Question about 1997-1998 Chevy Silverado RockerFlares 139 - Extra-Wide Fender Flares
Silverado 1997 remove fan
Remove fan
How do I remove a radiator in a 2000 Chevy Silverado 1500 pickup
Gasoline Engines
  1. Drain the cooling system.
  2. Unfasten the upper fan shroud bolts and remove the upper fan shroud.
  3. If equipped, remove the upper panel fasteners and the panel.
  4. If equipped, remove the upper insulators and brackets.
  5. Disconnect the radiator upper and lower hoses and, if applicable, the transmission coolant lines.
  6. Remove the coolant recovery system line, if so equipped.
  7. Remove the oil coolant lines, if equipped.
  8. Remove the lower fan shroud bolts and the lower fan shroud.
  9. Remove radiator from the lower brackets and insulators.
Jul 28, 2014 | 2000 Chevrolet Silverado 1500
How to remove oil pan in 2003 chevy silverado 2500 hd
You most certainly have to remove the motor mount bolts and jack up the engine to remove it. If exhaust passes under the pan you will need to remove it also.
Also unbolt the fan shroud as it has to move with the fan as you jack up the motor to clear the cross member.
Mar 15, 2013 | 2001 Chevrolet Silverado 1500
Fan speed 1&2 not working on my 2000 silverado. how do I fix it.
The switch itself is malfunctioning. Remove the fan switch. You will find that the switch is shorting and melting. It is a common problem. It's called the blower fan control switch.
Jul 17, 2010 | 2000 Chevrolet Silverado
1999 silverado fan switch only runs on speed3 and up how I fix this problem
Either your fan resistor pack needs changed or the fan switch itself.
The resistor simply unbolts from the blower box by two screws .
The switch, you must remove it from the dashboard.
Nov 13, 2009 | 1999 Chevrolet Silverado 1500
How to remove fan from water pump, '99 silverado 4.8
the is a special flat wrench and pulley holder to remove. there is also a wrench kit from lisle tool that make for use with an air hammer that works great. Note: the thred on the fan is right hand
Aug 01, 2009 | 1999 Chevrolet Silverado 1500
MY heater fan works on 4 & 5 Only on my 2000 Silverado
remove the passenger side lower insulator panel. behind the panel you wil find the blower motor housing. next to the blower motor housing there will be a wiring connector with 6 to 8 wires going in to it. the connector will be held secure with 2 screws. remove the connector and remove the screws -- this is your resistor. reverse the process to re-install.
Jul 21, 2009 | 2000 Chevrolet Silverado 1500
1997 chevy silverado 1500 350 vortech, new fule pump not working
before you drop tank again, check fuses & relay.then disconnect fuel line @ filter turn key to on position should hear fuel pump run and get gas stream out of line. if no flow from line new pump faulty be sure & remove negative battery cable first good luck.
Jun 04, 2009 | 1999 Chevrolet Silverado 1500
I have a 1997 Chevy Silverado. First gear doesnt work??
If trans fluid is full, it's shot. You could remove pan and check to see if filter is blocked but if fluid smells burned and there is a lot of debris in pan, don't bother with it...just get another one!
Feb 18, 2009 | 1997 Chevrolet K1500
1997-1998 Chevy Silverado RockerFlares 139 - Extra-Wide Fender Flares Logo
11 people viewed this question
Top CRE Loaded Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a CRE Loaded Vehicle Part and Accessory Expert? Answer questions, earn points and help others
