Question about Kenwood Audio Players & Recorders
CANT OPEN THE CD DOOR
CD IS POWERED UP, WONT PLAY AND WONT EJECT CD, HOW CAN I MANUALY OPEN THE CD DRAWER
    Habit-Forming:
    New Friend:
  • 30 Answers
I know this is an older thread however you may have a load / eject motor issue.
That being said there should be a pinhole to eject the CD. Straight out a paper clip and insert into the hole and press the manual eject button
Posted on May 07, 2016
    Champion:
    Habit-Forming:
  • 239 Answers
Take out the complete mech, look for a small pulley wheel under the tray and turn it with your finger until it releases the disc
Posted on Oct 20, 2014
SOURCE: CD drawer will not open or close
Had The Same With Mine. Its was the belt Inside that joins Motor To Cd Tray. Its Black and directly under the cd tray at the front. Its probably either loose like mine of maybe broken. I replaced mine with an elastic band and its been fine since.
Posted on Oct 29, 2007
  • 31 Answers
Hi, The CD drawer mechanism needs a new belt. They have a motor that drives the tray mechanism, and there's a small belt that drives the main gear so that pushing the drawer in gently to close it doesn't damage anything. However, once that belt breaks/wears out, the drawer will stay in whatever position it was last in.
Posted on Sep 17, 2008
  • 165 Answers
SOURCE: Drawer opens when the player is switched on
hello marc you have a dirty laser,blocked sensor or even a misaligned condition try this clean the lens put a disc and turn it off with the tray inside wait about a minute and turn it on saludos
Posted on Jan 11, 2009
SOURCE: Sony CDP-CX300 CD won't play
The rubber drive belt for the c/d load mech is streched or broken,
replace the belts there is another that drives something else so change them both while you have it open
Posted on Mar 30, 2009
SOURCE: Will not play CD's ,press play and the drawer opens
darkie u need to clean your lazer i had seem problem with same model jake here
Posted on Jul 31, 2009
There is a cd in the drawer and it plays great. But i cant get the drawer to open to change it
You may have a load / eject motor issue.
May 06, 2016 | Audio Players & Recorders
My Marantz CD 53 CDplayer door is not opening. what is the solution
You probably have a broken belt on the cd tray so it's neither open or closed, if the laser's ok thats why it wont play
Mar 31, 2014 | Marantz Audio Players & Recorders
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
This is most commonly a belt in the drawer mechanism and is easy to fix IF you have the right belt in hand and can access where it goes.
A technician will be able to help.
Dec 08, 2012 | Audio Players & Recorders
I CANT EJECT MY CD CHANGER ON MY 2000 E46 325I IT MAKES A NOISE BUT WONT EJECT, ALSO IT WONT PLAY ANY CD IN THE CHANGER, IS THERE A WAY OF MABY MANUALY EJECTING IT ? MANY THANKS, MITCH
You need to pull CD player, then remove lid (4 small screws) and you'll find CD lodged and can easily remove. Put lid back on, reinstall player and you're GOLDEN!
Jan 04, 2011 | BMW 325 Cars & Trucks
Cant get my cd drawer to open i push the button and it wont open try pushing button and pry at the same time and nothing happens have emachine T3508
with your computer power turned off, use a straight mini-kabob pin (or sturdy paper clip) to manually let out the DVD drive tray. There is a little hole under the drive tray door that accepts this kind of tool device. Another option is to massage the door while trying to eject the DVD drive tray. This method requires your computer to be turned on and by selecting the proper drive (E:) from the My Computer in Start Menu, you then "Eject" and can push in on the door and on the corners, enabling the DVD drive tray to open.
Feb 02, 2010 | Computers & Internet
The radio with a 6 disc changer stock wont eject cds in my 2001 ford windstar van with double sliding auto open/close doors
Hi
Thanks for using FixYa. Locate your DVD player’s manual Eject button. It is usually a small hole located underneath the DVD drawer.
Use a stiff wire, a paper clip or safety pin—into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open and remove the CD.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 04, 2009 | 2001 Ford Windstar
Cd player wont respond
Did you fix it? I have the same problem but can't find any solutions.
Dec 11, 2008 | Sony CHC-CL1 CD Shelf System
Hi
maybe you have defective mechanical ejection! maybe the lock is stock. this is need to open to hook up the lock
thanks!
Likha
Oct 23, 2008 | RCA RCD150 Radio/Cassette/CD Boombox
TEAC CD P1120 wont play
hi there krell
you definetly have a fault in your cd players main board best solution take to electrical shop and ask them to test all the circuits it wont cost much to get them checked out and see how you go
hope this helps and if you have the time please rate me if you dont mind
thank you
fixya
Jan 10, 2008 | Teac CD-P1120 CD Player
263 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
