Question about Boston Acoustics BA735 Computer Speakers
No sound coming out of speakers green light on speakers is on
No sound coming out of my speakers. Plugged into green spot in back of computer......Dell Dimension E510 and they are not working any help here???
  • 344 Answers
The BA 735 Speakers I have are purely digital and will only work if your soundcard has a digital output, will not work through the normal analogue green socket .
Posted on Jun 25, 2009
Lost my sound when I moved my computer
Have you checked speakers on another computer. Get it checked first if it working on another computer or other device. If it working reinstall realteK audio drivers.
Nov 04, 2017 | eMachines ET1810-01 PC Desktop
Hp 3500 no sound
If you have the speaker cord plugged in to the correct spot and your Realtek sound driver is loaded then there are 2 possibilities.
1. You speakers are bad. Try using a different set of speakers to confirm.
2. The sound output on your motherboard is faulty. You should bring the whole tower back to be replaced immediately.
Double check to make sure you have your speakers pugged in to the GREEN hole in the back of your pc...
Sep 02, 2012 | HP Pro 3500 Microtower Business Desktop -...
Just intalled the speakers but can't hear anything
Here are some things to check for: -Is the power on? There will be a light on the speakers that show it has power. -Is the audio cable plugged in to the right spot? Most likely, the cable will need to be plugged in to a green colored jack on the back of your computer. -Make sure the volume is turned up -- it's the knob on the speaker that you turn.
Mar 05, 2011 | Bose Companion 2 Series II Multimedia...
I cannot get any sound from my speakers or the monitor speakers. I have plugged the green cable to the monitor and to the green connector on the tower with no luck. I have also plugged the extra speaker...
It sound like you have connected them correctly however unless they are multi-channel speakers you should only have to connect the green cable. Check to see if the volume control on your speakers/monitor and also OS are turned up and not on mute and also check to see that you have sound drivers installed for your sound device/card.
Oct 23, 2010 | Acer Aopen MS698 Computer Speakers
No sound comes out of the speakers. They previously worked fine prior to moving
If you have a soundblaster or onboard sound card, be sure that the cord coming from the speakers to the computer is plugged into the green inlet in the back, not the black one. If you plugged into the black inlet there will be no sound from the speakers.
Sep 24, 2010 | Boston Acoustics BA745 Computer Speakers
Speakers and controls are working but sound barely comes out.
Check the back of the computer. Typically this caused when the connection is loose or the speakers are plugged in to the wrong jack. The correct jack on a Dell is usually a light green color. The Microphone is pink, etc.
Jul 15, 2009 | Dell A215 Computer Speakers
Sound won't work without the earphones being plugged in
Make sure the speaker volume is turned up and also go into Control Panel, Sounds and make sure nothing is muted and all volumes are turned up. Also make sure the speakers are plugged into the sound jack in the back of the pc. The speakers also need power but since the light is on, it sounds like they are plugged in.
Apr 14, 2009 | E-Machines eMachines Desktop PC
No sound
2 things to check.
  1. Make sure if speakers have a power adapter that it is plugged in. That should give you the green light.
  2. Where the speakers plug into the computer there are multiple places in a row to plug it in. One is a microphone input, one is audio input, and 2 are for speakers (depending on the sound card you have). Try plugging it in different ones to see if sound works.
Apr 07, 2009 | Compaq Audio Players & Recorders
I had memory added to my pc so everything was unplugged. Now I can't figure out which one is the power source for my speaker bar and where it should be plugged. The speaker bar has the green light on and...
Make sure the green plug from the speaker bar is plugged into the green plug on the back of your computer. If it is plugged into the wrong jack you will not get sound. Hope this helps.
Mar 16, 2009 | Dell AS500 Sound Bar Computer Speakers
Speaker installation
first see to that audio driver is installed in ur computer or not if not put motherboard cd, right click on my computer go to hardwre right click on sound manager with yello question mark and give update driver
Nov 13, 2007 | Audio Players & Recorders
Boston Acoustics BA735 Computer Speakers Logo
668 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
