Question about Alcatel Lands Phones
Turn off voicemail - Alcatel Lands Phones
My ZTE phone goes to voicemail and never rings why?
It is either not registered on the cell network or is out of signal and defaults to voicemail. Or Voicemail has been enabled in error. find out from your local phone shop which code to enter to turn voicemail off. ( my provider uses 1261 on giffgaff to turn voicemail on and 1262 to turn it off.) It depends on the network as to what code you need to use.
Jun 02, 2016 | ZTE Cell Phones
Turn off voicemail 6408D+
Turning off voicemail is usually done by the voicemail administrator, they can reset passwords and add or delete a mailbox on an extension. The number of rings before going to voicemail is usually system wide, and that program is changed by whoever programs your phone system.
Apr 21, 2014 | Avaya Definity PBX Phone 6424D+ Gray
How to turn off voicemail on samsung s4
To turn on voicemail on s4 go to settings then open voicemail settings. Here you can change the voicemail settings
Nov 16, 2013 | Cell Phones
Turn on voicemail indicator on my vtech
On most VTech phones the voicemail indicator turns on when someone leaves a message on the voicemail system offered by your phone company. Many phone companies have such a system, which takes messages when your phone is busy. You'll have to contact your phone company for instructions on accessing their voicemail system.
Mar 22, 2012 | Lands Phones
Can receive and answer calls but greeting announcement is silent.how do I turn on greeting.
Please tell me the model of your phone.However,you can do this with the use of your phone profile i.e from the phone click on it the screw down to the profile then click on it screw to setting or turn setting from there you will be able to get to greeting setting or turn from this step you will be able to activate the turn again .
Good luck.
Thanks for using fixya.
Sep 06, 2011 | Cell Phones
Never used voicemail ,just used answering machine . Now voicemail light keeps flashing and symbol for voicemal appears on phone screen. I really do not know how to turn of voicemail or how to access...
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Aug 22, 2011 | Vtech CS612954 Cordless Phone
Turning on my voicemail
Depending on the carrier it can be a little bit different. Basically you need to dial the voicemail number from your cell, most commonly 123. After this an automated machine will guide you through the setup.
Hope this helps,
Joe
Feb 19, 2010 | Samsung U900 Soul Cellular Phone
I have voicemail through my telephone company. Recently my panasonic phone system kxt7731 has been answering the calls for voicemail, instead of going to my phone company voicemail. I am being left...
I have voicemail through my telephone company. Recently my SAMSUNG SGH-D980 phone system has been answering the calls for voicemail, instead of going to my phone company voicemail. I am being left messages that I cannot retrieve! I would like to "turn off" the voicemail function of my phone system. I'm not sure why the phone changed from working "properly" to now picking up voicemail calls. Thank you for any help you can give me!
Sep 14, 2009 | Cell Phones
Turning off answering machine
Hi
you cannot retrieve messages off the voicemail system I am afraid. If this is down to malicious calls and police are involved speak to O2 as they may have a way to supply evidence direct to police?
Regarding turning off voicemail here are the codes you need, dial 1750 to activate voicemail, 1760 to deactivate voicemail, 901 is used to call in and listen to voicemail and additional options i.e. greeting, pin etc.
WARNING! By turning off voicemail you will ERASE any messages in your voicemail as it resets each time deactivated! So only do this is messages are no longer required!
Hope that helps?
Apr 26, 2009 | O2 X2i Cellular Phone
Voicemail icon won't go away
hai... go to settings/intial setup/master reset/it ask security code type 000000 , it will get cleared
May 06, 2007 | Motorola Mobility RAZR V3
Lands Phones Logo
18 people viewed this question
Top Alcatel Lands Phones Experts
Gyula Lacz
Unlockingcom
Are you an Alcatel Lands Phone Expert? Answer questions, earn points and help others
