Question about LG DLG7188 Gas Dryer
LG dryer power button lights but does not start the dryer
The control panel lights up. I select "cotton" then push the start button, but nothing happens. It seems not to make a connection. Once in awhile, it works, but lately nothing...
5 Suggested Answers
  • 489 Answers
SOURCE: LG DLE 9577
check to make sure that the power legs are correctly installed.  Use an volt meter and measure voltage across neutral and hot.  Hot leads should be on the left and right side and neutral is in the middle.  Hot to neutral should be 120v.  Hot to hot should read 240v.
Posted on Apr 28, 2008
SOURCE: LG DLG5988W
I have the same problem. The dryer was working fine. Now, when I start the dryer it flashes "clean filter" . I'vecleaned out the lint screen, washed it and even vacuumed inside the lint area, wiped down the door and I even checked the vent on the back and outside. Still nothing. Help!
Posted on Feb 19, 2009
heatman101
  • 43501 Answers
SOURCE: dryer will not start
A dryer may not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Apr 11, 2010
Lg wle1501w dryer no power
Since its brand new it should have a warranty I would use that since you trying to could void that.
Jul 05, 2017 | LG Dryers
I have a LG DLE0 442W dryer. I am getting power to the control panel but when I push the power button nothing happens.
Check this website for the correct wiring procedure:
http://electrical.about.com/od/appliances/ht/wirea4prongoutlet.htm
Mar 10, 2014 | LG DLE0442W 7.3 Cu. Ft. Electric Dryer -...
LG DLE0442W won't start
It sounds like the control PC board has been damaged.
Mar 10, 2014 | LG DLE2301 Electric Dryer
Electric dryer will not start
Maybe a defective start button?
Nov 05, 2013 | LG DLE2516 Electric Dryer
Dryer check filter light keeps blinking and dryer will not start cleaned lint filter and nothing happened display on control board blinks when dryer is turned on and that's about it can you assist dyer...
There is a reminder light to "Check Lint Filter" near the lower right of the cycle knob. It will come on every time the power button is pushed. After cleaning the lint filter, if the "check lint screen" light does not go off, it is likely that the touch pad control will need replacement.
Jan 09, 2011 | LG DLE0442 Electric Dryer
Dryer will not start
we had a very similar problem on our DLE3777W LG clothes dryer. It would power up normally, all drying options and speed and heat selections behaved normally but when you tried to start the dryer the start button and the time remaining indicator would flash until the unit was turned off. Called LG and Best Buy and they could only tell us to contact a repair shop. But I realized that the light was burned out inside, so I replaced it myself to avoid being charged by the technician I was about to call. The burned out light bulb WAS the problem, as soon as it was replaced the dryer worked perfectly. I think I saved a couple of hundred dollars with a $4 light bulb. I would have been mad to have the technician show up and charge me $120 just to show up, then an hourly rate and then the bulb.
EJ
Jun 07, 2010 | LG DLE7177 Dryer
heatman101
Apr 11, 2010 | LG DLG5932W Gas Dryer
Sears elite he dryer stopped working
Bad control panel. Replace the control panel at repairclinic.com. When your control panel clicks like that it means that a resistor or solder joint has gone bad and it is cheaper and easier to just replace the board
Feb 19, 2009 | Kenmore Elite HE4 Electric Dryer
LG DLG7188 Gas Dryer Logo
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
