Question about JVC HR-XVC27U DVD Player/VCR
How to remove caption feature from dvd player
How display captions on TV from DVD player?
The captions availability is part of the DVD program that you are watching. If the movie or feature recorded on the DVD disc has got captions then you should be able to select it as part of the DVD setup menu that shows up on screen when you insert the DVD disc in the DVD player.
Sep 03, 2014 | Televison & Video
I can't get closed caption off my dvd player
Some DVD players cannot handle closed captions. Cheaper or older hardware players sometimes strip out the closed caption data. Players that have a progressive scan mode sometimes block captions when in this mode. And anything that's connected with an HDMI cable can't pass through captions.Most software players that you use when you play a DVD on your computer don't have any way to decode the captions. Windows Media Player can display DVD captions, and Apple DVD Player can display pop-on captions but not roll-up style captions. Certain paid versions of WinDVD and PowerDVD have CC capability. Look in your player's preferences to see if there are any closed caption options.
Thank you for using FixYa, have a nice day don't forget to rate me.
thanks,
REymond
Oct 18, 2011 | LG DBRH197H DVD Player/HDD Recorder
How do you shut off the closed caption feature?
I do not know this dvd player, but on most anything with closed caption, you hit the cc button on the remote until you come to '0' or 'off'. As CC has about 6 channels it can use, but really only channel '1' is used. So you might have to cycle through the CC channels until closed caption disappears. Hope this helps. You might also have a setup menu on this DVD where you can control the CC.
Just cycle though it till you get to '0' or off, exit the setup menu.
Jan 07, 2011 | KLH DVD-221 DVD Player
Can not get closed captions on dvd to play on sony tv with captions on tv set on.
Hi, you might have to turn the CC feature off from your TV and select the CC feature from the DVD disc set up.Refer to page 35 of the owners manual to get the correct language caption on your disc(dvd): basically press the audio key on your remote control until the desired captioning appears.
Jun 21, 2010 | Toshiba SDV395 DVD Player/VCR
By the numbers! How do I turn on the closed
there is no closed captions on dvds, you can use subtitles, very similar to closed captions. just load dvd
look into either extra features or subtitles
it would say "english for deaf/hard of hearing." or just plain english subtitle. either way, it works.
Oct 17, 2009 | Emerson EWD2203 DVD Player/VCR
Sony dvd player... black square appears
this feature is related to the tv.
The black square is an space reserve for text. Most of broadcasting companies dont use it at all. Now to evoid it you go into menu look for close caption options and make sure to send the TEXT feature to off, Again in the TV MENU. Details and information about this feature is in the user's manual, specially how to turn it off.
May 01, 2009 | Sony DVP-NS575P DVD Player
Lost remote!
yeah i agree it's bull sh*t
Nov 23, 2008 | Durabrand DVD-1002 DVD Player
DV2150 Close Captioning
Same problem here.
Instructions for DV2150 say you can access closed caption toggle by going to SETUP, then OTHER then CAPTION, but this (CAPTION) option is missing from the menu. I, too am struggling with the Jeopardy game buzzers, which I cannot program. Was wondering if the lack of "closed caption" is the reason
Dec 28, 2007 | GoVideo DV2150 DVD Player/VCR
Can't get closed caption when i'm playing a DVD
The DVD player needs to have the decoding built into it.
Sep 18, 2007 | Sanyo DP42746 42 in. Plasma Television
Closed captioning
I had the same problem. My DVD player was connected to my HD TV via a HDMI cable as was recommended by the DVD owner's manual. I removed the HDMI cable and attached the three video component cables. Bingo, closed caption crossed immediately.
Aug 09, 2007 | Funai MWC24T5 24 in. OLED Television
JVC HR-XVC27U DVD Player/VCR Logo
13 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
