Question about JVC TV-20241 20 in. TV/VCR Combo
Technika child lock
Unable to select tv
I have no remote and I think the TV is on child lock, it is a technika tv LCD 40" the stand-by light comes on but you can not get the tv to start. Is there a way to "factory reset" this tv without using a...
not sure it this will work on ur tv but try to unplug the tv, and push the power button on the TV and hold for 30 or more seconds,, on some TV's this little trick resets back to Default.
Jan 26, 2015 | Televison & Video
Lock symbol on screen of my fukuda tv.unable to change channel
sounds like your TV is Locked.Child lock is on.try to disable the child lock. user manual will guide you to do this.Good luck
Jul 14, 2011 | Televison & Video
Trying to auto re-tune but TV asks for a passcode for Technika DV3-T 32" LCD
Hello
Get it it menu option surf to Child Lock Settings option.
Press [Up or Down] button to select CLEAR ALL item, press [Left or Right]
button to unlock all the locked items.
Press [Up or Down] button to select CHANGE PASSWORD item,
press [Left or Right] button to enter INPUT NEW PASSWORD
menu, first input new password and then confirm the
new password, the password will be changed.
Now you can auto tune your TV, by entering the new passcode. OK.
Jul 02, 2011 | Televison & Video
I have an AKAI TV CT-2877A (M) and the "child
As long as you remember the "CODE" The child lock on a TV is a wonderful thing.
The lock sometimes causes unwanted trouble--if it gets accidentally turned on and you don't know the code, you can find yourself unable to fully enjoy the full range of available television stations. Please apply the following possible 5 different solutions taht verified by different users and than hopefully you'll be back to watching regular TV ....
  1. Bring Up TV Menu ; Power on the television with the activated child lock on. Push the "Menu" button on the remote control. A series of features appears on the screen, ranging from the overall TV functions to the video display and the audio setup features ,Choose "Options" and a new menu appears on the screen. From the new menu select "Child Lock." The exact setup selection is going to vary slightly, although the child protection is always referred to as either "Child Lock" or "V-Chip." The V-chip is the actual chip built into the television that blocks out certain television programming.
  2. Try a "factory reset" action... This should be somewhere in the TV menu system. However Please note that will clear everything, so you may need to re-program every things..the channels etc.
  3. Hold the lock key in the remote for few seconds . you will get the lock tool bar . you can unlock it there
  4. Hold the display button on the remote for 10 seconds.
  5. As a The last solution which is common for all TV sets..
    • Try to find the User manual for your television. The section In the manual about how to set the child lock feature will also explain how to unlock it.
    • Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A commonly used code is "0000."
    • Unplug your television for at least 1 hour . The internal memory battery of the TV is what helps remember what your code. When TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code back to "0000 " again...
if the problem still continues you have to email to : http://www.akaiusa.com/
Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :) Thanks
Jun 26, 2011 | Televison & Video
Cannot tune my technika tv due to a child lock?
have you tried to put in 0000 or 1234, this usually comes from the factory, unless to have put one in yourself.
Mar 25, 2009 | Televison & Video
Child lock on deca tv from harvey norman
Simply press "menu"followed by "play" or "stop"to select "general set up".Then press "forward". Use "play" or "stop" to select "child lock" followed by "forward". Child lock should now display "on". Press "play" or "stop" to select "off" and "forward" to make inactive.
Does this helpful or fix your TV?
Nov 17, 2008 | Televison & Video
Childlock on tv without remote
unplug it for and hour or two and plug it back in
usually this will reset the tv's settings and the child lock will be turned off.
Oct 22, 2008 | Televison & Video
JVC TV-20241 20 in. TV/VCR Combo Logo
23 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
