Jvc turntable la120
How to check if belt is attached or broken
4 Suggested Answers
djproaudio
  • 515 Answers
SOURCE: I need to put new turntable belt on a Technics SL-B200
The belt goes underneath the turntable platter. First you attach to the lip on the bottom of the turntable platter, then you put the platter on the turntable. You'll see some holes on the platter, after you put it on, just rotate the platter, until you see the motor shaft, then pinch the belt around the motor shaft.
- OPTiC
DIY Yourself DJ Repair Videos
DJ Equipment Sales
Posted on Jan 11, 2009
  • 15 Answers
SOURCE: JVC L-A10 Turntable won't turn on
there should be a fuse on the circuit board close to where the power cord connects, check to see if its good
Posted on Feb 03, 2009
  • 3 Answers
SOURCE: I have a JVC L-A11 turntable. I cannot get the
I just had my L-A11 in to 'the needle doctor' (Jerry Raskin's shop in dinkytown, Minneapolis) We had the same problem with the platter.
After pulling (hard) to no effect on the platter - using the holes near the spindle and pushing simultaneously on the spindle. The tech next got out a small hammer, and while pulling on those same holes in the platter, he gave it a sharp 'whack' on the spindle with the hammer, and it came right off (the platter). I would have been too feint of heart to do it, but it worked great.
Posted on Feb 23, 2010
How to remove Platter on JVC L-A120 Turntable
Hi Jeff...
The platter on the JVC LA-10 does not come off as most turntable platters do. It is attached to the spindle with a Philips head screw.
Here are the steps:
Remove dust cover from turntable. Unscrew hinges and lift.
00.jpg" alt="Remove dustcover at hinges.">Remove dustcover at hinges.
  • Secure tonearm to prevent stylus damage.
    00.jpg" alt="Secure the tonearm.">Secure the tonearm.
  • Remove slipmat from platter.
    00.jpg" alt="Remove slipmat.">Remove slipmat.
  • Turn the turntable on its side and remove screws that hold the top to its base. Remove platter by unscrewing the bottom plate from the turntable. The spindle bearing is held in place with a Philips head screw. Loosen it and the platter will separate easily from the spindle.
    00.jpg" alt="Separate the spindle from the platter by loosening with a Philips head screwdriver.">Separate the spindle from the platter by loosening with a Philips head screwdriver.
  • Loop replacement band around the pulley cylinder in the motor. Replace platter and bottom plate. Tighten spindle screw. Test the new belt by turning the platter clockwise two or three rotations. Belt should fit snugly and turn with little resistance.
    00.jpg" alt="Test the replacement belt by turning the platter clockwise.">Test the replacement belt by turning the platter clockwise.
  • Feb 05, 2016 | JVC Audio Players & Recorders
    Turntable not rotating. What should I do?
    HI, lift the platter off and check belt. If it is broken or stretched you will need to replace it. To test belt for over stretch simply place it on the platter pulley then flip platter over the right way up. If belt stays put it is ok, if it falls off it needs replacing. Keep em spinnin, John Stylus City.
    Jun 20, 2014 | JVC AL A158BK Turntable
    Turntable will not turn
    If you lift up the mat of the deck you should see a large whole in the platter. Rotate the platter by hand and you should see if the belt is attached or not. If broken then take out the remains of the belt and measure the diameter of the belt in mm. Put that into Google with the words "turntable drive belt" and you should find a match. You might also have to look up how it's fitted.
    Mar 23, 2014 | Audio Players & Recorders
    How to replace the belt on jvc l-f130 turntable
    You will have to lift the platter section off the unit itself. Check for the spindle motor turing the table and lay the belt out around the spindle motor. Refit the platter and work the belt around the inside of the platter through the two large holes in the tray.
    Nov 22, 2009 | JVC AL A158BK Turntable
    How to lift up the JVC L-a21 platter for changing the belt? Thank you in advance.
    I am not familiar with this exact turntable, but on most belt driven turntables, the platter should simply pop off. There are usually holes in the platter once you remove the rubber mat. Put your fingers in the holes and pull up while pressing down on the center spindle, and the platter should pop off. Sometimes you have to put on a little force to get it to come off.
    The holes in the platter are to allow you to attach the new belt to the motor spindle once you put the platter back on with the new belt.
    Jun 21, 2009 | JVC Audio Players & Recorders
    Table does no rotate
    If it is belt-driven the belt may be broken or fallen off.  Lift the turntable to check underneath.  There may be a spring clip near the center of the turntable that you have to remove to lift it.
    May 18, 2009 | Audio Players & Recorders
    Jvc turntable
    hi, please check first your fuse inside your turntable, replace it if possible
    Apr 04, 2009 | JVC AL A158BK Turntable
    Feb 03, 2009 | Audio Players & Recorders
    JVC L-A10 won't turn on
    the two issues are unrelated. a few turntables won't show life until the tonearm is moved over to the record area. at this point the motor should start turning wether it has a belt or not.
    Feb 03, 2009 | JVC TH-A10 System
    - OPTiC
    DJ Equipment Sales
    Jan 01, 2009 | Technics SL-1210 Turntable
     Grubhead
    Grubhead
