Question about Kenmore HE5 Steam 7.5 cu. ft. Electric Super Capacity Dryer -
My Kenmore Elite he5 steam dryer shows check lint storage
  • 441 Answers
SOURCE: I just purchased a Kenmore HE5 Steam Dryer. It
does the door latch in place firmly?
Posted on Nov 17, 2009
  • 410 Answers
SOURCE: I have a Kenmore elite HE5 electric dryer. The timer stops
I am not a repair professional. I am a 78 year old man who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and found that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer or a front load washer I suggest you
go to www.applianceaid.com where they have very good step by step trouble shooting and repair information on both washers and dryers as well as other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good
trouble shooting and repair nformation on most
washers and dryers. I think you'll find what you need
there. Don't worry about the timer, they hardly ever
go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Posted on Nov 30, 2009
blueextc3221
  • 15935 Answers
SOURCE: Our Kenmore Elite he5 steam dryer has an error
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 25, 2010
blueextc3221
  • 15935 Answers
SOURCE: My Dryer Kenmore Elite HE5 show the Code F70...
The F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If it does, then the washer may work normally.
If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit. I recommend calling a service technician to properly diagnose and repair this type of problem so that the correct component can be replaced.
Be sure your unit is plugged into a 3 prong grounded outlet as well.
F71 is a "heatbeat failure" which means that your front interface control board is shorted and will need to be replaced. it's actually fairly easy to replace and can definitely be done by yourself. To access the part, just pull the unit forward and remove the 3 screws coming in from the back of the top panel. Remove the top panel by pulling it back, up, and off. Then remove all the screws going into the top of the control panel. Remove the dispenser drawer and remove the screws coming in through the dispenser. Remove the screws coming from the inside of the dryer going forward into the control panel, then remove the control panel (it's just clipped in on the bottom. After that you can disconnect the wire harnesses to the front interface control board and replace that part.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 28, 2010
blueextc3221
  • 15935 Answers
SOURCE: Hi..I bought a HE5 Kenmore Elite dryer...do i have
yes - you must make all the connections.
Posted on Sep 30, 2010
How do you clean the lint inside the he5
most likely you have too much lint built up in the exhaust tube just unplug the dryer pull it out so you can get behind it and pull off the exhaust tube.you will have to loosen the clamp first with a flat head screwdriver.Once you get it off remove as much lint as you can by hand and then clean the rest out with a vacuum. you will need to clean out both the the exhaust tube and the tube going into the dryer.Then put it back together and run it to see if that fixed the problem.If that does not work then you will need to call a service technician.Mechanical Mobile services is a good repair company to call if you need a tech 443-791-0895
Feb 17, 2014 | Kenmore HE5 Steam 7.5 cu. ft. Electric...
Dryer won't run check lint screen light comes on
Did you check the obvious by turning off the 30 amp double breaker and turning it back on
Nov 30, 2013 | Kenmore HE5 Steam 7.5 cu. ft. Electric...
No heat-Kenmore (Whirlpool) Elite He5 Steam 110.8775
Check that there is 240 volt at the plug as sometimes a breaker will be weak on one side and only produce 120 volts which will let the drum spin but produce no heat
Mar 20, 2010 | Kenmore Elite 45986 Front Load Washer
Hi..I bought a HE5 Kenmore Elite dryer...do i have to hook up the water inlet even if i do nto use the steam options?
Sep 27, 2009 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore Elite HE5 front loader and seem
when i clean my screen i use a cheap vacuum to **** up particles as i pull it out and vacuum screen. works so nice.. but use a cheapy that you doesnt need a bag and it will filter better as it gets clogged with lint lol.
Apr 16, 2009 | Dryers
Kenmore Elite HE5 Electric Dryer
I have a Kenmore HE5 Steam: after a power failure last week, now when you turn the dryer on and push"start" the cycle stops emediately and flashes PF...
May 07, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore HE5 Steam 7.5 cu. ft. Electric Super Capacity Dryer - Logo
23 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
