Question about Toshiba Regza 37HL17 37 in. LCD TV
Removing stand bracket from tv/toshiba
Cant remove bracket from stand
SOURCE: stand
3 or 5 scews at the back of the set just above the stand . remove these then 2 persons lift the tv straight up leaveing the stand behind. you will the have to lay the tv flat or put it straight on the wall
thats if you have fitted the wall brackets of course
Posted on Jun 01, 2008
  • 814 Answers
SOURCE: question on toshiba tv - fixya post
Found this on the www.Toshiba.com website. Q. How do you remove the stand?
Models: 26HL37, 26HL47, 32HL17, 37HL17, 42HL17, 32HL37, 26HL67, 32HL67, 37HL67, 42HL167, 42HL67,
47HL167, 52HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00078
1. Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface. NOTE: Extreme care should always be used when removing the pedestal
stand to avoid damage to the LCD panel.
2. Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can
be removed without tools.
3. Remove the five screws shown in the diagram below. This will allow removal of the pedestal stand.
4. Once you have removed the five screws holding the pedestal stand in place, remove the stand from the TV by
sliding the stand away from the TV. The Toshiba customer service number is 1-800-631-3811. Hope this helps you with your problem.
Posted on May 17, 2009
dsacco86
  • 1077 Answers
SOURCE: need to remove tv stand
There are 4 screws you need to remove to get the stand off.
There is 2 vertical screws near the ANT/CABLE port and 2 more vertical screws near the power cord.
The stand should slide out after that.
  • 2318 Answers
SOURCE: i want to remove stand from 42 to hang on the wall 1080
Click here to download the user's guide and check page # 5 for instructions on how to remove the pedestal stand.
Posted on Jan 02, 2010
SOURCE: How do I remove the stand from a Toshiba TV
Mine isn't exactly the same model (I've a Toshiba Regza 32AV615DB) but on mine there are 4 small black screws at the back of the TV, near the lower edge. They're recessed into channels and quite difficult to see. Remove these 4 screws and you can lift the TV off the stand. Good luck.
Posted on Feb 04, 2010
How do i remove the table stand from my 37" toshiba regaza tv?
there should be 4 screws in the back of t.v unscrew them and it will lift off.
Jun 01, 2010 | Toshiba REGZA 47HL167 TV
How can I remove the the stand so I can mount it on the wall
1)Carefully lay the front of the unit face down on a flat,
2)Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3)Remove the five screws shown in the diagram below. This will
4)Once you have removed all five screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
5)Now you are ready to install the wall mount brackets
I hope this helps and good luck!
Feb 28, 2010 | Toshiba 32HL67 32 in. LCD Television
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
How to remove tv stand from toshiba 42 inch lcd model 42hl167
Remove 5 screws as shown in below image to remove stand of TV.
It is also mentioned in user manual of TV page-5, click Toshiba Support to download a copy, if required.
Thanks.
Aug 30, 2009 | Televison & Video
I want to wall mount my 26LB30QD but the stand needs to come off, there is nothing in the instuctions on how to remove the stand, please advise.
With the tv laying flat on to the screen, remove the two screws in the recessed holes. Then remove the two screws above towards the input panel, one under AUDIO-L/AUDIO-R and the one under HDMI-1. The stand should easily slide out.
Mar 06, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Question on toshiba tv - fixya post
REF:FAQLCD00078
Dec 22, 2008 | Toshiba 42HL167 42 in. LCD Television
I am trying to remove the stand on a LG Model : 52LB5D. I have removed the 4 screws on the back but can't remove stand. It feels like there is another screw or something holding it in.
If you are looking at the back of your tv there is the stand bracket with a screw on each side. remove those screws and nothing will happen. that is the problem i was having but if you look right above the ones you just took out and there is going to be a black screw. take those off from each side and it will fall off.
Dec 09, 2008 | Televison & Video
Remove base of Insignia ns-ltdvd26-09
to remove base from insignia tv
1)remove plastic cover from bottom rear of tv
2)remove 8 philips head screws on rear of tv above base
3)pick up tv and base will come off
once you remove it you realize how easy it is
Jun 29, 2008 | Insignia LCDTV26 26 in. Television
Stand
How do I remove the stand?
Apr 13, 2008 | Toshiba Televison & Video
Toshiba 26HLV66
you will need to remove the jack pack cover on the back of the unit (plastic cover), it should pop off, then remove the screws holding the stand on (should be 5 if memory serves).. after that the stand should slide away from the tv.
make sure your wall bracket kit can support the weight and that the screws you embed in the wall are using hercules hooks, anchor bolts, or something similar... last thing you want is a dead tv and ripped up drywall.
hope this helps,
trin
Nov 16, 2007 | Toshiba 26HLV66 26 in. LCD TV/DVD Combo
Toshiba Regza 37HL17 37 in. LCD TV Logo
18 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
