Question about Plumbing
How to bleed water pipes in a two story house?
2 Suggested Answers
  • 125 Answers
SOURCE: i have an audi 97 a4 6 sylander and i had to
Yes you need to bleed the system. There is a hole in the coolant hose going into the heater core. Back of engine at the firewall . Loosen the clamp and slide the hose part way off the pipe. Add coolant to the system expansion tank until it flows out of the hole in the coolant hose . Slide hose back onto pipe and tighten the clamp. Close cap on expansion tank ,turn on heater controls , Start engine and run at 2000 RPM for about 3 min. Continue running engine at idle until the lower hose on the radiator becomes hot. Check coolant level in the expansion tank and add if necessary when system is cool. DO NOT open expansion tank cap while system is HOT.
Posted on Feb 07, 2011
Where is the a/c expansion valve located on 2006 range rovrer
1 - Radiator
2 - Thermostat housing
3 - Radiator bottom hose
4 - Viscous fan
5 - Water pump
6 - Radiator top hose
7 - Heater return hose
8 - Coolant supply hose
9 - By-pass hose
10 - Radiator bleed (purge) hose
11 - Bleed (purge) hose, thermostat housing
12 - 'Y' piece ejector
13 - Expansion tank
14 - Heater rail
15 - Heater unit
16 - Heater feed hose
17 - Intercooler
18 - Air cleaner
19 - Air feed hose
20 - Turbocharger
21 - Charge air supply hose
22 - Cooled charge air supply hose
23 - Exhaust manifold
24 - Engine oil cooler
25 - Feed pipe, engine oil cooler
26 - Return pipe, engine oil cooler
27 - Oil filter
Aug 22, 2016 | 2006 Land Rover Range Rover
Domestic hot water works but no hot water to baseboard heat
If its a one story house, the system pressure should be somewhere around 10 to 12 psi. There should be a PRV (pressure reducing valve) on the domestic water line supplying make up water to the boiler. The shut off valve in that line should be in the open position unless the prv leaks through and slowly overpressurizes your system to the point of tripping the pop-off valve. If so, then the manual shut off should be kept closed then opened only to boost the pressure up a bit in the system. It kinda sounds like you are suffering from low system pressure.
If there is a vent or vents in the system, try bleeding them into a coffee cup and you may find it sputtering air/water mixture. Bleed them until you have full water flow and make sure you keep approximately 10 psi in the system.
Oct 07, 2014 | Cadet Manufacturing Heating & Cooling
I bought a UK spec E39 528i last year with an over heating problem (new head had been fitted)but still over heating.I bleed the water system and drove home just short of a 100 miles with no problem.Next...
remove the colas and repair or change it because the colas is not straight that's while there's pressure in pipes and inside water system .. the CO2 is going to mixed with water
Mar 19, 2011 | 1999 BMW 5 Series
I have an audi 97 a4 6 sylander and i had to change the metal pipe wich transfer water from reservor to termostat housing do i need to bleed the system after fix and soo wher is the bleeding valve thanks...
you dont have to bleed the water it automatically takes out the air when it runs and the thermostat valve opens check the level again after a run of 5 miles or when the temp is in the middle
remember not to check when the engine is hot
Feb 07, 2011 | 1997 Audi A4
Water pump location
Here are the procedures.
WATER PUMP
Removal
1. Drain cooling system. Remove timing belt. Remove right ignition coil. Disconnect coolant hose from coolant inlet housing.
2. Remove retaining bolts and separate coolant inlet housing and "O" ring from water pump. Remove retaining bolts/nuts and water pump. Remove "O" ring from coolant by-pass pipe which fits into rear of water pump.
Installation
Ensure sealing surfaces are clean. Install NEW "O" ring on coolant by-pass pipe. Lubricate "O" ring with soapy water solution.
2. Apply a .08-.12" (2.0-3.0 mm) diameter bead of sealant on mounting surface at rear of water pump. Install water pump. Ensuring water pump engages over coolant by-pass pipe. Tighten
fasteners to specification.
See
3. To install remaining components, reverse removal procedure. Fill and bleed cooling system.
Jan 05, 2011 | 1992 Lexus Ls 400
Sewer smell in house since installing the new toliet and the toliet gurgles when the washing machine is on. It started with the new toliet now the gurgling and smell is also present in another bathroom.
It sounds like a vent problem.
On top of each house is a vent stack.
There should be a vent stack above each toilet, and above kitchen sink.
Look for pipes sticking out of roof.
These pipes are open to the sewer line.
When you run a column of water down a drain, the vent stack lets air flow in front of and behind the column of water.
This air flow prevents the gurgling sound.
The gurgling sound is the drain water pushing air in front of it because of a clogged vent.
If you have a two story house, there are vents that run between floors to prevent the air flow from gurgling or bubbling sewer air into each drain as water column moves down pipe.
http://www.bradyinspects.com/plumbing-vents.html
http://chestofbooks.com/home-improvement/construction/plumbing/Standard-Practical/Venting-Part-3.html
Look for bird nest over vent pipe on top of house.
Run a snake down into pipe from roof and see if the is a stoppage.
You many need to call plumber to track down each vent and the cause.
For example if there are quick-vents installed inside a wall and the quick vent is no longer working.
You can also take advantage of fixya phone support.
Fixya expert will walk you through the steps for a price.
Dec 25, 2010 | Kohler Bath Highline K-11492-96 Biscuit...
Location of radiator bleed valve on a 1999 pontiac grand prix.
Looking at the engine from the front of the car, on the LH side there is a black pipe that comes up from the water pump housing and on top of that is a small screw that will bleed the air in the coolant system.
May 29, 2010 | 1999 Pontiac Grand Prix
My water pump was frozen. so i replaced that and the thermostat. The cars stalls every few minutes, sounds like hard vacuum by the air filter, filter is also new, any suggestions?
iwas the air filter piping removed ?- loose piping or unplugged sensor in plastic pipe could cause problem - water pump is on other end of motor - was air bled from water system - bleed screw on thermostat housing
Sep 24, 2009 | 2001 Pontiac Bonneville
Change thermostat on gm 3400 v6
Drain coolant at the radiator drain. Remove air intake hose and MAF sensor assembly. remove throttle cable bracket and disconnect cable linkage. Remove throttle body bolts and disconnect coolant hoses to throttle body. Loosen heater hose pipe and remove heater hose from rear of pipe. Remove radiator hose from thermostat housing. Remove top thermostat housing bolt. Loosen and almost remove lower thermostat bolt. You will need to slide your wrench and hand under the exhaust crossover pipe to gain access. Loosen the bolt until you can remove the thermostat housing, it should be slotted to clear the bolt. Replace the thermostat and reassemble. Bleed cooling system using the two bleed screws (one on thermostat housing and the other on the passenger side of the engine where the heater hose pipe comes out above the water pump.
Jan 23, 2009 | 2003 Pontiac Montana
My hot water pipes were froze this morning. Michigan! I have cold(almost froze) There is not any water coming out in kitchen from hot side. I have cold though in every room. There is water coming out a...
no easy fix . your water heater should be fine most likely its up to temp ,thats why its not lighting its main flame . the frozen pipe is another story you need to get the heat up in the house open any cuppord doors that have pipes in them like under a sink ( to let heat from the room get it there ) leave a faucet on hot and wait . at some point you will unfreeze . but you migh end up with a broken pipe so keep your eye out for a water leak . good luck
Jan 16, 2009 | Heating & Cooling
Plumbing Logo
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
