Question about Asko W6021 Front Load Washer
Door won't open on Asko 7005 washer - Asko W6021 Front Load Washer
5 Suggested Answers
SOURCE: asko w6221 washer
The motor brushes was the problem, however I had to get a tech to tell me this. Thanks just the same, but a little to late.
Posted on Jan 25, 2008
  • 49 Answers
SOURCE: asko 10505 - wash finished, door won't open
it is most likely your machine may have a draining problem. if it cant drain the water out the door wont open. if you open the small door at the front bottom of the machine you will find the little black drain hose. unplug the hose off the door and drain machine. when the machine is empty try powering on and opening the door. if still no luck you will see (in the same location) a red pull ring. undo the screw holding the ring in position and gently pull until the door releases. it would be worth undoing the button trap lid to access the pump and check for any blockages (most common coins **** pins etc) let me know how you get on.
Posted on Mar 06, 2008
SOURCE: can't open door of front load Asko washer 12225
Open the little door on the lower left corner of the front of the machine, and pull on the red tab in there. door will pop.
Posted on Nov 21, 2008
  • 32 Answers
SOURCE: i have an asko 10505 washer. how do you open the
here is a video that shows someone closing an Asko machine. I think you just have to get your hand in that place where she shuts the door and pull.
http://www.youtube.com/watch?v=kmvxNwqUDJ8
Posted on Mar 28, 2011
Asko service
Please refer page 12 and 24 in the washer manual to find out how to open the locked door. You have to press the door open button for 3 secs at end of cycle.
Asko Front Load Washer Use and Care Guide W6021 W6441 W6761...
Aug 10, 2014 | Asko W6441 Front Load Washer
W6444 washing machine door won't close
Try some WD40 spray on the door and lock. Just a bit. Try closing and opening the door. The machine should be in the <off> position.
Mar 16, 2013 | Asko W6021 Front Load Washer
Door won't open
has your machine got a filter that is exsessable if so you need to undo it and empty the water,( before the door will not open with water in the drum its a safety device if the filter is not on the front of your machine you will need to find it and clean
Dec 10, 2011 | Asko W6021 Front Load Washer
I have an asko 10505 washer. how do you open the door?
Mar 28, 2011 | Asko W6021 Front Load Washer
Asko dryer has no power.Washer ok
By-passed fuses,dealer said he's done hundreds.Saved me a service call.This is the 1st and only problem we've had in 10 years! We love our Asco.
Feb 16, 2010 | Asko Dryers
Asko dryer 7005 will not start. When I touched
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a broken door latch, a bad door switch or even a broken door switch actuator, in a dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Nov 22, 2009 | Dryers
No manual, don't know what the buttons do
laundry.manualsonline.com/.../asko/asko_clothes_dryer_product_list.html
Mar 31, 2009 | Asko T731 Electric Dryer
Asko 7005
Go reset your circuit breaker. Even if it didn't pop out, reset it.
Oct 25, 2008 | Dryers
Asko 7005 and washer 10505
1) there is a reset button on the back panel of you dryer it is in the middle black rubber...
2) you really can't the asko washer needs a 240v to run... You can hire an licenced electrician to wire a 240v plug for your asko washer if you do not want to plug it into the dryer
Jul 01, 2008 | Asko W6021 Front Load Washer
Asko W6021 Front Load Washer Logo
13 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
