Question about Brother MFC-8660DN 5-in-1 Laser Multifunctional Printer
Drum near end
Message says drum near end
timeattack
SOURCE: Replaced new drum unit but LCD keeps saying Drum Near End of Life
Front cover must be open
Press The "Clear" key on the top panel
Press 1 to reset the drum count
Close the over
Posted on Feb 06, 2009
SOURCE: MFC-8460N Drum Changed - cannot clear DRUM NEAR END message
This sometimes happen when you dont use genuine cartridges/drums, you can leave it flash just let everyone know to watch for changes in print quality since you will no longer have a warning for this drum. when its near its end.
Posted on Nov 11, 2009
MNfisherman
  • 11896 Answers
SOURCE: drum life near end
Depends on the usage of the machine. If hardly used, you should get a years worth. But here's what you can do:
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Posted on Apr 19, 2010
  • 1382 Answers
SOURCE: I recently noticed a message that said
This message would continue to appear if the drum unit counter was not reset when you installed a new drum.
To reset the drum unit counter, follow the instructions below:
  • Press Menu on the Control Panel.
  • Press the Up or Down Arrow key to select Machine Info..
  • Press OK.
  • Press the Up or Down Arrow key to select Reset Menu.
  • Press OK.
  • Press the Up or Down Arrow key to select Drum.
  • Press OK.
  • Press 1 to reset the drum unit counter.
Thank you !!
Posted on Jun 09, 2010
jasbrotheroe
  • 3 Answers
SOURCE: I get the code "Drum near end" although the Drum
open the front cover and press the clear back button then select the yes option to screen menu
Posted on Aug 18, 2010
How to fix brother printer drum error troubleshooting and routine maintenance
I still receive the error message "Replace Drum", "Drum End Soon", "Drum Near End", or "Drum Stop" after I replace the drum unit with a new one. The following error messages will continue to appear if the drum counter was not reset when you replace the drum unit with a new one.
  • Replace Drum
  • Drum End Soon
  • Drum Near End
  • Drum Stop
To clear these error messages, you need to reset the drum counter as instructed below.
If you want to clear an error message related to the toner replacement, click here to see how to clear an error message after you replaced the toner cartridge.
"What is the difference between the toner cartridge and the drum unit?"
Please reset the drum counter only when you replace the drum unit. If you reset the drum counter during the life of the drum unit currently being used, the remaining drum life will not be displayed accurately.
  1. Make sure that the machine is turned on.
  2. Open the front cover.
  3. Press Clear or Clear/Back on the control panel.?
    NOTE: The layout of a control panel differs depending on the model, but the Clear or Clear/Back button is located on the right side of the LCD screen as shown in illustration.
  4. Do one of the following.
    • If your Brother machine has a numeric keypad:
      Press 1 to reset the drum counter.
    • If your Brother machine doesn't have a numeric keypad:
      Press the Up Arrow Key to reset the drum counter.
  5. When the LCD shows Accepted, close the front cover.
Sep 11, 2017 | Brother Office Equipment & Supplies
did you do the reset procedure? if not it's in your owners manual under the section "replacing the consumables".
hth,
razors
Nov 29, 2011 | Brother HL 5250DN Laser Printer
My Brother 8065 says "Drum
  • This message would appear if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
  • This message would continue to appear if the drum counter was not reset when you replaced the drum.
    To reset the drum counter, follow the instructions below:
    1. Open the front cover.
    2. Press the Clear/Back key.
    3. Press 1 to reset.
    4. Close the front cover, pressing firmly on each side until they click into place.
Jan 25, 2011 | Office Equipment & Supplies
Does the 'Drum Near End' message for MFC 8460N mean to indicate the toner cartridge needs replaced?
Same with our Brother 8640N, drum near end means toner is nearly to end but sometimes even you replace bew cartridge is appears this message. TONER LIFE END message need to replace cartridge.
Dec 17, 2010 | Brother MFC-8660DN All-In-One Laser...
Brother DCP 8060 is displaying drum near end what does thic mean
After approx. 25000 pages you should replace drum unit
Oct 04, 2010 | Brother DCP-8060 All-In-One Laser Printer
Drum End Soon
You will soon need to replace the drum. Its considered a consumable just like the toner cartridges. You can purchase the drum anywhere that sells brother pruducts.
May 24, 2010 | Brother HL4040CN Laser Printer
Drum life near end
Open front cover
Press Clear/Back
Apr 19, 2010 | Brother MFC-8860DN Printer
Message: Drum near end What does that mean?
that's mean drum life end (nearly) arrange new drum for replacemnet or contact you service engineer
Sep 11, 2009 | Office Equipment & Supplies
Feb 24, 2009 | Brother MFC-8460N All-In-One Printer
Brother MFC-8660DN 5-in-1 Laser Multifunctional Printer Logo
12 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
