Question about Sport & Outdoor - Others
Need assembly instructions for Huffy U9h244 Fast
Need assembly instructions for Huffy U9h244 Fast Break Portable 44'' Basketball System
5 Suggested Answers
greenspan
  • 1734 Answers
SOURCE: Need English assembly instructions for Reebok
Hi, ask here, they have found already some hard-to-find Reebok manuals.
Posted on Aug 23, 2009
SOURCE: assembly instructions for portable basketball hoop
we put all three poles into one by mistake on our new portable hoop we managed to get the screw out but cannot get the poles apart help!
Posted on May 18, 2010
walesarumi
  • 6993 Answers
SOURCE: I have an old huffy
Follow the below assemble instruction as requested for your huffy sports basketball hoop;
Insert the mounting screws through the mounting holes of the backboard, then lay the backboard face down. Lay the mounting brackets on top of the backboard so the mounting screws of the backboard go through the mounting holes of the brackets. Tighten the screws with a wrench.
Insert the adjustment hardware between the brackets and insert the screws connecting to the brackets to the adjustment hardware, then add a nut to the screw and tighten with a wrench. These screws will be inserted horizontally through the brackets into the adjustment hardware. The adjustment hardware allows you to adjust the height of your basketball hoop.
Line up the holes of the rim to the holes of the backboard and install the rim screws through the rim into the backboard and secure them with a nut. Tighten the nut with a wrench. Thread the nut through the wire holes of the rim.
Assemble the pole. Dig a hole with a shovel where you want to install the basketball hoop. For the exact size of the hole, you will need to consult the directions on your Huffy basketball hoop. To achieve the regulation height of 10 feet, this step strongly depends on the size of the particular basketball pole and a specific measuring depth. Measure the hole with a tape measure for accuracy. Mix a bag of cement in a wheelbarrow with water. Consult the directions on the cement bag for exact mixing instructions.
Place the pole in the hole and shovel in the cement. Allow the cement to dry.
Use a ladder to reach up and connect the mounting arms to the mounting brackets and then to the top piece of the basketball pole. Each of mounting arms has a hole at the end that you need to line up to the mounting bracket and secure with a screw, add a nut and tighten with a wrench.
Line up the holes at the end of the two top arms to the top holes of the top of the basketball pole. Insert the long screw through the holes of the arms and pole, secure it with a nut and tighten it with a wrench. Install the bottom arms to the lower holes of the basketball pole.
I hope the above helps.....
Good luck.
Posted on Apr 03, 2011
jyackle5
  • 8197 Answers
SOURCE: hello I have a huffy
The only way to get a manual is to email Huffy on the link below.
http://www.huffysports.com/customer_support/installation.php
Posted on Jun 19, 2011
Should Spaulding 44" model # 77537T be filled with water or sand?
Hi, according to Amazon (see link below), that model can be filled with either water or sand. My only thought was that water would be much easier to remove than sand if you ever wanted to empty out the tank.
http://www.amazon.com/Spalding-77351-Portable-Basketball-System/dp/B0027HDIAI
Oct 26, 2013 | Lifetime 3819 Impact 44" Basketball...
Need replacement balls for a Huffy electronic
I have found the number for Huffy. You should be able to see if they have replacement balls for your electronic basketball game.
U.S. Customer Service
Email: service@huffysports.com
Phone: 1-262-820-3440
Phone: 1-800-558-5234
Fax: 1-262-820-6757
Thank you, hope this helps. Please let me know.
Apr 30, 2010 | Huffy Dual Electronic Basketball Game
Assembly instructions for portable basketball hoop
Sep 10, 2009 | Huffy Sport & Outdoor - Others
Sport & Outdoor - Others Logo
125 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
