Question about Earthwise 1850 PSI Electric Pressure Washer
Earthwise pressure washer
Cannot change wand
Why won't the hose connect to the washer?
The connection is made at the bottom of unit.
should be standard garden hose.
sometimes I find if I gently hold hose against connection point then rotate counterclockwise until I feel a click! then ( without lifting hose) rotate clockwise and hose should now be threaded onto power washer.
Oct 09, 2016 | Earthwise 1850 PSI Electric Pressure...
Will start and run fine water comes out but has no pressure
Maybe bad pump. Remove wand and wand hose, run machine with water in. High pressure water coming out of wand/hose connection, bad wand or hose. No high pressure water, bad pump, replace.
Apr 01, 2016 | Simpson PS2600 PowerShot Commercial-Duty...
Why is my detergent not working on my new k5 pressure washer
If you are referring to an electric washer,The wand for the detergent is a double action wand. You usually pull the wand end out for low pressure and detergent flow.
May 30, 2014 | Garden
HOw to attach soap bottle to earthwise 1850 pressure washer
It should have a tube on it put it in your bleach bottle and use the black tip for dispense 1/2 bleach/1/2 water
Aug 08, 2013 | Earthwise 1850 PSI Electric Pressure...
Poor pressure and water comes out of the detergent hose
replacing the wand wont solve the pressure problems, its going to be the pump problems, pump create high pressure to the wand. hope that help
Jul 21, 2009 | Karcher 2500 PSI Pressure Washer
Cleaning solution isn't siphoning to washer wand
you need to use i believe the black tip where there in least pressure it does not work with pressure
Jun 23, 2009 | Karcher 2500 PSI Pressure Washer
Earthwise 1850 PSI Electric Pressure Washer Logo
43 people viewed this question
Top Earthwise Garden Experts
Steve Sweetleaf
Steve Sweetleaf
Call Bill
Call Bill
montehammons
Are you an Earthwise Garden Expert? Answer questions, earn points and help others
