Question about Westinghouse 55" 1080p 120hz LCD HDTV - Black VR-5525z
Tv turns on, and then shuts off
I can turn on the TV with a remote, but then it shuts off after the big 'W' appears on the screen. I tried turning it on with the power button on the TV itself, but it does not respond, none of the buttons on the TV work. The light indicator is on, the screen appears to work, but the TV won't stay on, it shuts off a second after the 'W' on the screen shows up.
5 Suggested Answers
  • 2336 Answers
SOURCE: White Screen of Death. TV locks up
You will need to replace the power supply or get fix because there aren't too many service parts available anymore.
Posted on Jun 07, 2008
jerryg50
  • 1689 Answers
SOURCE: TV power light comes on but no picture/no sound
The control panel, or the circuit area that reads the control panel, or the uPC is not functioning properly for reading the control command. The service tech will try a new control panel assembly, or the module(s) that have the related circuitry. Once the defective modules are replaced, the tech will leave in the new modules.
When under warranty and these sets are exchanged under warranty, they give you back a set that was serviced from someone else. That is the drawback with having the set serviced under warranty.
Jerry G.
Posted on Feb 10, 2009
freetek
  • 5568 Answers
SOURCE: No power on Westinghouse LTV-46w1 Television
This kind of failure is very common; that is why I suggest that one should keep the old CRT TV, buy a converter and put them both in the garage or basement so they are handy when our s*e*x*y new sets go belly up.
With fair confidence I can say that the main power supply has failed.
If you want to try this on your own, it only will require the removal of a few screws and a flashlight.
- Unplug the set overnight. - Remove the rear housing  - Use some logic and these tips; look for a separate board with larger than average parts on it and seems closer to the power cord than others. This will be the power supply.
Check the board over for something that looks like a part number and record it. If you find more than one, one of them will be the bare board number, the second (sometimes on a sticker instead of printed directly on the board) should be the part number for the assembly.
Search for the Westinghouse service company nearest you and call them with this info. Ask if they repair these or just sell new ones. If it is the latter, don't pitch the old one, continue to look for a repair service that will take it on after you have the new one in place and can watch your favorites again. The new supply will likely cost between $90 - $150 and with a little common sense, most anyone can remove and replace these in the set. Expect any repair to cost about the same as a new supply; US technical labor costs more than Chinese assembly labor.
These supplies can be as reliable as the primitive older type but companies refuse to use the high-grade components necessary to give them a long life so they fail much sooner than the old, less efficient kind known as 'linear' supplies.
Posted on Mar 22, 2009
  • 142 Answers
SOURCE: My Westinghouse LTV-w1 will not turn off. None of
try unplugging tv to reset it,leave it off for a minute,and then plug in
Posted on Jan 08, 2010
We've been experiencing the problem for about a month or so now you try to turn the tv on the green light appears then it shuts off... It does it with the remote and even when trying the actual tv tur
OK, need to know a few things before providing an answer on this one
1) Has the screen flickered in the recent past?
2) Has this ever occurred before?
3) Have you heard any noise coming from the monitor?
4) Has the screen grown dim or brighter lately
Thanks!
Apr 05, 2013 | Computers & Internet
A black rectangle has appeared on the screen, blocking out most of the picture. How do I fix it? thanks
Ur tv still have the funsctions ON like Close Captioning.U have the tv original remote wright?Yes?Tries the remote button like CC on ur tv remote pushes it a couples make sure like CC1,2.3..turn all off.Tries go into the tv Menu tries looking for Closed Captioning functions turn CC1,2,3...turn it all off and Text1,2,3...turn it all off too.These two functions off.Tv will stop this big black box poping up on the tv screen.
Sep 06, 2011 | TruTech PVS31170S1W 17 in. LCD Television
Lost remote. Must do manually on t.v. Two problems:\r\n1) I cannot get channel back on channel 3. It skips from 2 to 4. 2) TV has large black box on screen covering most of screen. I can push buttons...
Try website like Remotes.com to buy the tv original remote to used.U will used the tv original remote to turn to channel 3 with ease.After u have the tv original remote push the menu button go into Closed Captioning functions turn off like TEXT 1,2,3...The big black box will not appear on the screen again.Tv used it manually control buttons up and down channels trying to get to channel 3.U will never get it to tv channel 3 because tv channel 3 was not save on it memory list of on the tv turn manually channels buttons programming memory.Tv have a manual button said MEMU button on it tv front bazel frame?Yes.Might could used the Menu button on the tv frame to get in to turn off TEXT 1,2,3...to stop the big black box to show up on the tv screen again.
Aug 17, 2011 | Toshiba 36A50 36" TV
Tv turns on. A blue screen appears. Then it shuts down in 20 seconds. The timer light blinks repetedly.
Try this:
1) turn on TV
2) from the remote control ..press MENU 2,4,7,0 then ENTER
3) tv will state on screen that it is INITIALIZING.
4) press the RESET BUTTON on front of TV.
5) should be good to go!
Jan 15, 2010 | Mitsubishi WD62627 62" HDTV
Trouble changing device
Your problem may be solved by re-initializing the set. With the tv on use the remote and push MENU,2,1,7,0. A display will come up. Use the up down arrows on the remote to select INITIAL and press the enter key on the remote. That should do it.
May 04, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Big black box across the screen towards the bottom.
In some TV's closed captioning can cause this problem. turn off CC and see if that helps.
Dec 13, 2008 | Toshiba CF36G40 36" TV
Programming my remote to control the sound on my TV
Here is what is called a power scan. It will go through all the codes in the remote and find the right code for your tv.
1)hold down tv button next to sat button in top left corner
2) when all buttons illuminate press 500 into remote
3)press pound sign
4)Hello, please help..
5)hold town tv button again.
6)when all buttons illuminate press big red power button
7)press up arrow once a second until tv shuts off
8)press # pound sign
9)try to turn tv back on w/ big red power button
10)if tv doesnt turn back on try again from step 2 but use down arrow instead
Jul 24, 2008 | DISH Network IR Remote Control
Dish network remote
i would suggest trying power scan again...
3)press pound sign
if this doesnt work try addressing your old remote to the receiver by pressing record from system info screen
Jul 06, 2008 | DISH Network IR Remote Control
Echostar IR remote (Dish)
to set remote to tv
3)press pound sign
to set remote to receiver you need to access system info, if there is no sys info button on your receiver turn power off and press the up arrow, then press record 2 times on the remote,
Apr 30, 2008 | DISH Network IR Remote Control
RCA P52753AT tv will not turn on
the High Voltage splitter needs to be replaced
Oct 06, 2007 | RCA P52939 52" Rear Projection Television
Westinghouse 55" 1080p 120hz LCD HDTV - Black VR-5525z Logo
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
