Question about Measuring Tools & Sensors
Capabilities of a Vector VEC080 Smart 2amp battery charger
I have a Vector Smart 2amp battery charger for a 12 volt system. I don't have a instruction booklet, and I was wondering what it's capabilities are. Thank you, Simon
2 Suggested Answers
  • 86 Answers
SOURCE: instruction booklet for Vector 090 battery charger
Here you go:
http://www.battery-rechargeable-charger.com/vector-car-battery/vector-car-battery-owner-manual-VEC090.pdf
Posted on Mar 08, 2009
I need a power charger for a veco 12 pod 450 amp 12 volt jump start system .
The smart thing to do is, after using it for a jump start, leave it connected for 5 minutes and it is charged again... otherwise a normal 12 V charger will do on the clamps that go to the box... I use a 12V Stanley 25 amps when needed. But most of the time I keep it connected for 5 minutes and do not worry about it.
Jun 23, 2014 | JUMP START SYSTEM
How many volts I have a charger that has different volts which one to set it on I have a whistler 1610 just trying to put the charger on the right voltage
Most automotive electronics work on a 12 Volt DC system. You must be using adapter capable of providing about 12 to 14 volts because car batteries provide 12 volts; but car alternators put out 13.8 volts. Do not attempt to connect to an adapter that put out AC voltage!
May 21, 2014 | De-1610 Radar Detector With Car Charger
Instructions for vector veco22 jump start system
This company took over the Vector line from Black & Decker who bought out Vector. They should be able to help.
Automotive & Electronic Products, Spotlights & Worklights Battery Chargers, Jumpers, Inverters, etc. Baccus Global
T: 877-571-2391
(Mon-Fri 9:00AM-5:00PM EST)
customerservice@baccusllc.com
Click Here For Service Page
Apr 14, 2013 | JUMP START SYSTEM
I don't have a manual for my small Black & Decker Smart Charger. I'm trying to charge the battery on my '07 Honda Rebel 250cc. It has settings for 2/6/12 volt batteries. How do I hook it...
You just need to set black & decker charger to 12V . Don't make mistake while connecting + / - leads. + lead usually come with Red color cable. You can use the AVO tester to justify the lead cable. The charging time is normally about 10 -12 hours (or just just check the status on your charger display). If your charger does not has trickle charge facility, you have to disconnect your charger after 12 hours continuous use.
Also, you can find the guidance about your charger here :
www.blackanddecker.com/power-tools/VEC1087CBD.aspx
Regards
Sep 22, 2011 | Honda CB 250 Motorcycles
How long does it take to charge CCA 7000 battery ( car ) when I use SE-2158 battery charager wih 2 AMP/12 VOLT
2amp 12 volt is a slow charge it will take about 6 or more hours. when the needle on charger is down in green to full charge its fin. hope this helps
Sep 13, 2011 | SE3010 2003010 Amp Manual Starter and...
How do you recharge the vector? Don Rutledge
VECTOR VECO12B, JUMP´N CHARGE SMART BATTERY CHARGER.
Hola a todos, yo he comprado recientemente (Febrero 2011) este sistema. Yo he tenido el mismo problema el cual no carga la bater?a interna del sistema. El sistema de carga de bater?as funciona bien pero el sistema de jump-starter no funciona.
Luego de hacer varias pruebas, de leer en internet y analizar el problema, yo llegu? a la conclusi?n de que la bater?a interna esta da?ada o fuera de especificaci?n.
Que sucede? Lo que pasa es que la bater?a interna del jump-starter se encuentra en un nivel de tensi?n (Voltios) se encuentra demasiado baja, lo cual no es suficiente para que el cargador lo vea como suficiente para iniciar la carga, muestra la falla F01 o F02.
Lo que yo realice fue lo siguiente: usando el cable de carga de 12 volt DC, yo coloque un extremo conectado al salida de 12 volt DC desde jump-starter y el otro extremo del cable yo lo conect? con los cables auxiliares a una bater?a externa. Esto hace que se conecte la bater?a interna del jump-starter, con la bateria externa. Esto sin usar los cables de pinzas para bater?as.
