Question about Salton PC4 Popcorn Maker
Assembly How to clean and re assemble
How do I clean the Prism/LCD assembly on Eiki LX-85
LCD panels with the prism assembly,
put the assembly into the water,clean with some kitchen cleaners
to dry the assembly up with hair dryer
suggestion: keep the panels and the prism as a assembly,do not take the panels apart from the prism.
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
skype:lampdeng
Mar 03, 2014 | Office Equipment & Supplies
Dirt on the prism LCD assembly
LCD panels with the prism assembly, put the assembly into the water,clean with some kitchen cleanersto dry the assembly up with hair dryersuggestion: keep the panels and the prism as a assembly,do not take the panels apart from the prism.
After each copy i see dot on the sheet
1 Check the Copyboard Cover, Copyboard Glass, and Standard White Plate
  • If any of these parts is soiled, clean it with a moist cloth. If scratches are found, replace it.
2. Checking the Charging Assemblies
  • a. Check each charging assembly for dirt and a fault in its charging wire/charging brush (scratches, deformation).
  • b. Clean the charging wire, grid wire, and shielding plate of each charging assembly. (Dry wipe the part with lint-free paper; then, clean it with alcohol. If dirt cannot be removed, replace it.)
  • c. Check the height of each charging wire.
  • d. Check to see each charging assembly is properly set.
  • e. Check the charging spring (especially of the separation charging assembly) for rusting.
3. Checking the Developing Assembly
  • a. Check to make sure that the rolls on both ends of the developing assembly are in contact with the photosensitive drum.
  • b. Check to make sure that the surface of the developing cylinder is coated with a uniform layer of toner.
Mar 21, 2011 | Canon CLC 1120 Color Copier
Error e0610096 in canon 1140
The Service manual say:
E061 is an error code associated with the mechanism controlling the surface
potential of the drum, and points to the following:
(The notation "xx" of detail code indicates the color of the developing
assembly; e.g., xx=01: M, xx=02: Y, xx=03: Y, xx=04: Bk.)
Detail code: 0096
Description: Vd2 is 550 V or less.
Possible cause: The Vd2 lower limit is reached
Step 1
Checks: Is the setting of
COPIER>ADJUST>V-CONT-M/C/
Y/K in service mode identical to the
settings recorded on the service label?
Yes/No: NO
Action: Enter the settings from
the service label newly.
Step 2
Check the detail code in service
mode (COPIER>DISPLAY>ERR).
Is it 0000 or 0001? YES Go to step 3.
Is it 0010? YES Go to step 4.
Is it 0020? YES Go to step 5.
Is it 0030, 0031, or 0032? YES Go to step 9.
Is it 0040? YES Go to step 12.
Is it 0050, 0051, 0052, or 0053? YES Go to step 16.
Is it 0070, 0071, xx80, or xx81? YES Go to step 19.
Is it 0060 or 009x? YES Go to step 20.
Step 3: Potential sensor unit
Checks:
Turn on and off the power switch.
Does LED1 on the potential
measurement PCB remain on
during potential control?
NO - Replace the potential sensor unit.
YES - Check the wiring from the
DC driver PC to the potential
sensor. Turn off and then on
the power switch; if the error
is indicated once again, go to
step 2.
Step 4: Pre-exposure lamp
Checks:
Does the pre-exposure lamp turn
on during copying operation?
NO - Check the wiring from
the DC driver PCB to
the pre-exposure lamp;
if normal, replace the
pre-exposure lamp.
YES - Check the potential
sensor unit. Turn off and
then on the power switch;
if the error is indicated
once again, go to step 2.
Step 5: Primary charging assembly
Is the primary charging assembly
connected properly?
NO - Connect the assembly
properly.
Step 6: Primary charging assembly
Is the primary charging wire
broken or soiled?
YES - Clean or route the charging
wire once again. Turn off and
then on the power switch; if
the error is indicated once
Step 7: Primary charging assembly
Are there traces of leakage on the
primary charging assembly?
YES - Replace the primary
charging assembly.
Step 8: High-voltage cable
Is there electrical conductivity
from the primary charging wire to
the high-voltage transformer
(HVT-DC)?
NO - Check the primary highvoltage
cable.
YES - Replace the HVT-DC
PCB. Turn off and then
Step 9: HVT-DC PCB
fitted properly?
NO - Fit the assembly
properly.
Step 10: Primary charging grid plate
Is the grid plate of the primary
charging assembly mounted
properly?
NO - Mount the grid plate
properly.
Step 11: High-voltage cable HVT-DC PCB
Is there electrical continuity from
charging assembly to the highvoltage
transformer (HVT-DC)?
NO - Check the grid highvoltage
cable.
Step 12: Post-cleaning charging assembly
Is the post-cleaning charging
assembly fitted properly?
properly.
Step 13: Post-cleaning charging assembly
Is the post-cleaning charging wire
broken or soiled?
