Question about GE GBS22HCP Bottom Freezer Refrigerator
I have an Amana side by side Model ARS236AC refrigerator. The ice chute located in the freezer section has frost that builts up around it. When I remove the frost buildup. It simply returns a few days later. Does anyone know what is causing this? Wayne
  • 82 Answers
The flap may not be closing, or may not be seating correctly.
Posted on Jun 19, 2009
  • chris weier Jun 19, 2009
    the flap may not be closing, or may not be seating correctly.
My freezer keeps frosting up
if on the back wall of unit you have a defrost issue recommend replaceing the adc/timer and defrost thermast. if not on the back wall you have a air leak often found around the doors and the ice chute .more often the ice shut look to see if everything is closing tight
Jun 03, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Frost is forming around the ice despenser inside the freezer and ice will not dispense
The ice chute solenoid located behind the main control panel for the ice and water is bad. Snap the cover off the front and then you will see 4 screws holding the housing in place. Remove this and you will see the solenoid. Replace this and you will be good to go.
May 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice dispenser frost build up - Amana refrigirator
This sounds like your ice may be melting and freezing around the chute. You may need to replace that rubber gasket on the chute. Otherwise, if you use a lot of crushed ice, that will build up badly on the chute and you can manually clean that off. I hope this helps you!
Aug 14, 2009 | Amana 25.8 cu. ft. Side-by-Side...
I have an Amana Side by Side. The freezer section
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost heater, defrost thermostat. If the heater and thermostat are ok it’ll be the adaptive defrost control.Part 13 on this diagram of your fridge controls. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=ASD2625KES&productCategoryId=0165000&brandId=1268&modelName=AMANA-REFRIGERATOR&diagramPageId=00005&componentDescription=CONTROLS&documentId=M0612301&backToLink=Return%20to%20Sub%20Components%20list
Is the evaporator fan in the freezer running.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jul 13, 2009 | Amana ASD2625KE Side by Side Refrigerator
Our freezer is not cold, food is defrosting, ice is melting. Refrigerator is working, freezer is not. We hear compressor running continuously. This is a side by side Amana model with water & ice maker...
Look at the back of the freezer wall from inside the freezer. Is there frost on it? If there is, you need to replace one of the components of the defrost system. If there is no frost then you need to have a repair made to the sealed system, it is either out of gas or the compressor is running inefficiently
Jun 20, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Frost build up around ice dispenser in freezer
Suddenly having the same problem. Any solution?
May 16, 2009 | Amana 25.8 cu. ft. Side-by-Side...
Frost forming around ice dispenser inside side by side Fridge
The presence of frost indicates that the dispenser(ice) probrably isn't closing all the way once you get ice. This allows warm air to rise up, condense and form frost. In all likelihood the solenoid that controls the opening and closing is bad and needs to be replaced.
Jul 10, 2008 | Kenmore 55692 / 55694 Side by Side...
Ice maker frosts over on the chute
This would indicate a problem with the ice chute door seal. Have it serviced. Air leakage would cause the frost-ice buildup.
Jun 01, 2008 | Whirlpool ED2FHSS Side by Side...
Frost on icemaker door
Most likely the ice door is not closing properly.
Clean out the ice chute and look down it from the inside while you shine a flashlite up from the outside. If you see light around the door then it needs to be replaced or something is wrong with the mechanism.
Post back and let me know what you find.
Nov 21, 2007 | Refrigerators
Bottom of ice maker/dispenser frosting over
Open the freezer door and look down the ice chute while you shine a flashlite up the dispenser cute from the outside. If you see light around the chute door, it needs to be replaced or something is wrong with the mechanism. The problem you describe is almost always air leakage around that flap.
Post back if you need more help.
Nov 17, 2007 | Whirlpool GC5SHEXNS Side by Side...
GE GBS22HCP Bottom Freezer Refrigerator Logo
60 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
