Question about Nikon D3100 Digital Camera
D3100 says shutter disabled recharge battery but battery is charged
It won't let me change shutter speed
3 Suggested Answers
SOURCE: Shutter Disabled
i was quated £250 to replace a buckled shutter unit can this be done any cheaper
Posted on Jul 05, 2008
  • 48 Answers
SOURCE: my nikon d40 displays
A couple of things to try, and if these don't work you will probably need to have it serviced.
1. There is a reset button which may fix it. It's described on the first page of "Troubleshooting" in your manual. The camera diagrams at the front of your manual will help you find it, near the connector cover.
2. If it doesn't work after the reset button, pull the battery out and leave it out for two days, then put it back and try again.
Posted on Mar 02, 2009
My olympus camera won't charge properly
If the camera battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Apr 02, 2013 | Olympus 228230 Model VG-140 Digital...
My nikon D3100. when i scroll the Command dial for increasing the Shutter speed the Shutter number indicator did not move.
turn the other wheel increase your ISO or your speed or turn the wheel the other way put your camera in M for Manuel
Nov 01, 2012 | Nikon D3100 Digital Camera
My eclipse cld 4gb mp3player wont hold a charge
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 17, 2012 | Mach Speed Trio Eclipse 4GB CLD MP3 Purple...
Nikon D3100 shutter "problem"?
Are your pictures properly exposed and are they sharp or are your pictures degraded? Is that 1/3-second you describe a delay between the time you push the shutter release and the time the picture is taken or somthing else? Check to make sure you're in the proper shutter release mode (slider switch to right of the mode dial). Also, your self-timer may be turned on. Your camera allows you to set a 2 or 10 second delay from the menus. If it is set to 2 seconds and turned on, it might seem like a 1/3-second delay. If that doesn't help, you camera is covered by Nikon's warranty. Contact Nikon Service at 1-800-NIKON-US (1-800-645-6687) 9AM-8PM EST, Monday to Friday.
Aug 27, 2012 | Nikon D3100 Digital Camera
Nikon d3100 bran new battery wont finish charging !!
You have one of a few problems. Either your new battery is defective, which does occasionally happen, or there is a problem with your battery charger. The other possibility is that your camera has a problem; possibly a short circuit that is draining the battery. If you have a spare battery and it will take a charge, your new battery is probably bad.
May 17, 2012 | Nikon D3100 Digital Camera with 1855mm...
Nikon d40 low batt info but batt is full charged
sometime if the battery is dead it still shown fully charge on the charger, try change another battery or with new one.
Nov 07, 2011 | Nikon D40 Digital Camera with G-II 18-55mm...
My shutter is broken d3100 how much to fix it
I have the same problem. I just took it to a camera shop. Labor will run 185-200 and parts will be upward of 250.
Oct 29, 2011 | Nikon D3100 Digital Camera
Shutter Disabled
Jul 02, 2008 | Nikon D40x Digital Camera
Nikon D3100 Digital Camera Logo
16 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
