Question about True Refrigerators
RESET THE DEFROST TIME FOR TRUE GLASS CHILLER
2 Suggested Answers
SOURCE: Can i stop the defrost mode on my FR48 glass chiller?
Turn off power to unit for short time this will reset unit.
Posted on Sep 23, 2008
Why does my maytag mqf1656tew have ice build up on bottom shelf and where is the drain plug at. This is a frost free freezer
Frost Free means that it performs defrost cycles to keep the chiller plate or evaporator fins free of frost. Difficult to know where your frost is, but it can build up on anything this time of year. If your frost is on a part that provides the cooling, then it will need a service visit as the defrost timer is faulty.
Dec 11, 2016 | Maytag Refrigerators
Need a diagram of Goodman heat pump showing defrost relay area
Turn the power off to the heat pump and get a magnifying glass. There is probably only one board inside the outdoor unit anyway, but look closely through the magnifying glass and you should see a set of tiny needle size pins....maybe two rows of 4 parallel pins. There should be a black plastic jumper across a set of pins corresponding to the defrost length. Near those pins and written on the board there will be something relative to defrost duration. This is why you need the magnifying glass especially if you have any trouble with close up vision.
There is probably not a setting that is adjustable for the intervals between one defrost cycle and the next as they are typically initiated not on elapsed time, but on temperature of the outdoor coil providing input to the board that defrost is necessary.
Jan 08, 2015 | Goodman Manufacturing Goodman GPH1543M41...
Why does my t-24-gc glass chiller keep freezing up to the point the ice hits the fan?
Check the defrost timer. Turn the small slotted knob on the side with a screw driver until the unit turns off. this will force it into a defrost check the defrost heater strip if it is getting hot then replace the defrost timer if not then check with a volt meter to make sure your getting power to heat strip. If you are getting power to heat strip but it is not heating up then replace the heat strip. also before you force it into a defrost check the defrost termination switch with a meter make sure you have power going to it and through it. It will be mounted on the evaporator coil a round therm o disk with 2 wires on it should be a red and pink one. If you have power going to it and not through it then replace it. This cuts power to defrost time if it gets to hot at coil during defrost.
Nov 04, 2014 | True Glass Chiller T-24-GC
Display panel on fridge door display flashing from 4 to 7 and beeps 5 times.
the blast chiller fan has prob failed
also check the thermal fuse on the heating elements that are around the chiller elements {used to defrost the chiller section}
and if there is also one on the fan check it
the beeping is prob an error code
you can consult the manual or phone the makers support number
to get more info on the exact error detected
usually there is some reset error like hold in the button etc and power on then let it go
more any more appliances have this
and if you dont know to reset
even if the error is cleared the unit will remain in this error mode
till reset again check the manual
Jun 19, 2014 | Amana SXD524VW Side by Side Refrigerator
Tru mug chiller won't get cold
Is the compressor running? Is the condenser clean and the fan running? Is the fan inside running? Is there ice on the coil? Those are the first things I would check after I check to see that the plug has power and the temperature control is turned on.
Mar 29, 2014 | True Glass Chiller T-24-GC
Not going into defrost
Then it must be freezing up. If the compressor runs, and there is no defrost cycle at all, the defrost time is bad, if the timer advances to a defrost but still is iced up the heater is bad. Refrigerators are small and hard to get at some of the components.
I would rather work on a 200 ton chiller than a residential ref. but its just getting to the components that I say this.
Jun 30, 2011 | GE Refrigerators
When I got home I heard the buzzer going off on the freezer..the temperature had dropped from -12 to -2 and I'm trying to reset it to-12 again how do you do that?
You dont have to reset it, you need to defrost it, the defrost element has failed and you have ice build up within the chiller plates, air cant pass through it due to the ice, I think you will find that food is starting to defrost and you will see a bit of ice on the back panel inside the freezer.
Defrost it for 2 days with door open, after that, should work fine for a week or so, very common problem.
Hope that helps, Russ
Jun 29, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
True t49g side by side not defrosting
True's T-49G is not equipped with a defrost timer as it is a medium temp unit, so I would suspect the temperature control may be defective. Part #800393 is commonly used for the True T-49G, though it's best to check verify with model number and serial number. It could also be as simple as adjusting the temperature dial a little bit. The target temperature range is around 36 degrees Fahrenheit.
May 31, 2011 | True T-49G Glass Door Commercial...
I have a watercooler that freezes. Water will not come out of the spout because it is frozen inside the system. it is not the temperature gage on that back of the machine. I have experimented with that.
no its the thermostat in it thats running out of true,,it telling the chiller the water is still to hot so the chiller freezes it some more,,change the thermostat its packed up,,
Jun 11, 2010 | Microwave Ovens
Aug 04, 2008 | Perlick FR48 Commercial Refrigerator
Refrigerators Logo
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
