Question about Dryers
Whirlpool dryer will not start even after changing the motor
Ok I have a issue that is stumping me. I had a repairman look at my 2001 Whirlpool dryer and he said the motor relay was bad and the motor needed to be replaced. So this morning I went to the parts store and got a motor and fanwheel and replaced it myself. Hooked everything back up and nada. I had already checked the thermal fuse and it tested good. Basically when I open the dryer door the light comes on and when I close it the light goes off. When I set the timer and push the start button nothing happens I can hear the timer clicking away. Any other ideas to check. It is model # LEB6400LW0.
  • 4 more comments
  • girardsc23 Jun 19, 2009
    Sorry it is 220v and I have checked the breaker box and have actually flipped the breaker twice just to make sure that it was not tripped.
    Ok ready for this I just changed the thermal fuse and the timer switch because this is irritating and still no signs of life. Oh failed to mention that when I open the door the drum light comes on and when I close it I can see from the rear that the drum light is off. Anyone have any ideas? Any way to jump the start button manually?
  • girardsc23 Jun 20, 2009
    I did grab a voltage meter and tested the door switch and it is testing good. I even tested the starter button and it test good. I am thinking that it has to be either the thermostat cut off or the thermostat internal bias. Otherwise really the only thing left to change is the little motherboard like thing. So any additional things to try just let me know and I will give it a shot. Man this thing has me stumped
  • girardsc23 Jun 23, 2009
    Ok since I have replaced just about everything else on this dryer and it is still not working. I replaced the door switch even though it tested good and still nada. This evening after I replaced the door switch I got curious and the cabling that goes to the motor I hooked the voltage meter to it to the red and to the black wires that go to it. I plugged my voltage meter to it and then plugged in the dryer, nada then I grabbed the door switch and closed it as if the door were closed on the dryer. Turned the dial to timed dry and then pressed start it did not show anything on the voltage meter. Not a jump nada nothing it would seem to me that when I pressed the start button it should have least "completed the circuit" and shot a jolt of power at least but nope nothing. Anyone have any ideas I would love to hear them.
  • girardsc23 Jul 09, 2009
    It actually ended up being a bum replacement motor. Thanks for all your help!
  • chris weier May 11, 2010
    Do you have 220v to the outlet, to the dryer? Have you checked the wiring in the control panel?
  • 999 Answers
If you do not have a meter to trouble shoot with you can bypass the switch by taking off the wires and clipping them together . UNPLUG the cord first. Make sure they are not touching anything and plug it in and shut the door. If it starts it is the door switch. If it does not you have some investigating to do.
Eric
Posted on Jun 19, 2009
  • Eric Duda
    Eric Duda Jun 23, 2009
    Set for a timed dry. While pushing the start button(hold it in) wiggle the timer knob around.(This sometimes will show a bad or failing timer contact) If there is nothing happening then you are going to have to follow the voltage path from the plug through the thermostats and timer to the motor with a meter. Eric
Dryer will not run
though there is power supply to the unit but don't start you have to check the door switch. if switch is ok and still unit don't start check the starting capacitor if equipped. replace if bad. if unit won't start even with a good capacitor and good door switch , then check the motor switch. if motor switch is bad replace the whole motor. switch and motor are sold together.thanks.
Mar 01, 2016 | Whirlpool Dryers
Dryer starts, drum turns a few times then stops. On its own, repeats the attempt to start but has the same issue. For a while it would actually start and complete drying cycle after 3-5 attempts. Now it...
if you can still here the motor running it could be the belt slipping,, try running the dryer with a very light load in it ,,if it works ok,,its the belt slipping and it cant turn a full load anymore,,change the drive belt!
if no motor sounds its the programer,,,pricy part!!!
Jun 27, 2010 | Whirlpool LER4634J Electric Dryer
It will not spin or drain
check pump assy and filter assy could be blocked ...if ok change motor brushes
Dec 31, 2009 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool gas dryer does not heat, Motor works drum to go around; timer seems to work also. Repair person said it was the controls on the motor; replaced motor but still have no heat. Cleaned out vent...
I do believe the repair man hosed you on the motor. Most of my experience is with electric dryers but I can try to shed some light on the subject. I would test the safety thermostat if it is open you can temporally short the leads together to see if it heats up. It is about $70.00 so you do not want to just swap it out, do not run for a long period of time if you short the leads out (Fire is Bad). Next check the Sensor on the burner unit which turns on the Electronic gas valve ($200.00 Ouch) or it could be a clog it the orifice. Do you smell Gas by the burner unit? Next is the Igniter which you should hear click. A volt meter is recommended to test the components and an Ohm Meter to test the Safety Thermostat. I wonder if your repairman even took his out of the truck.
Jul 15, 2009 | Whirlpool Dryers
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Whirlpool LER5644A No heat and motor wont Turn
Replace the dryer wires.
Put your meter leads into the 4&5 slots.
Make sure the door switch is closed or jumpered.
Push the start button.
If you read no voltage the issue is with the wiring, the timer, or a relay.
Mar 11, 2009 | Whirlpool LER5636P Electric Dryer
Dryer will not start
Go to the breaker panel and make sure the neutral is making good contact. Especially check for corrosion. If it is good there, look for other connections between breaker panel and dryer. It seem to me you have a bad neutral somewhere.
Feb 24, 2009 | Whirlpool LER4634J Electric Dryer
Drum will not rotate in LEW0050p Dryer
hello is the door making the switch if thats ok check wires see if any are loose if thats ok .at the bottom of the machine next to the motor theres a part callled a capacitor its got 2 wires coming off it this can stop the dryer rotating i hope this help
Jan 28, 2009 | Whirlpool LEW0050P Electric Dryer
Dryers Logo
207 people viewed this question
Top Dryers Experts
Marvin
Marvin
