Question about Brother All-In-One Laser Printer DCP7065DN
Printer 7065dn won't collate scans through the top feeder
Won't collate scans in to pdf format
5 Suggested Answers
daryn720
  • 113 Answers
SOURCE: I want to Scan and send by email in PDF format all pages !!
Looking at my manual , it tells me you have a software user guide on the cd-rom ....this is where you will find the answer.
Posted on Jun 02, 2009
brett207
  • 231 Answers
SOURCE: I have a brother mfc7420 when I use the Feeder on
Clean the narrow glass strip at the left hand side, under the doc feeder
Posted on Dec 24, 2009
Testimonial: "yes, that worked. Thank you :)"
  • 241 Answers
SOURCE: paper does not auto feed on top of printer
You could be having feed issues. I would suggest you have a technician clean the paper path sometime the rollers get a little shiney and don't pickup the paper like they should. A certified technician will also replace any rollers if needed and perform a maintenance cleaning.
Posted on May 28, 2010
  • 22 Answers
SOURCE: does the briothers mfc 8840d scan directly to a pdf
well if you got a software disk from brother when you bought the printer if that has a scaning program o it install the disc on your computer and open it, put the paper on the scanner and view the advanced settings on the scan program if it has any otherwise search the settings and find the extension or format that it saves in and change it to what you prefer
Posted on Jul 05, 2010
How do i scan multiple pages in pdf
You can only do that if your printer has a feeder. If it only has a cover and a gloss top where you place 1 sheet at a time, you can only do one at a time.
Aug 27, 2014 | Samsung CLX-3175FN Color Laser All-in-One...
How to configure Brother DCP-7065DN to scan directly to Synology DS412+
I don't believe the DCP-7065DN allows scan to FTP. Brother's models MFC-7460DN and MFC-7860DW do provide this function. Good luck and please share your solution should you find one.
Dec 31, 2013 | Brother DCP-7065DN MFC / All-In-One Up to...
The top left "hinge" won't seat, therefore the top feed can't be used to fax, scan or copy.
It's possible that the hinge of the scanner cover broke. If that's the case, you won't be able to scan from the ADF (Auto Document Feeder). If the printer is still under warranty, please call our technical support team to have the printer replaced.
Aug 10, 2012 | Lexmark Pinnacle Pro901 Inkjet Wireless...
Can you multi page scan, say 3 pages into one file, want to emaqil that file. Don't want to have to email 3 separate files. Re HP8500A
Yes, you can scan 2 or more pages in one file if you scan as pdf file and you use the top feeder to scanned multiple pages. SET YOU SCANNING FEATURES TO SCAN AS PDF not JPEG FILE.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
May 14, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Using automatic feeder to scan a multiple page doc into 1 PDF
Yes you can scan up to 30 files in one pdf , and you have to put documents in auto feeder (face up) and from the pc, scan menu, scan to files, select destination and extension.
That's all
Mar 04, 2010 | Canon PIXMA MX310 All-In-One Printer
Biz hub 250 Pdf printing problem
Hi I am former Konica Tech Support for 26 years. I do some network problem. Y may need to upgrade the copier memory. or this just simple setting. on the printing side I can assure you no problem. there is a setting on the operation panel choosing if you prepared pdf when ever you to e-mail, scan to box or scan to SMB. You can delete the old print driver and the control panel delete your even the printer Icon at the printer and fax folder. Re install the printer and the printer driver. And make sure send a test print. If so happened that you don't have the print driver you can go to Konica web site and download the print driver. There are many kind of print driver. postscript driver and etc. I hope this info will help you and if not you may contact me again.
HH
Aug 20, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Scan with feeder, cuts off the bottom of the document
Hello sir; You may use rubbing alcohol to clean up allthe rollers at document feed unit, it will take care the problem.
Feb 21, 2009 | HP OfficeJet 6310 All-in-One Printer...
Brother MFC-465CN How can we scan multiple documents?
Make a stack of the documents you want to scan and load them in the automatic feeder: The page to scan facing upward, and the top of the page inside. Press the Scan button and start (color or black).
If you choose the pdf format, you will have them in a single file.
Hopr it helps.
Feb 18, 2009 | Brother MFC-465CN InkJet Printer
HP 3055 printing black lines when using collate feature to copy
All you need to do is to clean the small wide glass (that at the LEFT of the main flat big class). The Auto Document Feeder (ADF) specifically uses this glass to scan for copy (and fax). When it is dirty (such as small dirt or particles on the surface which is easy to gain in long run), it will create thin vertical line(s) as the result.
Jan 28, 2009 | HP LaserJet 3055 All-In-One Printer
Brother All-In-One Laser Printer DCP7065DN Logo
16 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
