How to reset audiosonic HDT909 set top box
Video Resolution in TV menu is changed and cannot view the menu option again
2 Suggested Answers
SOURCE: No TV "Select Source" Menu Option
Had the same problem and found on the back of the tv on the black box that the cable hooks to there is a plug at the top of that box on the left side came loose. If you slide that box to the right you can completely remove it from the tv. Reinstall it and make sure it's plugged in tight your tv setting should come back.
Posted on May 16, 2009
Hi, I have an Audiosonic HDT909 set top box and I cant find the 4 digit brand code for it so I can use the Audiosonic universal remote control for/with it .. the orginal remote is shot ! cheers D
You should be able to use code search on the remote to find a code that works. If a search through all codes stored in the remote control fails, you may have to try a different universal remote control. All universal remote controls do not contain all possible codes.
May 27, 2017 | Universal Remote Control Televison & Video
How do I pair srp4004/86 philips universal remote control with audiosonic hdt909 HDTV?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Feb 20, 2015 | Philips SRP4004 Remote Control
Audiosonic hdt909
Posssibly antenna orientation could be a factor. Also, STB suppliers recommend repeating channel search periodically so that missing channels magically appear.
Apr 22, 2014 | Televison & Video
On my Audiosonic HDT909 set top box, I cannot get the picture for channels 9 GO and GEM. I get the audio but no picture.
I have the same problem and searched around and found the solution. It's a hardware fault. You have to take it back and swap it for a different one.
Sep 06, 2013 | Car Audio & Video
Resetting parental controls on my RCA projection TV
From the main menu choose "Parental Controls;" it's option six.
Choose the first option, V-Chip TV Rating Limit, and using the arrow keys and the OK button on the remote, scroll through until the TV-MA rating appears. Press the right arrow button to move the highlight over to the "Status" field and toggle to "View." Press the OK button. This will set the age-based ratings to Mature.
From the Parental Controls menu, select the second option, V-Chip Movie Ratings Limit and change the rating to TV_MA and the "Status" to "View."
From the Parental Controls menu select the third option, V-Chip Unrated Program Block and select item one, which will be "View."
Select the fourth option, which is "Channel Block." Highlight the Channel field and using the channel up and down buttons, go through and check they are all set to 'View." Any set to "Block" will need to be toggled back to View.
Lock the controls to activate the changes using item six on the "Parental Controls" menu.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or make a search by typing in the brand name of the device in the "Search Box", at the top right of the display window
Dec 04, 2012 | RCA Televison & Video
1. Had some problems recently with my lap top.
The action you took to fix your computer by resetting it has reset the screen resolution to what sounds like the XP default.
To adjust the screen resolution follow this set of instructions-
First right-click on the desktop and then left click on Properties from the menu that appears.
The display properties dialogue box will appear, click on the settings tab at the top right of the box.
Screen Resolution
This slide bar is what you use to change the resolution, the options you have will depend on your graphics card and monitor, but the standard options are 800x600, 1024x768 and 1152x864.
Changing the Resolution
To change your resolution simply slide the bar along to the resolution of your choice and then click the Apply button.
After clicking Apply your screen will resize to the new resolution and you will be presented with a confirm dialogue box, if you are happy with the way your screen looks then simply click Yes, if you would like to try a different resolution click No.
//javaftper
Jul 31, 2010 | Microsoft Windows XP Home Edition
Audiosonic km1412d no colour in tv / dvd just black&white
Check in menu for video options, Select pal, NTSC or whatever your country is transmitting. If auto option is available best to set it there. Check also sound options like I, BG, or DK and set again to your transmission,If you have a settop box make sure on other tv it is displaying coulour. saom also have sound and video options. Try to connect dvd with av cables and see if coulour is there. if still B&w get repair technician
Aug 11, 2009 | Televison & Video
i have the booklet tell me what tv dvd or item you wish to control i'll look it up in my book tonyand.michelle@gmail.com
Oct 05, 2008 | JC Whitney - Audiosonic 3-way Custom-fit...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
