Question about Mtd Garden
The stiring wheel shaft keep slipping on its braket!
The notches on the bottom of the shaft keep slipping on the turning plate, the plate looks ok. but the notches on the bottom of the shaft looks worn. how can I remove and replace?
  • tml2
    tml2 Sep 24, 2012
    ive done several of these. email me with tractor and i can help you tom tml61747@yahoo.com
  • Doug Jul 30, 2013
    13CF675G062
  • 376 Answers
What is the model number under the seat?
Posted on Jun 19, 2009
  • Dwain Pippen Jun 19, 2009
    Sorry, I didn't mean to make that a solution. Hit the wrong key. Anyway, if you'll get the model number from under the seat and post it here, I tell you what you need to fix it. MTD makes several different steering systems. That's why I need the model #. Dwain
How do I fix my snowblower when the wheels won,t move ahead or back
Sounds like gear on axle shaft broke shear bolt or key. Take bottom plate off base of snowblower.It is ok to tip snowblown up on front end so wheels are in air. After plate is off turn wheels and see if drive gear is moving with axle. If not key way or bolt has broken off, replace and will be back in motion.
Feb 18, 2015 | Craftsman Snow Blower / Snowblower Bottom...
Ice maker issue - the auger is turning but with any resistance it will slip while the shaft keeps turning. If you remove the ice bucket and hold the auger it will slip there as well. Top of shaft and...
Can you please advise your brand name and model number (of your ice-maker)?
However it sounds like the drive blade may be rounded off, but this is just a guess in the absence of model number.
Best regards,
Feb 17, 2018 | Refrigerators
I have an 04 yz 125 that won't shift into 2nd but
2nd gear is at the bottom of the shafts if the tranny is stacked in the mag side case. So it is controlled by the bottom fork. You should be able to shift it thru all the gears by turning the shift drum. Make sure as you shift the shafts stay all the way in the output shaft and idler shaft bearings. As you shift it, look for full mesh between the wheels(shaft that goes to the clutch) and the gears across on the output shaft.
If that all looks good, the shifter cluster(on the end of the shift drum, with the 2 dogs that engage the notched wheel on the end of the drum) may not be lined up properly. If the gears and shift drum are new, I'm thinking I'd look there first. Good luck!
Jun 11, 2011 | 2004 Yamaha YZ 125
How to replace key ignition
I don't think your vehicle has an airbag system, but please be certain if it has I would refer you to a manual for the proceedure to discharge SRS system before you start. Some local libraries have manuals that they will let you look at and photo copy. You will need a good quality steering wheel puller, and snap ring pliers and a tool to remove the locking ring retainer and to reinstall it. All you need to do is pull the horn ring (look at the back of the steering wheel) remove the screws that hold horn pad on. Next loosen the steering wheel nut do not remove at this time this is left on to prevent you from getting a steering wheel in the teeth when it pops loose, (possibly). Next check to see the locater marks on the column shaft and the wheel note position and mark if necessary. Do not use a hammer to pound on shaft of column it WILL damage the shaft! Use steering wheel puller tool to remove wheel. Next use the lock plate removal tool to depress and release pressure on retaining clip holding plate on remove plate. You may have to pull turn signal switch out of the way by removing the handle and retaining screws. Now you will see a plastic clip that holds two brass comtacts carefully move the top plastic release clip down to release and remove small contact assembly. You should be able to see a square notch in front of the mechanical key lock mechanism. With battery disconnected move cylinder to on position and slide out assembly. Slide new assembly in place and try back to lock position and remove key. Reverse order to assemble.
Oct 14, 2010 | 1990 Buick LeSabre
John deere 68 riding mower steering column won't turn wheel assembly via arced toothed plate. Wheel assembly OK and greased. Some minor play when rotating steering column with steering wheel, but appears...
Just had same problem with my craftsmen. There is a very inadequate little nylon bushing supposed to keep that shaft stable. When worn out it allows that shaft to move and puts the gears in a bind. It is located on the end closest to arced gear where shaft hooks to drag link. Its a pain.
Sep 27, 2010 | John Deere Garden
My horn blows when i turn the stiring wheel
take your steering wheel of . you have a little spring in there onder a round plate replace it
Sep 19, 2010 | GMC Sonoma Cars & Trucks
I can not get the alternator out
ok im a mazda tech i won a price for doing this for mazda
alot of techs were taking off the drive shaft and mazda was paying to much for the warranty labor haha
loose and remove the alternator and move it out of the way
from the alternator braket
what going to do next is remove the alternator braket its 3 or 4 bolts
remove joint shaft too
remove it completely and you can remove the alternator its a snug fit but its been done and going back in its the same prossedure alternator in first and braket next
braket torque bolts to 29 to 41 ft lbs
May 14, 2010 | 2002 Mazda Tribute
Pulley wheel slips off and the agitation stops.
There should be square notch in the pulley and one in the shaft, this keeps the pulley on the shaft, if that shear pin or keeper is missing you will need to replace it most auto parts shops have shear pin material in stock and they are pretty cheap.
Mar 19, 2009 | Washing Machines
Kirby g4 belt replacement
Facing vacuum,turn belt lifter knob counterclockwise till it stops.Lift headlight hood,and unlatch brushead,and remove.Looking thru the hole in back,turn belt lifter knob clockwise to release belt.Remove bottom plate,and bend one end of bracket to remove end of brush roll.Slip new belt on and replace brushroll back into bracket,and replace bottom rug plate.Looking thru hole in back,turn belt lifter knob until the hook inside picks up belt.Replace brushead,and again,turn belt lifter knob clockwise to drop belt onto shaft.
Dec 18, 2008 | Vacuums
Garden Logo
174 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
