Question about RTO Sole F80 Treadmill
Low speed fault - RTO Sole F80 Treadmill
    New Friend:
  • 22 Answers
With belt movement check speed sensor. Without belt movement check MCB. If you neglected unit it could be belt and deck if its shutting down during a workout. I have also see a lot of on/ off switches getting old and causing LS errors due to low voltage to MCB
Posted on Aug 16, 2014
02001 TOYOTA TACOMA TRANS SPEEDS THROUGH GEARS AT LOW SPEEDS CAUSING ME TO DOWN SHIFT NO PASSING GEAR
assume it is an automatic
speed sensor
solenoids
low oil
needs a service
TPS
transmission computer fault
Oct 20, 2016 | Toyota Cars & Trucks
Tip
Komatsu Fault Codes
E02 PC-the EPC system;
E03, Swing parking brake system;
E10, the engine controller power failure, the engine control drive system circuit malfunction (this engine stall;
E11, the engine control system failure (decrease of output power, in order to protect the engine);
E14, the feedback system abnormalities;
E15, engine sensors (temperature, fuel pressure, oil pressure) fault;
EOE, a network failure.
The fault code: the 989L00 the engine controller lock warning (mode 1).
989M00, the engine controller to lock warning (mode 2).
989N00, the engine controller to lock warning (mode 3).
AA10NX air filter clogging.
AB00KE charging voltage is too low.
B @ BAZG, low oil pressure.
B @ BAZK, the oil level is too low.
B @ BCNS, engine coolant overheating.
The @ B BCZK the coolant level is too low.
B @ the HANS, the hydraulic oil from overheating.
CA111, the engine controller internal fault.
CA115, the engine speed sensor and backup speed sensor failure.
CA122, the intake air pressure sensor feedback voltage is too high failure.
CA123, the intake air pressure sensor feedback voltage is too low failure.
CA131, the throttle plate sensor feedback voltage failure.
CA132 throttle plate sensor feedback voltage and low failure.
CA144, high coolant temperature sensor feedback voltage fault 145, the coolant temperature sensor feedback voltage is too low failure;
CA153, intake air temperature sensor feedback voltage is too high failure;
CA154, intake air temperature sensor feedback voltage is too low failure;
CA155, the intake air temperature is too high (over limit);
CA187, sensor power supply voltage is too high failure;
More Fault Codes HERE http://truckmanual.weebly.com/komatsu-fault-codes.html
on Dec 20, 2016 | Cars & Trucks
When serviced it showed a low frequency fault but after service it cleared the fault. What is possible causes for fault?
Low frequency is caused by the engine not running at it's correct speed. There is a governor mechanism that controls the engine speed, so I'd check it for proper operation.
May 09, 2016 | GE 13KW Generator System With Symphony, II...
My cars revs jump slightly at low speeds causing car to jump at low revs
Sounds like a fault on the throttle body any warning lights showing on dash board?
Feb 19, 2016 | Cars & Trucks
Shuttering or vibration when accelerating from stop or low speed. now makes clicking/slight clanking noise at low speeds
cv joints are what normally make that clicking m noise at low speeds ,more prevalent when turning a corner
as to the other faults , run the fault codes as it sounds like a random misfire and may be fuel pressure or injector related
Oct 30, 2015 | 2006 Kia Sorento
When i pull the code up on my 1992 park avenue it blinks once then blinks twice. what does this code mean?
