Question about Salton MEX1B Espresso Machine
Head seal I need to buy a replacement
My question is if the piston seized up into the cylinder head do I need to replace the whole head or just buy a top end kit
The piston wont seize into the cylinder head it will seize into the cylinder and you will have to replace the piston the rings the cylinder. crankshaft bearings and seals and gaskets. maybe the cylinder head if it got hot enough to warp
Oct 18, 2015 | Motorcycles
Em6910 collar replace
The whole collar or do you just mean the blue silicone seal?
You can buy the blue seal on eBay. Simply undo the Philips screw in the centre of the 'shower' in the group head, take out the two shower screens and the blue seal will be fairly easy to remove.
May 09, 2014 | Sunbeam Cafe EM6910
My Rancilio Silvia won't pump water out of the head all of a sudden. It had worked for years up to this point
It may be that the 'shower screen' which is a perforated metal disk filter that fits inside the head has reached its use by date.
These can be found and bought on E-bay for about $15 each, make sure you buy a genuine Rancilio replacement, while you are at it, replace the rubber 'group seal' - a rubber ring for pressure sealing the head/arm after filling the arm with grounds - these are a similar price. If you get leaks around the head while making a coffee, the seal is worn out.
Jul 31, 2013 | Rancilio Silvia Espresso Machine
The black inl isn't printing out only the colour
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Dec 01, 2012 | Canon Sealed Pixma Mx870 All-in-one Inkjet...
I have a 2002 Nissan Altima 2.5L that is leaking oil into the spark plug tubes; can these seals be replaced or does the valve cover have to be replaced?
Yes, you need a Rocker cover (valve cover) Gasket kit. Remove the valve cover, remove all old O-rings and cover gasket, clean grooves and mating surfaces without gouging or scratching them, put the new gaskets on as per factory recommendations, tighten to the proper torque and you're done. The spark plug holes in the cover are part of the valve cover gasket kit. Any Napa, Car Quest, Pep Boys, Auto Zone will have it.
Oct 03, 2010 | 2002 Nissan Altima
Replace valve seals on a 1988 mitsubishi mighty
mcdevito75 here, That is a shop only job, the entire cylinder head has to come off and either a rebuilt installed or your old head is taken to the rebuilder, Most heads are made of Allumimum and extra care has to be taken removeing them from the engine, also you"d need a special tool to reove the valves from the head and another special tool to remove and replace the valve seals. Have the shop do this job.
Jun 17, 2010 | 1988 Mitsubishi Mighty Max
My honda wave 100 scooter produces white smokes especially when it runs for at least 5 kilometers
your honda wave is air cooled, it could be one of two things, valve seal or piston rings.
Jun 05, 2009 | 2005 Honda NF 100 Wave
Water in cylinder
The absolute "cheapest" fix is to go to your local auto parts store & buy a can of a product that is called "Block Seal" or something like that (terminology changes from region to region); tell the parts guy your problem & he will sell you the right stuff. Read & follow the directions. I cannot guarantee that it will work 100% (as we both have no way of knowing exactly how bad the situation is without disassembly), BUT, I have personally used "Block Seal" several times, and have had good results.
Try it. If it works, you will haved tons of $$$. If it does not work, you will need to pull the head & replace the head gasket. Hope this helps.
Oct 03, 2008 | 1994 Honda Accord
Salton MEX1B Espresso Machine Logo
15 people viewed this question
Top Salton Coffee Makers & Espresso Machines Experts
Angel Joseph Jr.
Angel Joseph Jr.
Tom Chichester
Anthony Turner
Level 1 Expert
Are you a Salton Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
