Question about Kenwood Car Audio & Video
87 vette power antenns wire color under dash - Kenwood Car Audio & Video
3 Suggested Answers
  • 34 Answers
SOURCE: 87 VETTE MISSING BADLY
18436572
Posted on Mar 14, 2009
BeninVa
  • 389 Answers
SOURCE: bought 87 jeep wrangler for project. look under
Autozone.com has some great wiring diagrams. I looked and your Jeep seems to be there. Go to Vehicle Repair Guide>chassis electrical>wiring diagram. You may need to register, but I think it's worth it. I'm looking at the diagram for your vehicle so if you have any trouble finding it just post a comment and I will try to assist you.
Posted on Jan 13, 2010
Testimonial: "Very rapid response, thanks for the assist. I will let you know"
Why can I not get power to the small wire going to the starter on my 2004 taurus
You need to know how it works before you can diagnose it. There is a starter relay in the under hood fuse/relay box .. This relay is controlled by the PCM - engine computer . Does you car have a anti-theft system ? a red light on top of the dash or a SECURITY light on instrument cluster ? Is the red light flashing fast when trying to start the car . If you find an pull the relay out an look on the bottom you will or should see four numbers . 30 & 87 , 85 & 86. You can test from the socket where the relay plugs in . PIN'S 87 & 85 should have B+ voltage . PIN 30 takes voltage from PIN 87 to start the vehicle , PIN 86 is the control from the engine computer . The PCM gives a ground on this circuit to energize the relay closing the contacts inside ,completing the circuit between B+ voltage on PIN 87 to PIN 30 to start the car.
Feb 04, 2016 | 2004 Ford Taurus
My dash lights will not work how can I fix this
Do you have any mileage programmer, use the to reset the dash system.
Jul 31, 2013 | 1988 Mercury Tracer
I have 87 vette driven car stop running change module coil still no spark starts ounce in a month then dies had three mechanics look at it and no one knows what wrong with it
car is a classic--get the hole ignition system looked at by a specialist-othr parts are worn or wires cud hav degraded--secure a haynes repair manual etc to study procedures
Jun 03, 2013 | Cars & Trucks
98 mercury trace no 12 v going to the ac compressor
check your fuse box for a blown ac fuse, fuse box usually under dash, sometime under the hood of the car usually on drivers side. bad switch?
check if you hot wire lead might be pinched and grounded out or broken wire between battery and switch
May 25, 2012 | 1998 Mercury Tracer
2004 vette, I have an engine analyzer module,
It should be right near the steering column under the dash. They are usually easily accessible -- I've never known GM to hide them. It may be behind a trim panel.
Apr 26, 2010 | 2004 Chevrolet Corvette
The display light on the radio of my 96 vette stays on.Now the a/c won't turn off
You have an issue in the wiring loom under the dash--there is some kind of short--good luck--these are the awkward ones
Jul 11, 2009 | 2004 Chevrolet Corvette
1986 corvette electrical problems.
since you have power in both states its obvious that you have a ground wire problem this is very common on vettes due to fiberglass body your gonna have to take dash pad out and trace down both grounds on these 2 areas till you find the loose or broken wires theres a huge amount of ground wires from those locations on a block between the battery and firewall under the hood use a volt meter make sure you have it grounded and search the circuits 1 at a time ..i also have an 86 vette and have had similar problems if your not a good electrician youl just be pulling your hair out,, another way is,, if you cant beat em join em ,, try pulling a new wire to the effected circuits from a ground point on the fire wall make sure battery is grounded properly reattach any broken or loose ground straps you find around engine compartment these are braided bare wires going from engine to frame and from battery to fire wall etc hope this helps you im lucky i have some electrical knowledge because it can be frustrating
Sep 29, 2008 | 1986 Chevrolet Corvette
1977 chevy corvette wiring diagram
All the diagrams for your corvette can be found here:
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c1528008370b
Headlight wiring is towards the bottom of the page.
Hope this helps, have fun wrenching on that vette.
Jul 04, 2008 | 1977 Chevrolet Corvette
Car Audio & Video Logo
12 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
