Question about Sony KP-51HW40 51" Rear Projection Television
Turn on tv picutre off and on then steady - Sony KP-51HW40 51" Rear Projection Television
No picutre
Contact the authorized service centre for LG in this case. It will be best. Gopakumar Gopalan Google
Especially to this model LG TV.
Mar 25, 2014 | LG 55LM6200 55 1080p 120Hz 3D WiFi LED...
Jvc lcd picutre won't show
as you said jvc lcd tv won"t show. if lcd tv have good power supply & main board. that will be inverter board gone in. replace it will be solve you problem. good luck!
Sep 03, 2012 | JVC LT-42X579 42 in. LCD TV
My screen is blue and it wont let me see anything
Hello
Your TV is not getting any signal at all to process, or the tuner inside your TV is faulty. Blue back screen comes, when there is no signal to any of its input or faulty tuner. Just connect the tV with any other video source, like VCR or DVD , connected to its AV terminals and set the tV to take input AV, and check whether picutre comes in or not. If picture comes with AV connection, make sure that your tVs tuner is faulty and should be replaced. If no picutre comes with AV connections too, the Chroma Ic insie your TV is faulty, and should be replaced. OK.
Feb 17, 2011 | JVC AV-32S575 32" TV
Sony kp-53v90 no picture but has sound and display lettering
The tv have a problem known as a convergence problems,it dead.The tv convergence board require changing 2 STK convergence ICS and some or all it resistors to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 05, 2010 | Sony KP-53V90 53" Rear Projection...
When initially turned on TV will alternat between picutre & black
When the tv goes to a black screen does the sound remain on? Also,if you listen carefully can you hear any arcing noises in the back of the tv?
Aug 03, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Tv has sound but no picutre
HI FRIEND
its cathode ray tube or a colour wheel problem,,,check it,
thank u,,,,,,,,
May 03, 2009 | Westinghouse SK-32H240S Television
Faded and out of focus picture
Your TV has a burnt CRT base socket. Replace that, it is not a tough job, but make sure that you get the exact same type of base socket.
Jan 14, 2008 | Panasonic CT-34WX15 34" TV
Sony KP-51HW40 51" Rear Projection Television Logo
21 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
