Question about Whirlpool Inglis IP8200 Dryer
What model today is similar to Inlgis dryer IH82000
Is IH82000 same as IP82000
2 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: INGLIS DRYER MODEL IP82000 RUNNING BUT NO HEAT.
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.(((((Most common issue)))))
Posted on Aug 04, 2009
What does energy efficient mean?
It means that it accomplishes the same task as similar equipment, but consumes relatively less energy accomplishing that task than previous (or other current) examples of similar equipment. "Energy efficient" is not an absolute term - there can't be any single unique piece of equipment with no peers that can call itself "energy efficient"; it's strictly a comparitive term. That which we today call "energy efficient" will tomorrow be thought of as horribly wasteful and inefficient.
Aug 10, 2014 | Amana Dryers
Frigidaire Gallery Electric Dryer, model GLEQ2170KS.
Can you tell if the dryer is moving air? Is it getting Hot?
if yes, then it sounds like a belt issue. If it is moving air, then the motor is running. If no air, then the motor is NOT running. If this is the case, I would not leave it "Humming" for long. Motor could get pretty hot. Also, there is often a one time over temp switch in the motor. If this gets too hot, this will trigger, killing the motor.
If it seems like a belt issue, look online for instructions for opening the machine up, and check the belt status. Belt could have jumped off a pulley, and just needs to be put back on. Or, something could have failed. You will have to look inside to find out more.
Jul 02, 2012 | Frigidaire GLGQ2170K Dryer
Amana 7300 Tandem
Check the drum surface of your dryer for possible object that may be stucked in the drum holes that may cause damage to the clothes. You may do similar checks of the washer drum if your dryer drum checked negative.
Good hunting.
Aug 21, 2017 | Dryers
I have a 9 year old Roper dryer. Went in today to turn it on and the motor sounds like its running, but there doesn't seem to be anything turning and I hear a high pitched squeaking sound. Any thoughts??
The problem is likely the dryer belt . Here is a video Dryer belt replacement video . It may be a different model but the process will be the same. You can also enter in your model # for diagrams and illustrations. Not all models are available. All parts come with installation instructions.
Feb 21, 2011 | Roper REX4634KQ Electric Dryer
How do I change out the heating element on my kenmore oasis electric dryer model 110.67032600
Use a putty knife to press against NUMBER43.
This is a newer cabinet but basically busts down like an older one.f4825eb.jpg9b58516.jpgAfter the front is removed the dryer magically becomes exactly like this older model here: Cabrio dryer service manual. Similar to oasis.
Oct 10, 2010 | Kenmore 67082 Electric Dryer
How old is this dryer Whirpool electric dryer LEC6848AW3
To tell the age the model number must be given
Apr 30, 2010 | Dryers
My gas dryer (3 yrs old today) wont turn. It just
O turned the drum by hand and it started running
Nov 04, 2009 | Frigidaire Dryers
2. Heating element
3. Thermal fuse
Aug 04, 2009 | Whirlpool Inglis IP8200 Dryer
Clothes dryer squeaks when running
Fixing Frigidaire model # FER641FSO, not stacking, but had similar problem. turnsout one of the coils came off. might try that...
Mar 01, 2009 | Frigidaire GLER331A Electric Dryer
Whirlpool Inglis IP8200 Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
