Question about Fusion En-at1120 Car 12" Active Bass Tube Enclosure Powered Subwoofer Sub wires
Hi I have misplaced my wiring kit for my fusion 1120 sub is there another way to wire it in
5 Suggested Answers
SOURCE: fitting a sub and a amp
Is it stolen?
Posted on Feb 08, 2008
ricomun
  • 24 Answers
SOURCE: hi i have fusion sub woofer can u help me to
  1. Batt + or B+ or Positive.
    This is the connection directly to your automobiles battery. It should be a fused connection rated to about 15% higher than the fuse installed in your amplifier.
  2. Negative or '-' or Ground.
    This wire should be just as thick as the 'Batt + or B+ or Positive' wire. This wire can attach to any solid clean metal connation in the vehicle. Usually a trunk latch.
  3. Remote or amp startup wire.
    This wire is a thin 12V wire that will come from the deck. It's a signal wire that tells the amplifier to turn on.
  4. Inputs
    Low level inputs are in the form of RCA connectors and will require that your deck or head unit has low level or RCA outputs. High-level inputs are used for stereos that don't have low level or RCA outputs. They work by taking an audio signal directly from the vehicles speakers and then amplifying it as necessary.
  5. Speaker connection.
    Match the + and - these with the appropriate connectors on the speaker box. Red means + and Black means -.
    I hope this helps.
Posted on Jul 06, 2009
SOURCE: ive wired my fusion amp and sub but no sound
The orange wire, where do I conect it?
Posted on Aug 13, 2009
etirbynnor
  • 655 Answers
SOURCE: i have a fusion sub and amp and have no
Hello nicole_murra,
The green wires are for signal input to the included amp and should be connected to a pair of RCA preamp outputs on your head unit. The thin blue wire connects from "remote" on the amp to a switched 12V output on the head unit (usually blue or blue/white). The red wire is for power and goes through the fuse to positive battery. You also need to connect the amp terminal marked "ground" to the metallic chassis of your vehicle, within a distance of about 1/2 meter or less. There's usually a short piece of wire with black insulation included in most amp wiring kits. If your Fusion sub did not come with such a wire, you can use any wire that is the same gauge (or bigger) than the red power wire.
Hope this helps.
Posted on Sep 11, 2009
I have a 2 ohm dvc sub and a fusion pp am10001 amp what the best way to wire the sub to this amp
Since your amp is only 2 ohm stable, you will need to wire your 2 ohm DVCs in series (if they are 2 ohms each voice coil). Here is the manual for your amp:
http://www.vbc-group.com/ebay/PP%20Amp%20Man%20Pg1-21.pdf
Jan 09, 2016 | Fusion Car Audio & Video
I have got the Fusion FJL-1211 Class D Amplifier.When i turn the music up the amp switches off and back on until i reduce the volume and it plays fine.
your overloading the amp and its going into protect mode. turn the bass down on the deck or adjust the controls on the amp itself. get lower power rated sub(s) or more powerful amp since you won't be able to push the sub(s) you have with that one since the sub(s) is/are pulling too much power from the amp.
Aug 18, 2010 | Fusion Car Audio & Video
I have a fusion sub and amp and have no instructions on how to wire this can somone please help ive got green wires red wire and a small thin blue wire
Hello nicole_murra,
Hope this helps.
Sep 08, 2009 | Fusion FEW12PK Car Subwoofer
Have no wires for a Fusion EN-AT110 Basstube!!!
The best place is to go to any store like halfords or maplin, or a lot cheaper if you wanna wait is ebay, many fusion amps/ active subs need special wiring !!!£80 from them direct only way, or you can go to maplin and get this product: A21GF (power supply extender 24pin) then cut off the three columns you need and the top and bottom of each are the respective 12v positive input remote and earth, cut the wires off half way and twist the top and bottom together, then add the twisted wires to your normal sub cables. make sure you use insulation tape around the naked wires for quality and stop it short curciting
Dec 09, 2008 | Fusion FEW12PK Car Subwoofer
Sub making noise without input
Hi there guys, i dont have this problem ,but i do have the EN-AT1100 encounter 10" and cant get the thing to work at all. The six pin plug for the power (12V+), earth (GND) and accesories (REM) are all muddled up as i never bough it with the original leads. Can any of you help me out with the wiring on how to connect it? is there two wires for (12V+), two wires for earth (GND) and just one wire for accessories (REM)?
Hope you can help thanks.
Sep 13, 2008 | Fusion FEW12PK Car Subwoofer
AMPLIFIER PROBS
check all power coming to your amp remote especially
Jan 21, 2007 | Fusion FEW12PK Car Subwoofer
Fusion En-at1120 Car 12" Active Bass Tube Enclosure Powered Subwoofer Sub wires Logo
32 people viewed this question
Top Fusion Car Audio & Video Experts
Matthew Spark
Matthew Spark
Tygh Duval
Tygh Duval
Are you a Fusion Car Audio and Video Expert? Answer questions, earn points and help others
