Ktv lajmet e fundit - Televison & Video
Looking for the remote control code for a KTV television KTV LTW42DV
0184,0119,0157. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; that you want set-up code, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 05, 2016 | Ktv Televison & Video
Cybertec rm312x. What is code for KTV ultra slim TV?
Your Cybertec remote probably has a "code search" feature you can use to find something that will handle some or all functions of your KTV TV. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not contain all possible codes.
Feb 06, 2016 | Universal Televison & Video
Ktv televisions
1) you must test the TUNER try to clean with special LUBE for TUNERS +,i-f, detector, AGC signal see the block diagram for fix it
or get help from TV repair shop.
God bless you
Jul 14, 2012 | Ktv 13TEC 13" TV
How can i get a remote for my ktv ?
Hello
Remote codes for KTV with RCA RCR 311S are:
1004, 1035, 1046, 1065, 1068, 1078, 1083, 1123, 1127
Just buy this model RCA remote control You will get instructions with it how to set it up. OK.
Jun 30, 2011 | Ktv Televison & Video
Dont know how to use ktv remote
http://www.cox.com/support/digitalcable/hdtv/pdf/Universal_Remote.pdf
Try above link, this may be helpful to you.
Thanks,
Sep 18, 2010 | Ktv 13TEC 13" TV
How do i turn off the timing belt warning light after the belt has been replaced on my 93 trooper
You need to remove the instrument cluster and at the back in the middle is a single phillips screw in a hole marked "KTV" I think. Unscrew and resccrew into the hole next to it also marked "KTV". That will reset the function.
Apr 30, 2010 | 1993 Isuzu Trooper
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Electro Med Services...
