Question about Hardware & Accessories
Where are the pins to set time on 052-8808-8 - Hardware & Accessories
Pin for start up
if you never set up a pin then when ask for one just leave blank and press enter and see what happens if that does not work that means that someone else has set up one and you will have to take it in and have it reset
Dec 28, 2013 | RCA Tablets & eReaders
Turn off alarm without key fob
First off, you need to know the PIN.
Setting the PIN is as follows:
Think of a five-digit PIN, and write it down. Think of this set of numbers as a password for starting your bike and disabling the alarm during those times when you don't have your fob.
Turn the ignition key on, then off, then on, then off, then on again. Then press the left turn-signal switch twice. Press the right turn-signal switch once, and the current PIN should appear in your odometer.
Be sure the first digit of the PIN is flashing. Enter the first digit of your new PIN by pressing the left turn signal to cycle through the numbers.
Press the right turn signal once to switch to the second digit, and select the correct number with the left turn signal. Repeat this process until your new PIN is entered correctly.
Press the right turn signal once, then turn the ignition key off to save the PIN you selected.
Now, how to disable:
Let's assume for simplicity that your code is set at 31313 and you wish to use the manual disarm of the security system using the directional switches as if you lost your fob and cannot disarm the system.
Your security system will disarm the bike and it cannot be started without deactivating the system first.
If you are unsure of what the manual code is refer to the top of this page or check with your dealer and set one if it has not been set by them.
Again this is based on your code being 31313 just to make it easier to understand.
1. Turn the ignition to Accessory.
2. Press both turn signals. (security light should flash rapidly)
3. Press left turn signal button 3 times (the 1st "3" of the PIN). Press right turn signal button 1 time (to "set" the code number).
4. Press left turn signal button 1 time (2nd number of PIN). Press right turn signal button 1 time.
5. Press left turn signal button 3 times. Press right turn signal button 1 time.
6. Press left turn signal button 1 time. Press right turn signal button 1 time.
7. Press left turn signal button 3 times. Press right turn signal button 1 time.
Security light stops flashing and security system is disarmed.
If you've changed the number, use your new number instead of 31313.
Dec 25, 2013 | Harley Davidson Motorcycles
Keyless garage entry pad 53754 (315mHz) need to program a temparay passcode, how do I do this? thank you
1. Press the four buttons for your personal entry PIN, then press and hold the * button. The opener light will blink three times. Release the button.
2. Press the temporary 4 digit PIN you have chosen, then press ENTER. The opener will blink four times.
3. To set the number of hours this temporary PIN will work, press the number of hours (up to 255), then press *.
OR
3. To set the number of times this temporary PIN will work, press the number of time (up to 255), then press #. The opener light will blink once when the temporary PIN has been learned.
Test by pressing the four buttons for the temporary PIN, then press Enter. The door should move. If the temporary PIN was set to a certain number of openings, remember that the test has used up one opening. To clear the temporary password, repeat steps 1-3, setting the number of hours or times to 0 in step 3.
Jun 28, 2011 | Sears Craftsman LiftMaster Chamberlain...
WHERE CAN I FIND DIRECTIONS TO PROGRAM TIMER #0148373
Open following link to correctly identify product:
http://cgi.ebay.it/UTILITECH-2-OUTLET-TIMER-0148373-15-AMP-LOT-OF-4-/290468257053
Utilitec 0148373 timer is plug-in type timer.
Set on-off times by moving pins.
Pins are located on dial and stick up. They can be moved back and forth like stick-shift on car.
See example of pins at following link:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Pins-tabs
Instructions:
Turn ON lamp.
Light bulb is good.
Plug lamp into timer.
Plug timer into outlet.
Move some pins outward.
Then manually rotate dial clockwise to watch how lights turn on-off.
That will tell you if lights turn on or off when pins are set outward.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial turns as time passes.
Lever on top of timer is moved to 'Timer'
Dec 19, 2010 | Hardware & Accessories
How do you program a Tork 602A timer? I can't get mine to cycle on and off at a desired time.
The Tork 602A mechanical outdoor timer with 2 grounded outlets.
Tork 601A and 602A manual
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Manual has images of timer that will help.
Plug timer into outdoor outlet.
Dial is divided into light and dark sections that represent day or nighttime hours.
Reset time after power outage.
96 pins located around timer dial are used to set on-off times.
Each pin represents 15 minutes in 24 hour day
Move pins in-or-out with fingernail or ink pen to set timer on-off functions.
With Tork timers, usually when pins are out, timer is ON.
When pins are in, timer is OFF.
To double-check pin setting, manually rotate timer to watch when lights turn on-off.
Set multiple ON/OFFs each day.
Change on-off times by resetting a pin or two.
Timer repeats every 24-hours.
Manual ON/TIMER switch is located on inner dial.
Set Manual switch to TIMER for programs to operate.
To override time and turn on Load, move override to ON position.
Dec 09, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
How to set a GE outdoor timer product ID 51587 ?
GE 51587 has same instructions as Tork 601A single-outlet outdoor 24-hour mechanical timer.
Move pins in-or-out with fingernail or pen to set timer on-off functions.
With GE timers, usually when pins are out, timer is ON.
Manual ON/TIMER switch located on inner dial.
Set override to timer for program to operate.
Dec 06, 2010 | GE 51587 MultiEvent Timer
My wrist watch has been in a drawer for over a year. I want to wear it now. the time shows 6;13 and the date shows 8: 16. It is running correctly. How do I set it foe the correct time and date?
First you need to unscrew the crown (setting knob) of the watch. Turn dial from up to down (downwards), you will feel the knob loosen and then it will pop out gently.
Pull out the pin very gently and turn downwards to set the date. If you have a Day and Date watch, turn upwards to set the day of the week.
To set the time, pull the pin out futher and turn to set the appropriate time.
Finally push pin in and simultaneously turn upwards to screw back the pin.
Please make sure you push turn the pin tightly because most cases of Water Damaged watches are caused due to the pin being screwed up not tight enough.
Aug 17, 2010 | Watches
Temporary passcode
Press the temporary 4-digit PIN you have chosen, then press Enter.
The opener light will blink four times.
To set the number of times this temporary PIN will work, press the number of times (up to 255), then press #.
Test by pressing the four buttons for the temporary PIN, then press enter. The door should move. If the temporary PIN was set to a certain number of openings, remember that the test has used up one opening. To clear the temporary password, repeat steps 1-3, setting the number of hours or times to 0 in step 3.
Oct 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Can't figure out how to set Intermatic timer 111c up to nightlight
Hello. I can help you with this times.
Step one - insert the pins at the times you want the night light to come on and go off. The green pins will turn on the night light and the red pins will turn it off. If you just want one on time and one off time just use one pin of each color.
After you have the pins inserted, set the correct time on the timer and plug it into an outlet that is always on [not one that is controlled by a wall switch].
The override switch will turn the device off if it is on, but just one time. As the next time it turns on it will once again be controlled by the times.
If ou want the night light to come on and off in the evening and again in the morninng, use two green pins and two red pins. Push in a green pin at each time where you want the night light to come on and push in a red pin at each time you want it to go off.
Get back if you need additional clarification.
Jun 02, 2009 | Intermatic & Lighted Dial Timer
Hardware & Accessories Logo
214 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