This is code 12 and it means "System Normal"
Here is the complete list of fault codes for your Buick
GM common codes for OBD1 (for vehicles made before 1995)
12 System normal
13 oxygen sensor circuit open
14 coolant sensor high resistance or shorted
15 coolant sensor circuit low or open
16 direct ignition system (DIS) fault in circuit
17 cam position sensor fault
18 crank or cam sensor error
19 crank sensor circuit fault
21 tps sensor out of range
22 tps sensor signal voltage low
23 intake air temp sensor out of range, low
24 vehicle speed (vss) sensor circuit fault
25 air temp sensor sensor out of range, high
26 quad-driver module (computer) circuit #1 fault
27 quad-driver module (computer) 2nd gear circuit
28 quad-driver module (computer) circuit #2 fault
29 quad driver module (computer) 4th gear circuit
31 cam position sensor fault
32 egr circuit fault
33 map sensor signal out of range, high
34 map sensor signal out of range, low
35 idle air control sensor circuit fault
36 ignition system circuit error
38 brake input circuit fault
39 clutch input circuit fault
41 cam sensor circuit fault, igntion control circuit fault
42 electronic spark timing (EST) circuit grounded
43 knock sensor
or electronic spark control circuit fault
44 oxygen sensor lean exhaust
45 oxygen sensor rich exhaust
46 pass-key II circuit or ps.pressure switch circuit fault
47 pcm-bcm data circuit
48 misfire diagnosis
51 calibration error, mem-cal, ecm or eeprom failure
52 engine oil temperature circuit, low temperature indicated
53 battery voltage error or egr or pass-key II circuit
54 egr system failure or fuel pump circuit low voltage
55 a/d converter error or pcm not grounded or lean fuel or frounded reference voltage
56 quad-driver module #2 circuit
57 boost control problem
58 vehicle anti-theft system fuel enable circuit
61 a/c system performance or degraded oxygen sensor signal
62 engine oil temperature high temperature indicated
63 oxygen sensor right side circuit open or map sensor out of range
64 oxygen sensor right side lean exhaust indicated
65 oxygen sensor right side rich exhaust indicated
66 a/c pressure sensor circuit low pressure
67 a/c pressure sensor circuit or a/c clutch circuit failure
68 a/c compressor relay circuit failure
69 a/c clutch circuit head pressure high
70 a/c refrigerant pressure circuit high
71 a/c evaporator temperature sensor circuit low
72 gear selector switch circuit
73 a/c evaporator temperature circuit high
75 digital egr #1 solenoid error
76 digital egr #2 solenoid error
77 digital egr #3 solenoid error
79 vehicle speed sensor (vss) circuit signal high
80 vehicle speed sensor (vss) circuit signal low
81 brake input circuit fault
82 ignition control (IC) 3X signal error
85 prom error
86 analog/digital ecm error
87 eeprom error
99 power management
May 05, 2011 | Buick Park Avenue Cars & Trucks
98 suzuki swift low speed ,misses hesitates high speed is fine i just drove from vancouver to yukon 2400klms slow speed not good, how do i fix
It is possible that your car has some blocked jets, the fuel pump/injectors need a retune. Change the fuel filter and do a general suzuki 20 check up. the fault will clear off. I am sure this is a fault linked to the firing/fuel at the low RPM. What you can check is to see the filters, the electric section for poor contacts. Hope you try. Good day
Aug 12, 2010 | 2001 Suzuki Swift
Intermittent jet problem on Spa form hot tub - low speed jet works, when button is pressed for high speed, it starts runs for a few minutes then switches back to low speed, then back to high speed again - ...
Hmm, that's an odd one. It could be either a fault with the PCB or the pump.
The first thing to check is the voltage to the twin speed pump. If that's ok the motor is probably the cause of the fault.
As always, with anything electrical you need to be very careful with what you're doing and if you're unsure seek professional help.
Regards,
Ian.
http://hottub.synthasite.com
Apr 14, 2010 | Pool & Spa
Please explain hyundai terracan 2002 fault codes p1730 front speed sensor low input, p1732,p1734 low input,how to find problem, low range there is no opperation at all, cheers ,clive.ps in the model...
P1730 Front Speed Sensor - Low Input
P1732 Rear Speed Sensor - Low Input
P1734 Speed Sensor Reference - Low
These are all references to Electronic Stability Control or ABS systems. If there's no problem with wiring, then you could safely assume the speed sensors are bad.
Apr 30, 2009 | 2002 Hyundai Tucson
RTO Sole F80 Treadmill Logo
885 people viewed this question
Top RTO Exercise & Fitness Experts
Jim London
Jim London
Howard
Howard
Jax Planet
Jax Planet
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