YES - Clean or fit the charging
wire properly.
Step 14: Post-cleaning charging assembly
Are there traces of leakage in the
post-cleaning charging assembly?
YES - Replace the postcleaning
charging
assembly.
Step 15: High-voltage cable
assembly to the high-voltage
NO - Check the post-cleaning
high-voltage cable.
Step 16: Laser exposure system
Is the movement of the laser shutter
normal?
NO - Check the shutter
assembly
Step 17: Laser exposure system
Is the dust-proofing glass or the
bending mirror soiled?
YES - Clean it.
Step 18: Laser exposure system
Is the laser power normal? (See the
descriptions given for how to adjust
the laser power.)
NO - Adjust the laser power.
If output is absent,
replace the laser unit or
the laser driver.
YES - Check the
photosensitive drum for
grounding; if normal,
replace the
(After replacement,
execute the work under
II. C. 2.)
Turn off and then on the
Jan 13, 2011 | Canon CLC 1140 Copier
There seems to be dust behind the screen panel i live on a gravel road is there a way to clean the screen or what do i do
What you have to do is remove the front screen assembly by removing the screws loacted at the bottom of the screen frame just under the frame lip. Lift the screen assembly up from the bottom to disengage the holder clips at the top and set the screen assembly to the side. On the inside of the screen, the part that faces the projection mirror assembly you can use some Windex and paper towels to clean the surface. On the outside do not use Windex as this will breakdown the protective finish used on the viewing side of the screen. To clean the viewing side, use a special cleaner also used to clean computer display screens. Re-install the screen assembly and you are done.
Jan 21, 2010 | Hitachi 61SDX01B 61" Rear Projection...
2004 silverado 4x4 2500 left front wheel bearing
  1. Raise and support the vehicle.
  2. Remove or disconnect the following:
    Tire and wheel assembly Caliper and rotor Wheel speed sensor and brake hose mounting bracket bolt from the steering knuckle Electrical connection for the wheel speed sensor Front drive halfshaft assembly on four wheel drive models Hub and bearing assembly mounting bolts Hub and bearing assembly O-ring seal from the steering knuckle bore (2500 series)
  3. Clean and inspect the O-ring seal
To install:
  1. Clean all corrosion or contaminates from the steering knuckle bore and the hub and bearing assembly.
  2. Install the O-ring to the steering knuckle (2500 series).
  3. Lubricate the steering knuckle bore with wheel bearing grease or the equivalent.
  4. Install or connect the following:
    Hub and bearing assembly Hub and bearing assembly mounting bolts. Tighten the bolts to 133 ft. lbs. (180 Nm). Front drive halfshaft assembly on four wheel drive models Electrical connection for the wheel speed sensor Wheel speed sensor and brake hose mounting bracket bolt to the steering knuckle. Tighten to 106 inch lbs. (12 Nm). Rotor Tire and wheel assembly.
You can go to autozone.com and register for free online repair manual with everything you need.
Jan 19, 2010 | 2004 Chevrolet Silverado 2500 Crew Cab
When loading a disc it will show loading and then it will show no disc and I have run a cleaning disc but did not help
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc' or CD NOT PLAYABLE, code is the result of a failed or burned out lens. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more.
Nov 14, 2009 | Philips HTS-6500/37 System
What about Fehlercode: 6A00
6A00 is the error code when the purge assembly is jammed. That's the cleaning assembly on the right where the printhead parks. Check for any paper scraps in that area, and see if the wiper section is stuck above the cleaning pads. Sometimes you can just clean with a wet Q-tip around the sliding parts, otherwise you need to replace the purge assembly.
Nov 13, 2009 | Canon Pixma MP500 All-In-One InkJet...
Print smears
Hi Allan:
Sounds like you need to replace the drum pivot plate assembly. This assembly is what cleans the drum assembly prior to putting the image on the drum. The pivot plate assembly has a rubber drum cleaning blade on it and when the printer begins to print a page it cleans the drum first. If the cleaning blade or the pivot plate are deffective then the drum will not be cleaned properly leaving smudgy areas on the drum.
Aug 13, 2008 | Xerox Phaser 8560DN Laser Printer
Panasonic FP7117 Photocopier Fault code E3 11
that is for corona assembly first of all confirm that it is charger assembly or lower assembly .first of all put out lower assembly from machine and on copier if coderemoves then clean this assembly and change corona wires .if code still clean charger assembly and change corona wire.cod will bi removed.mian jee
Jul 14, 2008 | Panasonic Office Equipment & Supplies
Salton PC4 Popcorn Maker Logo
Top Salton Kitchen Appliances - Others Experts
Gareth Cockram
Gareth Cockram
Jerry Greenberg
Jerry Greenberg
tsalagi152
Are you a Salton Kitchen Appliances - Other Expert? Answer questions, earn points and help others
