Question about Magellan Maestro GPS
Magellan 4200 will not turn on has new battery
My magellan 1700 won't turn on, even after I reset it and put in a new battery
if you have a volt ohm meter see if theres voltage at the power adapter plug
May 12, 2014 | Magellan RoadMate 2000 GPS Receiver
Magellan RoadMate 2200T won't turn on
ost times not turning on is because the battery is flat or dead. Connect it to a USB charger or and AC charger and leave it for an hour to see if there is any recovery.
If it does not have it taken to a service centre to have the charge circuit checked and a new battery.
Please rate my help++++Thanks for using FIXYA
May 14, 2010 | Magellan RoadMate 2200T GPS Receiver
GPS receiver of Magellan maestro don't hold the charge/do I need to change the battery inside or needed to be repaired?
you should charge it and then when youre done dont forget to turn it off if that dont work then got to radioshack and buy a new battery!
Apr 12, 2010 | Magellan Maestro 4040 GPS Receiver
When I turn my Magellan Triton 400 on, it stays on the first screen that pops up. The only way I can turn it off is to take a battery out. I've tried new batteries, but that doesn;t work.
It is too complicated to fix yourself. If the unit is out of warranty, the JungleGhost at jungleghost.com has a repair service. Go to http://www.jungleghost.com/repair_service.shtml
Mar 04, 2010 | Magellan Triton 400 Handheld GPS Receiver
My magellan roadmate 1440 will not turn on? Is
get a new one.. no way to fix unless u get a new battery
Dec 18, 2009 | Magellan RoadMate 1440 Car GPS Receiver
Hi i have just bought a magellan maestro and can not get the voice directions working... it is a magellan maestro 4200
you say the voice directions are not working, but does the voice work at all..like when you scroll back through the screens, it should say back ect ect. if the voice does not work at all, ck the speaker icon on the main map screen to see if its muted, indicated by a slash through the icon..if it is not on mute, go to the system folder the to the sound tab go in there and make sure its not muted in there, if it is, unmute it and restart the gps..its a common problem on these magellan if the battery is run to low or completly dead which causes more problems. if all else fails, do a hard reset
Jun 24, 2009 | Magellan Maestro 4250 GPS
My magellan 1200 will not keep a charge when i plug it in...it will not turn on cause the battery is dead...when i plug in the charger to the unit it flashes a bright white light for like a fraction of a...
I agree. I suggest you should go to a technician and try a new battery. If the new battery does not work you should speak to your manufacturer.
Thanks for using FixYa!
Oct 17, 2008 | Magellan GPS
Magellan 2000 doesn't power up
try replacing the battery. ususally if the battery is dead it will freeze or not turn on. if this doesn't work magellan will replace it with a new one at a very reasonable price. I just replaced a magellan 800 with a magellan 3210 for $132.00. your may get a better deal. call magellan
if you have an a/c 110 volt to 5 volt converter for the magellan, try charging it in the house with that one rather than the car charger.
Jun 07, 2008 | Magellan RoadMate 2000 GPS Receiver
GPS Logo
16 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
