Question about Frigidaire FRS26R4A Side by Side Refrigerator
Replaced water actuator on frig and now it doesn't dispense water
I just replaced the water actuator on my Frigidaire frig and now I don't have any lights on the buttons and no ice or water will dispense.
  • 82 Answers
Pull it back open and double check you're wire connections
Posted on Jun 19, 2009
2002 kenmore 51262103
Unfortunately the valve that is in the back of the frig needs to be replaced. For some reason this valve that the main hose goes in goes bad and the water dispenser won't work. I had the same problem on my Frigidaire and had to replace the valve in the back.
Aug 17, 2014 | Refrigerators
Can't get water to come out the door frig. is one day old
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don't hear it there is a dispenser actuator switch problem. If you do hear it but water doesn't work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Sep 11, 2011 | GE Profile 23.1 Cu. Ft. Side-by-Side...
Water Dispensing Problem
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don’t hear it there is a dispenser actuator switch problem. If you do hear it but water doesn’t work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Oct 09, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
No light on water dispenser
'After about ten months, the water dispenser stopped. I found a 5/16" coupling below the freezer door. Following the instructions on a tab attached to the hose, I separated the hose from the coupling. I then actuated the water cradle. Water gushed out of the tubing. The dispenser side of the dual water valve is ok.
I snaked a wire into the hose toward the dispenser until it stopped. I withdrew the wire then measured the length. The hose had a blockage at the lower left edge of the dispenser opening. I didn't know if there was a check valve in the hose. Since it was still in warranty (2 months to go), I called service.
I didn't say anything about what I did to the tech. He concluded that the hose was frozen (there is no check valve or anything else in the line between the coupling and the dispenser). According to him my options were to replace the door (he actually said that) or shut down the frig and let it defrost. I fabricated a double layer cardboard cover for the freezer compartment. I removed the light bulb then covered the opening. In about 60 minutes the dispenser started working again. I have had the frig since 12/03. It just froze up for the sixth time today (3/20/07). GE has offered no help or acknowledging that the frig has an insulation problem.'
Jun 20, 2009 | Frigidaire FRS6R5EMB Side by Side...
Frigidaire PLHS267ZCB4 side by side, no ice or water, not cooling
I have the same problem. The repair people replaced the control board, but it did not fix the problem.
Mar 17, 2009 | Frigidaire Refrigerators
Ice maker
new icemaker,wont fill up with water when it calls
Jan 24, 2009 | Frigidaire FRS26R4A Side by Side...
Water dispenser and ice maker not working
Hi!! tony , yes you have a bad water valve its located on the bottom back of your frig..Replace your water valve..Good luck..
Jan 03, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Replace water actuator
im assuming you replaced the water actuator,and now cant fit the water hose back into the holder??? try disconnecting the hose under the freezer door hinge, this will allow you to pull extra hose up into the dispenser area, then after remounting the face you can reconnect at the bottom
Nov 25, 2008 | Frigidaire FRS26R4A Side by Side...
Water Actuator is broken.
I had the same problem with my water dispenser and since they were willing to sell me a part but provided no directions and I couldn't locate any I decided to make my own for those who might need them. Here is a link to a PDF I made, hope it helps.
http://www.rharriman.com/SupportFiles/FridgeActuatorReplacement.pdf
Before starting this job I would also like to warn all to please be save and UNPLUG the fridge. The whole job took me less then 30 minutes and I doubt anything will go bad in that amount of time.
Jan 13, 2007 | Frigidaire FRS26R4A Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
196 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