Bajo esta condici?n yo conect? el jump-starter a una toma de 110 volts AC y yo lo encend? y luego yo seleccion? el nivel de carga (2, 4 o 6 Amps). El cargador inici? la carga de las dos baterias, (la bateria interna del jump-starter y la externa).
Esto hace que la corriente de carga se distribuya equitativamente (dependiendo de la impedancia de cada bater?a) entre las dos bater?as.
Yo lo deje en esa condici?n por 12 horas, siempre chequeando la condici?n del sistema.
Luego de ese tiempo, yo desconect? el sistema y yo medi en el socket de 12 volt DC, la bater?a interna y subi? a un nivel de 11,50 volts DC. Desde ese momento el jump-starter, comenz? a reconocer la bater?a interna como buena, y yo lo deje dos horas carg?ndose a si mismo, y luego de esto, el nivel de tensi?n era de 14,40 volts DC.
Yo apagu? el cargador y el sistema quedo cargado dispuesto para trabajar.
De todo esto yo deduzco que el problema era la bater?a interna la que no tenia suficiente nivel el?ctrico para que iniciara el cargador de baterias su trabajo.
Saludos, yo espero que esto le sea de ayuda para todos.
Ali, desde Venezuela.
alilo07@hotmail.com.
Electronic translate
VECTOR VECO12B, Jump'n CHARGE SMART BATTERY CHARGER.
Hello everyone, I recently purchased (February 2011) this system. I have had the same problem which does not charge the internal battery system. The battery charging system works fine but the jump-starter system does not work.
After various tests, online reading and analyzing the problem, I came to the conclusion that the internal battery is damaged or out of specification.
What happens? What happens is that the internal battery jump-starter is in a voltage (V) is too low, which is not enough for the charger to see it as sufficient to start charging, it displays the fault F01 or F02.
What I made was this: using the power load of 12 volt DC, I placed one end connected to 12 volt DC output from jump-starter and the other end I connected with the auxiliary cable to an external battery . This makes connecting the internal battery jump-starter, with the external battery. This without using the battery cable clamps.
Under this condition I connect the jump-starter to a power of 110 volts AC and I turned it on and then I select the level of charge (2, 4 or 6 amps). The charger begins charging the two batteries (internal battery jump-starter and external).
This makes the load current is distributed equally (depending on the impedance of each battery) between the two batteries.
I leave it in that condition for 12 hours, always checking the condition of the system.
After that time, I disconnect the system and I measurement in the 12-volt DC socket, the internal battery and up to a level of 11.50 volts DC. Since then the jump-starter, began to recognize the internal battery as well, and I leave two hours charging himself, and after that, the level of tension was of 14.40 volts DC.
I turned off the charger and the system is loaded ready for work.
From all this I deduce that the problem was the internal battery which did not have enough power level to initiate the battery charger work.
Greetings, I hope this is helpful for everyone.
Ali, from Venezuela.
Jan 30, 2011 | JUMP START SYSTEM
Have lost instructions, it is a Vector battery charger, small but handles 12 volt and want to use to rechrge a lawn mower battery, is it safe to do.??
It will "jump start" the mower but I don't think it will function as a battery charger. It may, but I've never heard of it.
For Vector Products Support and Customer Service, please contact Black & Decker at 1-800-618-5178. Select the "Customer Option", then state the word "Operator" to speak to someone quickly. Their hours are 8 a.m. to 4 p.m. EST.
Jun 19, 2010 | JUMP START SYSTEM
Battery charger on 2008 Chevrolet Equinox
most chargers have a few different settings you want to put it ona slow charge for about 4-6 hrs bye slow charge I mean it should have a 2amp or a3amp trickle charge unless you are attempting to start the car immeditly the you will you the setting labled starting
Mar 01, 2009 | 2008 Chevrolet Equinox
Measuring Tools & Sensors Logo
82 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
