Question about LG 32LC5DC 32 in. LCD HDTV
I have no audio
What can be round with the audio, works for a minute and then its gone
I dont know how to set the clock
Setting the clock
Use these instructions to set the clock.
1 Use MULTI-CONTROL to select Clock.
2 Push MULTI-CONTROL left or right to
select the segment of the clock display you
wish to set.
Pushing MULTI-CONTROL left or right will select
one segment of the clock display:
Hour-Minute
As you select segments of the clock display
the segment selected will blink.
3 Push MULTI-CONTROL up or down to
put a clock right.
Note
You can match the clock to a time signal by
pressing MULTI-CONTROL.
! If the minute is 00 to 29, the minutes are
rounded down. (e.g., 10:18 becomes 10:00.)
! If the minute is 30 to 59, the minutes are
rounded up. (e.g., 10:36 becomes 11:00.)
Here is a link to the online Manual: http://a248.e.akamai.net/pix.crutchfield.com/manuals/130/130dehp690.pdf
Mar 13, 2011 | Pioneer DEH-P6900UB CD Player
Tip
Washer knob / Dial going round & round
If the washer knob of the unit is going round and round all by itself it means that there is something that has malfunctioned in the unit or else there was an error in setting proper cycles.
You will first need to reset the unit, to see the reset procedure click here
Once you have reseted the unit and even then the washer knob is going round & round it means that a part or parts in the machine have gone bad which may need to be replaced.
The question would be how can one understand which part in the unit has gone bad.
To make things easier, here is what needs to be done to know which part has gone bad.
  1. After reseting the unit, set a new cycle and switch on the machine.
  2. If the washer knob starts going round and round, the mode+Door lock light will flicker in a sequence, for example, it may flicker 4 times before taking a pause and then flicker 4 times again and continue this sequence.
  3. Once you know what is the count which is also the fault code there is a fault code chart which you can refer to understand which part has gone bad.
  4. The fault code chart is as follows:
Hope this helps, do let me know if this information was helpful or else you need more clarification on the same.
on Mar 02, 2010 | Washing Machines
Cant set up marc vincent wireless surround.need manual
projector mounted on ceiling of dodgy system, picture upside down, how does one get it round the right way, amplifier blew up the minute it was plugged in, we got scammed! does anyone want to tell me how to get the picture round the right way?????
May 16, 2010 | Audio Players & Recorders
My up flush toilet makes a humming sound every 5
The pump has either gone bad or it is siezed up...you can try to unplug the pum and let it sit for a few hours then plug it back in... sometimes if you jog it on and off a few times you can get tiit to break loose and work again...if not you will have to take it out and replace the pump.
heatman101
May 03, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
ENGINE PROBLEM
There are several nationwide salvage yards which are online. Let them do the running. They ship all over so you have more territory covered. Hope this helps you.
Jun 30, 2009 | Metra 70 7903 Mazda Protege 2001 Up Into...
How to set the clock
wish to set.
Hour—Minute
put a clock right.
Note
May 19, 2009 | Pioneer DEH-P5900IB CD Player
Pioneer super tuner3d
  1. Turn the radio off by pressing and holding the SRC button (under the label OFF).
  2. Press and hold the Audio button in the upper right corner of the radio. After holding the button for about 3 seconds, the clock will begin to blink (the hours).
  3. Use the up and down arrows to increase or decrease the time hours or minutes. Use the left and right buttons to toggle between setting the hours and/or minutes.
  4. When done, push and hold the Audio button again fir about 3 seconds until the clock stops blinking (hours or minutes).
Nov 16, 2008 | Pioneer DEH-1600 CD Player
I have an AKAI DGITAL INTEGRATED AMPLIFIER model NUMBER AM-M600 the connection at the back for the speakers has gone on one channel and i would like a replacement part please
when the wires are placed in the slots in the back of the unit there is no sound from one of the speakers so i am asuming the contacts have gone in the unit where the wires go
Nov 06, 2008 | Audio Players & Recorders
Mitsubishi WT 46805 ~ Picture gone..... :0(
Good Day, Corri;
It sounds like the TV has a Circuit problem in the convergence circuit. If it comes and goes then the concern can be corrected by re-soldering the 'conv' output IC"s. A semi-minor repair and cost.
Good Luck, big IRISH.
Aug 18, 2006 | Mitsubishi WT-46805 46" Rear Projection...
LG 32LC5DC 32 in. LCD HDTV Logo
Computer Repairing
Computer Repairing
