber seals and two springs and maybe a new spanner nut. It also comes with the spanner wrench  and allen wrench  needed to renstall. Tip you may be able just to tighten the spanner nut(clockwise) and stop the leak w/o rebuilding it.
Posted on Apr 25, 2009
defadad
  • 351 Answers
SOURCE: Single Handle faucet broke on my Kohler kitchen
Is cheaper to replace the whole tap as the service kits cost almost as much as the tap to buy, I presume you are talking about a flick mixer tap (that is what they are called in australia)
Replacing them is reasonably easy, turn off water at the main out on the footpath turn the tap on to let the water run out, go under the sink with a couple of spanners or deep reach socket and undo the lines and the tap hold down nuts and remove, replace in reverse order
Posted on May 07, 2009
  • 25 Answers
SOURCE: how do I remove the handle from a Fairfax(R)
U have to get a handle puller from a plumbing supply store. My husband is a plumber. he says that's all u need to do!
Posted on Jan 04, 2010
  • 74 Answers
SOURCE: I have a Kohler single handle kitchen faucet. When
change the cartrige
Posted on Feb 22, 2010
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Tip
    How to remove Glacier Bay Lever Kitchen Faucet Handles
    To remove the lever handle from a Glacier Bay two-handle kitchen sink faucet: Insert a 2.5mm hex wrench into the small hole underneath the lever. Work the wrench into the small handle set screw.Turn the wrench and setscrew counterclockwise to loosen. Pull the Glacier Bay lever handle off the faucet stem. P.S. You do not need to remove the screw to take the handle off.
    on Oct 07, 2010 | Globe Union Glacier Bay 8 In Double Handle...
    How do i remove the stem from an Elkay kitchen faucet model # LK7124?
    Leaky Elkay single handle kitchen faucet - DoItYourself.com ...
    www.doityourself.com/.../292646-leaky-elkay-single-handle-kitchen-fau...
    Can I replace the cartridge (A54236R) from our single handle Elkay (LK-6360) kitchen faucet without removing it from the sink top? If so where is the secret inhex ...
    Jan 14, 2016 | Elkay Plumbing
    Leaking CA87681 moen kitchen faucet
    Throw a cloth over the cover to prevent scratching the finish and grab it with a large pair of channel locks and unscrew it.
    Nov 18, 2013 | Moen 7907 Chateau Two-Handle Kitchen...
    Cannot remove handle from kitchen faucet
    Im gona say look for a 1/8 allen screw under a cap or plug of some sort on top or front of handle. loosen or remove sc..sonetimes handle is on snug ,,,,.good luck ';';';;'
    Jul 21, 2011 | American Standard 4175.200.002 Colony...
    I"m removing and replacing a
    Since you are replacing the Delta Faucet Delta 470-BL-DST Signature Single Handle Pull-Out Kitchen Faucet With Spray faucet, bend the water supply lines out of the way, and then use a standard basin wrench to remove the nut.
    Jan 25, 2011 | Delta Faucet Delta 470-BL-DST Signature...
    How do you remove the tri handle?
    You just pull the handles straight off the faucet. There are no screws or bolts holding the handles. Only a friction guide attached to the faucet stem. You can see this guide in the Grohe Classic Kitchen/Bar Faucet 31.057.000 installation instructions.
    Dec 12, 2010 | Grohe Classic Kitchen/Bar Faucet ...
    Loss of pressure in kitchen faucet - Price Pfister
    Your problem is a simple one.
    1. Turn off water to faucet.
    2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
    3. Remove the handle to the faucet. (single handle only)
    4. If not a single handle then remove spout from faucet.
    5. If a single handle remove cap carefully and any loose parts.
    6. Gently turn spout side to side while lifting to remove.
    7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
    1. Remove this valve (which is a backflow preventer) and replace.
    2. Reassemble and test.
    Problem solved.
    Dec 04, 2008 | Price Pfister Marielle Kitchen Faucet with...
    Kohler K-6350-7 Avatar single-control pullout kitchen sink faucet with leve Logo
    77 people viewed this question
    Top Kohler Home Experts
    Donni Steen
    john h
    Tim Whalen
    Are you a Kohler Home Expert? Answer questions, earn points and help others
